James Perrett wrote:What speakers are you using? Are they grounded?.
Its Onkyo tx-nr686 connected with Klipsch speakers... Grounded? I'm not sure what that means in this case, except that the Onkyo and the powered Sub-Woofer are plugged into 'Grounded' circuits.
As I said the sound goes away as soon as I unplug the USB cord. I can even make recordings with the Zoom without the USB. Without the high-pitch sound onto the SD-Card.
The diagram will possibly make you flip....
Here is a one-Channel diagram, but keep in mind there is 5-like this. and a 6th channel if you include the sub-channel that also comes through.
https:*?*?*/47TRPMM
It uses a 'Russound ADP 1.2'. To convert speaker-line output to RCA that is connected into the 'Zoom-R16'.
'Left', 'Right', 'Center', 'Sub', 'Rear-Left', 'Rear-Right'. 5.1CH Sound.
My current recordings using my built panel-box are starting to be decent. However, when using the computer with a DAW, I was getting the 'high-pitch' sound. I can edit it out.
Another issue I haven't been able to solve is... But may be totally unrelated is: I'm getting an unacceptable amount of pops and clicks.
Edit: I keep trying to post image. and it keeps failing. I've tried different methods. Here i'm trying just an url.
