Applying EQ ???
Applying EQ ???
Hi
At the mastering stage when deciding to apply EQ which feature would be best recommended to use, the dedicated EQ effects tool inside the Garritan CFX piano sample library, or an EQ preset inside Logic?
I understand its down to personal choice, but sound design is not really my thing.
- DigitalMusicProduction
Regular - Posts: 241 Joined: Thu Oct 22, 2020 7:00 pm
Re: Applying EQ ???
It depends, but basically you use the most appropriate tool for the job you want to do.
If you want to do gentle tonal shaping to brighten or darken the piano, you might choose to just use the tool in the piano plugin, as it's already there and designed for that.
If you want to specifically carve out problem frequencies, or have needs that that go beyond just a stylistic tone control, eg control the mid range more, then a dedicated EQ plugin will offer you more in that regard.
So how to choose the right tool starts from what you want to do.
With a classical solo piano piece though on a well-recorded piano, EQ adjustments should be pretty much unnecessary, and people are very attuned to the sound of a piano - too much EQing a piano will sound bad really quickly.
Re: Applying EQ ???
DigitalMusicProduction wrote:Hi
It's just your workflow. DAWs usually have better facilities for templates, repetitive patterns etc - and you can use the same interface and way of working across projects, independently of whether or not you use that specific software instrument.
Sonically, obviously in the DAW you can chose EQs with slightly different sounds, but I doubt it would make a great deal of difference unless the Garritan built-in EQ really sucks.
Re: Applying EQ ???
DigitalMusicProduction wrote:At the mastering stage when deciding to apply EQ which feature would be best recommended to use, the dedicated EQ effects tool inside the Garritan CFX piano sample library, or an EQ preset inside Logic?
At the mastering stage, the track is already recorded as audio, so the EQ built in to the sampler is of no use whatsoever. The EQ plugins provided in Logic are your only option.
However, if you aren't recording audio, just MIDI performances, then the sampler EQ is an option but you are essentially still mixing, rather than mastering...
Re: Applying EQ ???
Hugh Robjohns wrote:However, if you aren't recording audio, just MIDI performances, then the sampler EQ is an option but you are essentially still mixing, rather than mastering...
How does that work out?
My work flow is that of recording the Yamah CFX sampled piano in MIDI, to edit, then add any effects processing tools if necessary such as EQ or a mastering preset, all this will be done in MIDI, then the final action is to gain stage, then bounce the project to audio, is there anything I'm missing?
Re: Applying EQ ???
No that's fine. Hugh generally works with audio tracks, but leaving MIDI tracks as they are in the project and bouncing out as you say is fine.
Personally I like to bounce out a "mix" audio file, and then "master" that mix file as a separate process, but it's common for people to do everything on the project mix bus these days.
Re: Applying EQ ???
desmond wrote:With a classical solo piano piece though on a well-recorded piano, EQ adjustments should be pretty much unnecessary, and people are very attuned to the sound of a piano - too much EQing a piano will sound bad really quickly.
Thats an interesting point as I'm using the Sony MDR 7506 monitoring headphones which provide quite a flat signal, that said with no EQ applied the overall low mid and high frequency range sounds well when recording with the Classic version of Garritans Yamaha CFX Piano.
Naturally reference monitoring headphones are used to identify the most intricate details of a mix as well as providing a correct balance in EQ, so as you mentioned above, that just might be the case?
Re: Applying EQ ???
DigitalMusicProduction wrote:Hugh Robjohns wrote:However, if you aren't recording audio, just MIDI performances, then the sampler EQ is an option but you are essentially still mixing, rather than mastering...
Just trying to understand this, do you mean you put the processing/mastering in the audio output while the VSTi playing from the midi track before rendering the midi/VSTi to an audio track? Obviously audio processing/fx won't have any effect on a midi track.
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: Applying EQ ???
DigitalMusicProduction wrote:desmond wrote:With a classical solo piano piece though on a well-recorded piano, EQ adjustments should be pretty much unnecessary, and people are very attuned to the sound of a piano - too much EQing a piano will sound bad really quickly.
Headphones that are good for mixing do not favor (too much) certain frequency bands over others, so they don't lead you to mistakenly compensate. If you mix on a Beats by Dr. Dre for example, the bass is so hyped that you will turn it down when mixing, resulting in a mix that will have no bass when played on more normal playback systems.
That said, no headphone (or playback system) is perfectly flat, and certain aspects of mixing (the stereo image, for example) are inherently different in headphones, so you need to "learn" their sound anyways.
As for piano, desmond is spot on: you very seldom need to equalize it if it's "naked" (as in a classical recording) and in a pop mix at most you may want to cut some midrange to avoid clashes with other components, especially if the full range of the piano is used.
But in general: record a good piano in a good space with good microphones and leave it alone. Same goes with sampled or modeled pianos.
Re: Applying EQ ???
CS70 wrote:As for piano, desmond is spot on: you very seldom need to equalize it if it's "naked" (as in a classical recording)
What exactly do you mean when you refer to a "Classical Piano recording" What is unique about it, that effects processing tools such as EQ need not be applied, does it have something to do with the quality of the piano? Or the recorded sound environment?
CS70 wrote:But in general: record a good piano in a good space with good microphones and leave it alone. Same goes with sampled or modeled pianos.
I could be wrong? But Garritans Yamaha CFX Concert Grand Piano from Abbey Road Studios is rated one of the best sample Pianos out there. Having recently purchased it i found, out of the 3 perspectives (Classic, Contemporary, and Player) the Classic default version with AR1s natural acoustic sound environment sounds absolutely perfect.
After studying the microphonic recording process of the CFX, i believe it's this Piano that resembles the qualities in contrast to your quote above, so as say, leaving such a piano naked as it is, is probably the correct thing to do.
Last edited by DigitalMusicProduction on Fri Mar 05, 2021 11:13 am, edited 2 times in total.
Re: Applying EQ ???
DigitalMusicProduction wrote: ...the Classic default version with AR1s natural acoustic sound environment sounds absolutely perfect.
Then you need not worry about EQ and just record your masterpieces...
Re: Applying EQ ???
DigitalMusicProduction wrote:CS70 wrote:As for piano, desmond is spot on: you very seldom need to equalize it if it's "naked" (as in a classical recording)
What exactly do you mean when you refer to a "Classical Piano recording" What is unique about it that effects processing tools such as EQ need not be applied, does it have something to do with the quality of the piano? Or the recorded sound environment?
Classical musical is not a playground for production techniques. No one is distorting the oboes, putting delays on the flutes, and harmonizing the timpanis. Classical music is orchestrated and arranged to fit together, so there isn't much EQing, panning and so on to try to mix together multiple sources into a mix - the composer, arrangement and performances already do that.
DigitalMusicProduction wrote:the Classic default version with AR1s natural acoustic sound environment sounds absolutely perfect.
So why are you thinking about EQing it?
Re: Applying EQ ???
desmond wrote:Classical musical is not a playground for production techniques. No one is distorting the oboes, putting delays on the flutes, and harmonizing the timpanis.
An orchestra with pedalboards is something I want to see...
In seriousness though, and other have pointed it out already, working with sampled instruments is rather different to recording the sources yourself. With a decent piano library for example, a lot of effort and skill will have gone into recording the instrument in the first place, so it's already going to sound good as a lot of the work has already been done.
The last few projects I've mixed that featured a piano have all been done from sample libraries (some just solo piano/vocal and some as part of a larger arrangement) and I don't think I used any EQ at all on the piano. It was just a case of picking the library that best fitted the material, and then adjusting the mic/lid positions within the plug-in got the sound to where I wanted it to be.
Re: Applying EQ ???
DigitalMusicProduction wrote:Garritans Yamaha CFX Concert Grand Piano from Abbey Road Studios is rated one of the best sample Pianos out there...
You do seem to be placing an awful lot of faith in this one product as if it is the only answer to everyone's piano prayers. It really isn't.
Given your overriding desire to get these piano pieces as perfect as possible it makes me wonder why you are using samples at all, rather than a real piano in a real space with good engineers.
Re: Applying EQ ???
Thanks to,
Desmond, Hugh, CS70, Sam, Luke and manwilde for your support on this topic, helpful.
Re: Applying EQ ???
The idea with classical recording is that the music, the musicians and the recording space _are_ the effects. What you are looking for is to capture the interpretation of a specific musician which has chosen a specific instrument, is in full control of its dynamics and is recording in a space with the properties he/she wants and likes.
So in general you don't mess up with the sound of the instrument (EQ), the dynamics of the playing (compression) or the recording space (reverberation).
It's not that you can't. It's that it's usually not the point.
If instrument, musician or space aren't up to par, what'd be the point in getting another recording of Fur Elise? There's lots already.
Haha I have no idea! As you may have seen from my thread last week I just posed that very question to the fellows in the forum and turns out there's loads of options, which meant I spent some 3 full days trying pianos
Gonna check out the Garritan...
Re: Applying EQ ???
CS70 wrote:Gonna check out the Garritan...
It's all down to personal choice as always, and although there are some well sounding Piano library's out there, in my own personal opinion after researching through many library's i felt Garritans CFX and Vienna Symphonic Library Piano suite where amongst the best out there.
With exception of The Vintage D from Galaxy Instruments which i own, unless your a retro fan of vintage Pianos? Then the latter are pretty much indistinguishable from the real thing. As you mentioned above if you decide to look in to the Garritan CFX dont forget to download the CFX brochure, which walks you through the entire microphonic recording process.
One of the finest concert piano technicians in the world, Peter Salisbury, was on hand throughout the entire sampling process to ensure the instrument was captured in the best possible condition. The sampling process was played by a top London session musician to enable complete stability across the velocity layers and capture the sound of the instrument, All analog to digital conversion was completed via Prism ADA-8 interfaces, not to mention the Abbey Road sound engineering team who worked side by side in the production of the CFX, it really is a Piano..
Last edited by DigitalMusicProduction on Mon Mar 08, 2021 7:13 pm, edited 2 times in total.
Re: Applying EQ ???
Yeah no question that a sampled piano is a piano
