Dub and spring reverbs.
This guy is amazing, his studio, perfect, even though I’m not making this type of music, I love the way he’s got things set-up, I can identify with that.
https://www.youtube.com/watch?v=46eJcMkRY4s
Also, that spring reverb :shocked:
It’s just beyond, totally mind blowing....
https://www.rubadub.co.uk/benidub-spring-amp-ii-sping-reverb-amplifier
Of course as usual, and in-keeping with anything I want these days it’s OUT OF STOCK :(
I love this way of working, it applies to so many fields of music, he does have UAD stuff, which is interesting, I think for the vintage effects.
Posts: 21959 Joined: Sat Jul 12, 2003 12:00 am
Re: Dub and spring reverbs.
Post by al_diablo »
I have a nice Keeley spring emu pedal, but the new gamechanger audio pedal looks really good
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
Arp mate. If you want to add some retro 'clang' to your mixes you don't need that dedicated tank driver.
You can use a small mixer to drive the input coil from the headphone output (many cheap amps use the feeble TL072) Then return the signal to a line or mic channel. Or you could use a small hi fi amplifier. Lots of ways to skin this cat, I am sure you will work it out!
For some numbers? "Fender" style reverb channels used the ECC82 valve (some the 81) and that probably puts about half a watt into the drive coil but you can get away with a lot less, just need more 'makeup' gain.
The rare and very expensive Fender stand alone reverb unit used a 6V6 so hitting the tank with about four watts! I do however hear from a good friend amp tech that reverb tanks are not as tough as they were so go easy!
Posts: 19149 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
ef37a wrote:Arp mate. If you want to add some retro 'clang' to your mixes you don't need that dedicated tank driver.
Thanks Dave, I’m just wondering though, how much of the sound is attributed to the unit, rather than the spring? It does sound extraordinarily good, very spacey.
Oh COME on! Spring reverbs are g'awful things from a sound quality point of view. Full of resonances and colourations. I doubt the transducers are very linear. I put one in a 100W valve amp for a famous guitarist*, company favour (never got a drink either!) and had to work up a notch filter to pull out a nasty honk. In other words, it is ALL about the spring!
You do not want to hit them with much below about 150Hz and a sweepable mid filter would be very useful.
*Hank Marvin told me years ago "never name drop"
Last edited by Hugh Robjohns on Thu Mar 04, 2021 10:55 am, edited 1 time in total.
Arpangel wrote:Also, that spring reverb :shocked:
Power supply and spring tank not included... :think::shocked: And its the spring tank that really defines the sound, naturally!
Loving the video, though. Everything sounds better with a shedload of delays and reverbs piled on top. Reminds me of all those 'legalise cannabis' gigs I mixed when at college... I can still smell them now... :lol:
Last edited by Hugh Robjohns on Thu Mar 04, 2021 10:58 am, edited 2 times in total.
Posts: 43704 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Luke W »
Very cool. Making me realise that I should probably get my act together and finish building my pedal rig...
Luke W
Posts: 1698 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
Arpangel wrote: Of course as usual, and in-keeping with anything I want these days it’s OUT OF STOCK :(
Yes, ive been wondering about that. When window shopping online recently i have noticed that there seems to be a lot of items with long lead times "delivery in MAY" etc. As if the factory gates are open but production is on a goslow.
Saw this in a mail shot recently. Haven't tried it or heard it, but it does look interesting. And yes, it is fashionably available for pre-order. What we call 'out of stock'.
https://www.andertons.co.uk/gamechanger ... f23dfc1621
Posts: 13298 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Post by Agharta »
zenguitar wrote:Saw this in a mail shot recently. Haven't tried it or heard it, but it does look interesting. And yes, it is fashionably available for pre-order. What we call 'out of stock'.
That is a brand new product and YouTube is full of reviews.
So I suspect when it is actually released stock will be hard to come by.
Agharta
Posts: 4350 Joined: Sat Oct 30, 2004 12:00 am
ef37a wrote: Oh COME on! Spring reverbs are g'awful things from a sound quality point of view. Full of resonances and colourations. I doubt the transducers are very linear. I put one in a 100W valve amp for a famous guitarist*, company favour (never got a drink either!) and had to work up a notch filter to pull out a nasty honk. In other words, it is ALL about the spring!
That’s their charm, the colourations, if you mix them in with a high quality digital reverb you get some lovely effects.
Mixing on a board like that with it all in front of you, no substitute.
Yer not wiv me Tone. I am saying the spring effects make any electronics contribution virtually inaudible, apart from FR.
Post by djangodeadman »
If you’re looking for a cheaper and more readily available alternative to the Fender reverb tank, there’s only one option: Surfy Bear.
https://www.gak.co.uk/en/surfy-industries?page=0#&auto=true&b=1424
djangodeadman
Posts: 363 Joined: Tue Feb 18, 2003 12:00 am Location: Brighton
I’ve decided, this is all too much, reverb tanks, power supplies, I’m asleep already.
That didn't take long! :D
Posts: 29722 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Frank Rideau »
IMO for dub, I would be tempted to avoid guitar-pedal spring reverb type and would look for the vintagey dedicated units, you know the one you can kick on them and goes tccHAAAaahaaaAA
Some years ago, I found a Space Echo re-201 at a very decent price. The spring reverb in it is very usable. Now, unfortunately, they are going at ridiculous high price, and this without saying the amount of love you need to put into them to get them nicely rolling.
I also bought a Roland RV-100, low price. A little less agressive, but still very nice.
Check the used market, sometimes, you may see reverb units at very decent price.
This more is my kind of studio for making dub music...
https://www.youtube.com/watch?v=QcvIeacjzgE
Frank Rideau
Posts: 249 Joined: Mon Mar 21, 2011 12:00 am
http://soundcloud.com/orgasmo-sonore Revisiting Obscure Film Music
Frank Rideau wrote:IMO for dub, I would be tempted to avoid guitar-pedal spring reverb type and would look for the vintagey dedicated units, you know the one you can kick on them and goes tccHAAAaahaaaAA
I recorded in a local Ska studio in the 70’s, we had a Grampian spring, all right, but not worth £6,000 which is what I saw one up for recently.
I had a very nice Vesta Fire dual stereo spring reverb, that was really nice, very very smooth sound.
Post by MOF »
Arpangel you might want to look at the UAD AKG BX20 and Korg SDD-3000 plugins. I have both of them and like them a lot.
MOF
Post by Mike Stranks »
MOF wrote:... the... AKG BX20...
Now THAT was a reverb! :lol:
Cool ! Indeed the Grampian high value as probably more to do with the name of a certain Jamaican sound engineer associated with it. Also pretty sure once you've paid that price, it does not come free of potential troubles...
There is a growing business of people refurbishing old piece of gear and selling them on a flip. Some of them are actually doing a pretty good and honest job, for example these guys:
https://soundgas.com/
They also have a blog article on spring reverbs for those who are interested to hear what they have to say about the Grampian and other stuffs,
https://soundgas.com/blog/which-vintage-spring-reverb-is-best/
Frank Rideau
Certainly was. I used the smaller BX15 spring reverb for a good few years, which was engineered in a very cunning way. The service manual is here and includes a diagram of how the springs are arranged. Fabulous technology that worked and sounded far better than traditional Fender/Hammond type spring tanks.
Post by MOF »
I could only afford a very small spring reverb and it constantly boinged at the least provocation. I seem to remember buying it from an early incarnation of Turnkey, before they had a shop in charing Cross Road, I think it was in Hendon. The Great British Spring was much larger and better but still had that metallic sound.
Thank you for the service manual Hugh, I love the pictures of all those springs.
MOF
I knew a guy that used a BX20 as a stand for his DX7, he offered it to me for nothing and I said it took up too much room, no thanks, that was about 1988.
Fair enough if you can make a living out of this old stuff, but I do think that some of the prices asked, especially by the people you mention are a bit OTT.
Post by ken long »
Love my Great British Spring for all these reasons. As Frank mentions, Soundgas do a very nice grampian but £££.
ken long
Posts: 3631 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
ken long wrote:Love my Great British Spring for all these reasons. As Frank mentions, Soundgas do a very nice grampian but £££.
What I find quite ironic, is that a lot of this old stuff was bought by people with little money at the time, we had a Grampian because no one else wanted it, the British Spring, that was a budget reverb, the Grampian was the only commercial unit we had, the rest of our effects, and mixer, were home-made.
Then you had all those Jamaican guys doing it all on a wing and a prayer, mostly home made stuff, they’d pick up on something and it would go into legendary status, now it’s worth a fortune, but it was just what was around at the time.
