DI box(es) on a patchbay?!
Post by bradshc »
Hi all,
I have a small home studio with several hardware synths, effects boxes/pedals and an Apogee Element 88 audio interface “connected” via a couple of Samson S-Patch Plus patchbays.
I don’t use a mixer.
I recently took delivery of a lovely new Sequential Prophet 10 and promptly fried the main output by clumsily sending phantom power to it from my Element 88 (at least I think that’s what happened) :headbang:
The synth still works perfectly (evidenced through the headphone output) but the main output is dead.
As soon as lockdown is lifted and non-essential services are open again I will get it to a tech to be fixed.
In the interim I’m planning to get a couple of Radial Technologies Pro-D2s to patch into inputs 1-4 of the Element 88, to prevent anything similar happening in future.
My question is, is it okay to do this through the patchbay?
ie. To have my 4 most-used synth outputs normalled to the 4 Pro-D2 inputs, but available to be overridden (by patching on the front panel) by other synth outputs, and the 4 Pro-D2 outputs normalled to inputs 1-4 of the Element 88, but available to be similarly overridden to the effects inputs on the patchbay, for example.
The objective being to avoid patching between equipment other than through the patchbay, if possible.
I Would very much appreciate your advice.
Thanks,
Conor
bradshc
Posts: 7 Joined: Thu Mar 11, 2021 1:41 pm Location: Ireland
Re: DI box(es) on a patchbay?!
bradshc wrote:In the interim I’m planning to get a couple of Radial Technologies Pro-D2s to patch into inputs 1-4 of the Element 88, to prevent anything similar happening in future. My question is, is it okay to do this through the patchbay?
Not really....
DI boxes are designed to reduce line and instrument level signals to mic-level... but you really shouldn't connect microphone circuits through a conventional patch-bay. This is primarily because phantom power and A-type patch-bays don't play nicely together, and there is a real risk of the inherent shorts caused when plugging and unplugging can generate big voltage spikes that can damage or destroy both preamps and mic (and other gear).The other reason is because it's way too easy to screw up as you did and patch a line source accidentally into a mic preamp and fry something!
If you really want to use DI boxes and route balanced mic-level signals around, then that's fine, but mic level signals and preamp mic inputs should really be patched on XLR panels.
In your case, though, all your sources seem to be instrument level, so a much better idea would be to connect the TRS instrument inputs of channels 1-4 of the interface (which can never have phantom on them) to the bottom row of the patch-bay, and all your instruments to the top row, with the FX on the adjacent sockets as necessary... And that way you can easily plug instruments to FX pedals and inputs in whatever fashion you desire without risk!
Posts: 42816 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by uselessoldman »
Is your techie not working? I got one of my amps serviced a couple of weeks ago, took advantage of them being a little more quiet than normal and parts suppliers are all open for business.
I have the S-Patch, awesome patch bay it can do anything you ask of it and it never complains.
So standard config is instrument signal comes in top rear and out the bottom rear. Using the switch at the front you can then break that signal chain and plug in the front bottom so the signal goes through and out the rear bottom or out the top front from the patch bay somewhere else like an effect loop and back in the bottom front.
Is that what you were asking? So in your case you would plug in the front bottom that would go through the rear bottom to your interface inputs.
uselessoldman
Posts: 247 Joined: Sun May 03, 2020 7:39 pm
Wot Hugh said. Not sure why you feel the need for DIs? Are you using them to fix a problem?
Posts: 21243 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Yes.
His interface appears to use XLRs for all the inputs which are all switchable mic/line, and it seems he has connected those to the patch-bay.
Consequently, he accidentally plugged an instrument into an input that was set to mic with phantom... and (rather disappointingly) his Prophet 10's line outputs appear to have gone phut!
Having shared mic/line inputs on XLRs is a really stoopid idea IMHO, but it's not uncommon, sadly.
Fortunately the first four input channels of the interface use combi-XLRs with instrument inputs on the TRS connection... Hence my configuration advice above.
the purpose of DI box is to convert an unbalanced instrument signal (jacks) to a balanced line signal (XLR), guitars being the usual although yea it can also be used for some keyboards. Then you can run longer cables over XLR and without any signal interference.
Also cos now its a line output signal all interface inputs should accept it, not just a dedicated instrument input when you assign line input over mic for example.
Your synths should ALREADY be balanced line output??? if not then if the signal is unbalanced using a DI box would convert it to balanced. that is from a instrument output to a line output.
I agree with you Hugh, shared XLR/Jack balanced/unbalanced mic/line/instrument sockets on a audio interface with Phantom power is CRAZY silly. Especially considering this is not a cheap interface NOR are his instruments.
Last edited by uselessoldman on Thu Mar 11, 2021 3:46 pm, edited 2 times in total.
uselessoldman
uselessoldman wrote:the purpose of DI box is to convert an unbalanced instrument signal (jacks) to a balanced line signal (XLR)
Not quite... the unbalanced instrument / line / speaker level (depending on the box and its settings) input signal is brought down to a nominal mic level signal. The idea is to feed the signal into a mic preamp. Some DI boxes provide hotter signals than others, but I know of none that manage genuine line level.
Some synths are equipped with balanced line-level outputs, but most — including the Prophet 10 — have unbalanced outputs at a nominal instrument-level (although many can drive line inputs quite happily with the volume control turned up).
For that particular role, you'd actually be better off using a line isolator box like the ART CleanboxII or the ART DTI. These boxes use transformers to balance the outputs, but the transformers are 1:1 so maintain the source signal level, instead of stepping the signal level down to mic level in the way a conventional (active or passive) DI box does.
Hugh Robjohns wrote:Having shared mic/line inputs on XLRs is a really stoopid idea IMHO, but it's not uncommon, sadly.
I like combi sockets, and line/mic switchable is fine too - as long as phantom never makes it to the jack connection. IME that's usually the case.
So, yep all this needs is a jack connection - no need for DIs.
Post by bradshc »
Hugh Robjohns wrote:Yes.
Exactly right, Hugh... I have all 8 inputs on the Element 88 connected to the patchbay via XLR to TRS cables.
It didn't occur to me that the TRS connection of the combi-XLRs connector would not receive phantom power, which of course makes perfect sense.
Thanks to everyone for the advice (and for saving me the cash I would have spent on the DIs that can now go towards getting the Prophet fixed up!)
bradshc
Post by bradshc »
uselessoldman wrote:Is your techie not working? I got one of my amps serviced a couple of weeks ago, took advantage of them being a little more quiet than normal and parts suppliers are all open for business.
He works from a retail music shop (I don't have his mobile number, but I'll get it next time I get the chance!) and those are classed as non-essential and currently closed here in Ireland... until at least the first week in April.
bradshc
Post by bradshc »
The Elf wrote:Wot Hugh said. Not sure why you feel the need for DIs? Are you using them to fix a problem?
I thought I was, but Hugh has set me straight :thumbup:
bradshc
SO you North or South not that it now makes any difference since you are both still in the EU that is a sore subject with my family right now.
Yeah I know a lot of none essential Businesses are currently closed, BUT ONLY TO THE PUBLIC, many are still at work cos they still get orders to complete for ESSENTIAL BUSINESSES who are still open or completing orders made on line.
whilst the rest of us have time on our hands to play with all our toys :bouncy::bouncy:
uselessoldman
Post by Mike Stranks »
uselessoldman wrote:So you North or South not that it now makes any difference since you are both still in the EU that is a sore subject with my family right now.
Yeah I know a lot of none essential Businesses are currently closed, but only to the public, many are still at work cos they still get orders to complete for essential businesses who are still open or completing orders made on line.
Fixed that for you... :lol:
I say again: CAPITALS IS SHOUTING in a forum post :angel:
Posts: 10586 Joined: Fri Jan 03, 2003 12:00 am
Post by bradshc »
uselessoldman wrote:SO you North or South not that it now makes any difference since you are both still in the EU that is a sore subject with my family right now.
I’m in the South. No interest in the politics of it all, but economically the North really do seem to be caught in the middle. Can’t be easy.
uselessoldman wrote: whilst the rest of us have time on our hands to play with all our toys :bouncy::bouncy:
Well, it’d be rude not to :lolno:
bradshc
kudos to you bradshc, I look on with envy at your hardware, but my lass who is a Southerner would never tolerate such gross extravagance. She is always full of ideas on how I should spend my own money. Although it has taken her 6 years to get me to finally decorate my own place, I did hers the minute she moved in. I have this problem see, I cannot see my walls there covered with speaker cabinets !
Last edited by Hugh Robjohns on Fri Mar 12, 2021 12:52 am, edited 1 time in total.
uselessoldman
Post by bradshc »
Quick update, for no other reason than to highlight Sequential's great customer service (in my opinion).
I checked with Sequential and getting the synth fixed by a local tech would have invalidated the warranty (there are no authorised repair centres in Ireland, unfortunately).
Fair enough.
However, for the paltry sum of $25, plus the the cost of sending the voice boards to Sequential in San Francisco (€27), they repaired the problem for me and paid for return postage, all within 3 weeks (most of which was transport time).
Result!
:clap:
bradshc
Sounds pretty good to me! :thumbup:
Posts: 28843 Joined: Sun Jul 05, 2015 12:00 am Location: York
Wow, that IS impressive service! :clap::thumbup:8-)
No wonder they have such a good reputation among their customers.
Posts: 22130 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
I see no reason to worry about balanced outputs on keyboards and DI boxes in a home studio, it’s a waste of time, and just adds more things to go wrong.
Unless you’re running cables over many metres, in an RF hostile environment, it makes no sense.
Posts: 20881 Joined: Sat Jul 12, 2003 12:00 am
Gristleize!
I disagree. The more balanced connections you can make the cleaner system as a whole you will have. It is neither complicated, nor inherently prone to problems. It's not a waste of time at all.
I can cite several studio owners that have been smacked of the gob when I've re-wired them with balanced cable and the veil has been lifted from their eyes and ears. Typically the response is 'why didn't I do this years ago?'.
(DI boxes would be my third choice.)
Use balanced cables every time you can. Your audio will thank you for it.
Arpangel wrote:I see no reason...
I suspect that's because you don't understand the issues involved!
...just adds more things to go wrong.
There is nothing more to go wrong in a balanced interface.
You're right in that interference isn't the problem, but the balanced interface is about much more than just reducing interference.
In a complex studio with myriad connections between lots of different bits of equipment, ground loops are frequently a major problem and notoriously difficult to resolve.
The balanced interface, being fundamentally ground-free, eliminates that problem at a stroke (when implemented correctly).
Post by Jackie The Shepherd »
Hugh Robjohns wrote: Wed Jun 23, 2021 9:43 am
While the whole lot of you gentlemen here are now clearly stating that in a complex studio with myriad connections ground loops ar a PITA and notoriously difficult to resolve.
However I feel that while what you just wrote here is true, there also is a statement you made to me a year back about going TS-TS as it apparently did not matter for a small studio. I find this somewhat contradictory in spirit, if not in words and context. I had over various posts explained my studio as being quite a complex one and with my ever increasing size of synthesisers with unbalanced outputs I am really seeing a challenge.
So one way I thought could be to reduce the cable lengths between the synths and the patchbay rack feeding my two T8s and two DI800s, so a shorter length or unbalanced cable may not be a major issue. But then your point is also there that it’s not cable lengths but ground loops that matter.
So what do I do? My synths are all unbalanced so I have to use unbalanced cables. And buying so many T8s is not easy.
Any advice would be appreciated.
PS: To quote your statement to me in May 2024:
Re: Unbalanced Mixer Direct Out convert to Balanced
Post by Hugh Robjohns » Mon May 20, 2024 11:56 am
Completely agree about the benefits of being able to solder for DIY cables.
My comment you quoted was made because the OP quite possibly doesn't need to use a T8 (or DI800, or pseudo-balanced cables) between his mixer direct outs and interface inputs. Simple unbalanced TS-TS cables may well prove completely satisfactory...
The point is he (and we) don't know because it hasn't been tested.
... but I suspect the OP is locked into a mindset of thinking he needs to provide balanced signals into the interface.
Jackie The Shepherd
Posts: 127 Joined: Fri Oct 05, 2007 12:00 am
Hugh was being pragmatic - short connections under well controlled conditions will be fine if they are unbalanced. Those well controlled conditions include having a good grounding arrangement. Unfortunately many people don't have good grounding arrangements in their studios so, in that case, it is safest to suggest balanced connections.
I have plenty of unbalanced connections in my studio with no noise problems but a large part of that is because I have a reasonably good idea of audio grounding requirements and my computer is optically isolated from anything that passes audio.
If you wanted to be really picky you could argue that unbalanced connections sound better because they go through fewer electronic stages - but an extra op-amp at each end is unlikely to make any real measurable difference if properly implemented.
Posts: 16381 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Jackie The Shepherd wrote: Tue Sep 09, 2025 7:26 pmWhile the whole lot of you gentlemen here are now clearly stating that in a complex studio with myriad connections ground loops ar a PITA and notoriously difficult to resolve.
Difficult, but never impossible given knowledge and good engineering.
Context is important. There's nothing fundamentally wrong with unbalanced connections if the whole system is well-engineered. And using unbalanced connections doesn't guarantee you'll suffer ground loop noise, either.
Bob Katz's mastering studio was designed with unbalanced connections between much of the equipment!
What does that mean, exactly?
So what do I do?
Not worry about connections that aren't problematic, and carefully resolve those remaining connections that are causing problems.
https://www.soundonsound.com/sound-advi ... ound-loops
Has anyone noticed that it's a zombie post reply, and the OP will have sorted themselves out several years ago?
Posts: 18707 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
