Nice setup !
I also want to use a "double Unity" - Setup with the "Finalizer" TC card as an Insert in the LR sum and the second card with the M2000 Software as an intern FX Unit.
But at the moment i have problems to setting the things up. I can use the Finalizer Card as an LR Insert in SLOT 3 with extended routing, but i dont understand the signal flow with the M2000?
Both cards (M2000 and the Finalizer card) are without I/O extensions.
Could you give me a hint, which card i should establish in which Slot and how to setup the routing for the both M2000 engines on the other card.
I dont understand the routings for the M2000 card. I want to use this card with AUX 1 and AUX 2 without lost of Input channels. Until now i could establish the M2000 card only in Slot 3 with extend routing and get my constellation working with AUX 1 and AUX 2 as the Input and routing directly to LR sum.
Its a mess with the routings of the consol, if you are familiar with analog desks...
We had simply some cables to route any effect to any Return Channel...
The manual i do have are incredible about describing the Routing options with the cards.
Would be great, if you can show me your Setup of the Dual TC card desk on the I/O section and the routings.
Another last point about the software. Do you have newer Software for the TC Cards?
I do have the 2.11 Software now on the card but i read, there is a newer software ?
What did change ?
Should i also change the Eproms to V2.16 instead of V2.15 at the moment?
What are the changes?
Sorry for all the questions... but i hope i can save a lot of time in researching all the things.
There are enough other things i want to change on the desk (for example adding direct outs/Inserts for Channel 9-16 to connect my Motu devices. I already studied the service sheets with the PCB and there could be a simple solution to get more direct outs. Normally the desk has only 8 Inserts on the first 8 Channels and i am going to solder 8 additional Jacks for the Channels 9-16 to connect 1-16 to the Motu. In most cases this should be enough for my needs. I have also 3 ADAT Cards coming with the desk, but i dont want to make things more complicated with more and more Outboard gear.
I have tried to connect the 3 Adat cards with my second Motu (a 2408 with 24 Channels of ADAT) but this makes things not easier for me
I also do own 2 x Lexicon Nuverb cards (each on an old Mac, the Nuverb cards are the same hardware like a Lexicon 300 !!) with a ADDA converter (Flying Cow) i plan to use in the future.
That would be a lot of work to realize all the things... so i want to spent not more time in finding the optimal routing in the Yamaha desk for the 2 TC Cards.
Thanks for your reply and i am happy to find a collegue from "Live Business"...
Regards
Henry
