Dither confusion
Dither confusion
Post by RichardT »
I’m confused - should I dither or not when converting from Cubase’s internal 64 bit floating point representation to 24 bit PCM?
As far as I can see, the dither signal is around -140dB when outputting at 24bit, which is way below the noise floor of any real world converter.
And yet some people who should know say that yes, you should dither when reducing word-length to 24 bit.
What’s the truth here?
RichardT
Posts: 5730 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Re: Dither confusion
The rule is very simple: a digital signal MUST be dithered whenever the word-length is reduced.
I'd like to think Cubase would do it automatically for a fixed-point 24 bit output, but if it doesnt then technically yes, it should be manually dithered.
While it is true that your A-D converter (or ambient recorded acoustic) noise floor will be well above the -141dBFS 24-bit digital dither noise floor during the playback of recorded audio, that won't be the case when fading down or up from 'digital silence' between tracks. So while the quantising distortions due to the lack of dither might well go noticed by most listeners, you cant guarantee it and you will definately get technically better results if you do dither the output.
Posts: 43399 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by RichardT »
Thanks Hugh, that makes perfect sense. I hadn’t thought about fades.
RichardT
Post by MOF »
I think you’re confusing the 64 bit internal resolution and the 24bit audio.
Ideally your audio should be at 24bit and whatever sample rate you’ve chosen then dithered (and maybe rate converted) to 16bit 44.1khz for CD standard audio.
If you’re not exporting to CD format there’s no need for dither. MP3 formats are automatically converted from 24bit. The 64bit is for all the mathematical handling of data, such as reducing rounding errors as I understand it.
MOF
Posts: 2535 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
It doesn't matter what Cubase is doing internally (that's where the 64-bit comes in) - that's just the internal processing. When you create a new Project in Cubase you set the 'native' format for the Project and it is this that you need to refer to when considering dithering.
Posts: 21340 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
There is some extra confusion around the 64-bit float format...
With 32-bit float the mantissa is 24 bits long, so assuming your final mix doesn't exceed 0dBFS there is no word-length reduction in producing a 24-bit fixed-point output, so technically, no redithering is necessary.... But in practice it won't do any harm to add it and at least it guarantees a consistent noise floor when fading to/from digital black.
With 64-bit float, the mantissa is obviously longer, so dithering to 24-bit fixed-point is necessary. The only question is whether Cubase (and other Daws) take care of it automatically, or not.
In practice, it wouldn't matter if you dithered any way. The noise floor would rise to -138dBFS... But that's still 10dB lower than the best D-A I've ever measured...
Post by CS70 »
If what you bounce is below 0dBFS in the 24 bit full scale, no.
double (or "float64") numbers can represent signed integers between 2^-53 and 2^53 precisely. 24 bit samples are integers between 0 and 2^24 (i.e. individual distinct values that can be accepted or theoretically produced by a 24 bit D/A or A/D converter). So, once a properly coded mixing engine has done its job into a bus and the bus is below 0 dBFS (where the full scale is for 24 bits words) all values in that bus will fit in the 24 bit range without any need of approximation (incidentally, single precision floats - i.e. 32 bits floating point - can also represent the integers up to 2^24 precisely... only just. So it's the same also for mixing engines using "float" instead of "double", aka 32 bit floating point instead of 64).
In other words, "double" has space for way more integers than needed to completely cover a 24 bits integers space; "float" has just enough.
It's different when you cut the number of bits in an integer representation: in that case your target integer number space is much smaller, therefore large sets of different 24 bits integer numbers are forced into the same 16 bit integer number. Dither is a way to choose the best representative one (alternatively, you can simply think of truncation, and how to select the best approximation).
Post by MOF »
Hugh and CS70, is the 64bit value something that has to be set in Cubase?
I thought floating and fixed point values were something set by the program coders.
I have Logic X , I know of no setting other than ticking 24bit to replace the standard 16bit rate.
MOF
Post by CS70 »
MOF wrote:Hugh and CS70, is the 64bit value something that has to be set in Cubase?
Not an expert about Cubase, but I would be surprised if it were possible - it would mean switching between two different mixing engines. :) As you say, a mixing engine is coded and compiled in a certain way (e.g. declaring "float" or "double" in C/C++ as types of the numbers under calculation - aka single or double floating point).
It's usually set, and the only difference is the amount of additional "headroom" over 0dbFS that you get when moving data (i.e. calculating) between buses (and potentially the size of error in the calculation, but properly coded engines use well-behaved algorithms so it's not a big difference at all).
Post by MOF »
Thanks CS70, that’s what I thought.
MOF
Post by RichardT »
The Elf wrote:It doesn't matter what Cubase is doing internally (that's where the 64-bit comes in) - that's just the internal processing. When you create a new Project in Cubase you set the 'native' format for the Project and it is this that you need to refer to when considering dithering.
That’s the recording bit depth? As soon as you apply gain changes or any processing to that channel, though, the signal is going to be at 32 or 64 bit float, irrespective of the recording bit depth.
RichardT
Post by RichardT »
Hugh Robjohns wrote:There is some extra confusion around the 64-bit float format...
Cubase doesn’t dither automatically. I use Pro-L to do it.
RichardT
Post by RichardT »
Yes in Cubase, it’s possible to choose whether the audio engine works at 32 or 64 bit float.
RichardT
Post by CS70 »
I stand corrected. Fun. Guess it may help a little with performance and RAM usage.
Post by MOF »
I presume that’s on the PC to match the plugins, all modern Macs run at 64bit and support for 32bit was dropped a while ago.
MOF
Post by RichardT »
No, that’s something different - 32 bit addressing. Cubase is a 64 bit app on all platforms in that sense and only supports plugins with 64 bit addressing. The 32 / 64 bit choice in Cubase is about the word length of the data.
RichardT
Post by merlyn »
These are a couple of points I have found make dither more understandable :
- Hardware is 24 bit
When you hear playback from your speakers the digital audio has been truncated.
- Dither is part of PCM audio
Dither turns a non-linear system into a linear system with a small amount of noise. Quantisation error is correlated with the signal -- that means it is distortion which means in its raw state PCM is non-linear. Adding dither gets rid of quantisation distortion making the system linear at the price of a small amount of noise.
With 16 bit recording dither was added before the A/D process. With 24 bit that is unnecessary because the noise from analogue electronics serves as dither.
A question I've seen more than once is from people who want to use hardware effects as inserts in their DAW. A track goes out through the D/A, through the hardware, and back in through the A/D. Should that be dithered on the way out? Yes.
For an application like this, where dither might be used more than once on the same audio, it's recommended to use triangular dither.
For the final dither it's recommended to use noise shaped dither.
The question is then -- what do you want a 24 bit file for? If this is to be given to e.g. a mastering engineer then you could export at 64 bit float and you wouldn't need dither.
merlyn
Post by worshiptuned »
RichardT wrote:That’s the recording bit depth? As soon as you apply gain changes or any processing to that channel, though, the signal is going to be at 32 or 64 bit float, irrespective of the recording bit depth.
yes but then, after this real time processing at 32bit float or 64bit float the file is recorded at the set recording bit depth. Then for the dithering you have to consider the recording bit depth
from Cubase manual
see the paragraph Bit Depth
source:
https://steinberg.help/cubase_pro/v10/e ... log_r.html
worshiptuned
Posts: 138 Joined: Mon Feb 08, 2021 3:36 pm
CS70 wrote:Guess it may help a little with performance and RAM usage.
Greg Ondo of Steinberg explains at 48:55 that the 64 bit float processing precision is intended for recording at 32bit integer, some Steinberg soundcards have this option, I think also others as Merging Anubis. He says he made a blind test and there is a better audio quality (subjective)
https://www.youtube.com/watch?v=RFXBscdP5nQ
worshiptuned
Post by RichardT »
from Cubase manual
source:
Yes, and if you add processing to the recorded track after you’ve recorded it, it will be back at 32 bit or 64 bit float!
RichardT
from Cubase manual
source:
Yes thanks, you are right, it's confusing.
This is why they suggest in order to keep the best audio quality and avoid clipping, to set the recording bit depth also to 32 bit float, when recording with effects.
Then in Cubase is the bit depth to consider when dithering, whenever some processing is applied, 32 bit float or 64 bit float, even if there is a different recording bit depth? :think:
The Elf said differently :!::?:
worshiptuned
All DAWs process internally at either 32-bit floating point or (more recently) 64-bit floating point.
Any sources that you process internally (even if that's just a volume change) will grow in wordlength to one of those formats, and any tracks that you bounce or re-record internally will normally (and sensibly) be stored at one of those formats too.
However, the physical outputs (and inputs) are normally in a 24 bit fixed point format (or 16 bit for some legacy applications).
And any word-length reduction always requires dithering to prevent quantisation distortion.
The mantissa in a 32-bit float format is 24 bits so, in theory, any internal processing should already involve dithering to maintain the 24 bit mantissa accurately. That being the case, if you get your gain structure right that mantissa can be passed directly to a 24-bit fixed point output without further redithering.
The same is not the case with 64-bit floating point which has a larger mantissa.
If in doubt, redither at 24 bit anyway... at worst you'll raise the digital noise floor by a few dB (but it will still be below the actual noise floor of your D-A converter), and it will guarantee nothing nasty happens during fades.
Hugh Robjohns wrote: The mantissa in a 32-bit float format is 24 bits so, in theory, any internal processing should already involve dithering to maintain the 24 bit mantissa accurately. That being the case, if you get your gain structure right that mantissa can be passed directly to a 24-bit fixed point output without further redithering.
I appreciate! Now is much clearer!!! :thumbup:
worshiptuned
Post by CS70 »
worshiptuned wrote:He says he made a blind test and there is a better audio quality (subjective)
I guess... :)
Using double vs float simply changes the size of the unavoidable approximation errors present in every real-numbers numerical calculation made with a digital computer. Assuming that the mixing engine (as it must) uses numerically stable and good algorithms, even with single precision these errors will be very small. With double precision they will be even smaller... which in turn may make an occasional difference to what gets rounded to integers for D/A conversion, ultimately leading to a difference in sound, especially for minute details. So it may be that someone can perceive a difference. I am pretty sure I wouldn't perceive any. :D
I remember back when I was lecturing at the Beeb training centre in the mid-90s, when DAWs were just beginning to be 'a thing', there were lots of arguments about sound quality between 32-bit fixed point (as used on a lot of hardware digital mixers) and 32-bit float (with 24 bit mantissa).
We tried to find a way of reliably demonstrating any audible differences... and failed.
