SpitfireAudio Labs Crashing Studio One
Post by Heavy Metal »
Hi Laddingtons
I've downloaded loads of free Spitfire Audio plugins. When I move between them my DAW - Studio One is just closing down.
Any advice as to how to fix this?
Merci beaucoup :headbang:
Heavy Metal
Posts: 25 Joined: Wed Jun 10, 2020 9:24 pm
Re: SpitfireAudio Labs Crashing Studio One
Post by shufflebeat »
Are you getting any kind of error message from Labs or just the whole thing shutting up shop?
shufflebeat
Post by IAA »
Also I’d make sure you have the latest version of the spitfire audio app.
IAA
Posts: 1621 Joined: Fri Dec 28, 2007 12:00 am Location: York
Post by Luke W »
It may be worth contacting their support directly, they're usually very helpful from what I've seen. They've also recently added a forum to their site, and quite a few of the team are fairly active on there with problem solving. Might be worth a look.
Luke W
Post by uselessoldman »
Are we talking about the ones used in Kontakt library? AS far as my own experience goes, none of them should cause any issues. My only question would be what version of Kontakt are you using?
uselessoldman
Posts: 247 Joined: Sun May 03, 2020 7:39 pm
Post by Luke W »
uselessoldman wrote:Are we talking about the ones used in Kontakt library? AS far as my own experience goes, none of them should cause any issues. My only question would be what version of Kontakt are you using?
No I don't think so, as far as I know all of the LABS instruments use Spitfire's own plug-in.
Luke W
Yep, LABS stuff is Kontakt-free (thankfully! ;) ).
As suggested above, check you've got the latest version of the app/installer.
If you click on each of the instruments you'll see there's a 'repair' button as well (bottom right) so it might be worth giving that a go with one.
shufflebeat wrote:Are you getting any kind of error message from Labs or just the whole thing shutting up shop?
Just closing down completely
Cheers
Heavy Metal
IAA wrote:Also I’d make sure you have the latest version of the spitfire audio app.
Should be. Downloaded everything from their website just day before it stated crashing
Cheers
Heavy Metal
blinddrew wrote:Yep, LABS stuff is Kontakt-free (thankfully! ;) ).
IME that's where the trouble usually begins. I had some great Kontak libraries that the maker suddenly decided he would only expand upon with a bespoke engine - end of libraries. :(
I really wish they would just stick with Kontakt and ditch this 'Labs' idea. :headbang::protest:
Kontakt may not be perfect, and I know there's the license issue for content-makers, but the alternative is not a palatable solution, at least to me. If it ain't Kontakt I ain't buying.
Thanks for all the replies :thumbup: Will get in touch with their support. One thing I've noticed is that when I open up the Spitfire Audio "instrument" you can go between different instruments with left - right buttons or use the drop down selection option. The crashing happens when I use the left right buttons so maybe it's overwhelming system. Drop down possibly slower. Might be talkin pish :headbang:
Heavy Metal
Post by Kwackman »
The Elf wrote:If it ain't Kontakt I ain't buying.
Your point of view acknowledged and generally agreed with, but Labs are free!
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Then why should it not be made available as a Kontakt instrument? That way we would be running mature software that we know works perfectly well. It's a shame IMHO.
Interestingly, having been using Labs since they launched, it's just started crashing Reaper for me as well.
But I still don't like Kontakt. ;)
Post by Kwackman »
Dunno Elf, maybe they (Spitfire) wanted a really simple interface for their free sounds, which might suit some people?
There's other stuff I think works well in their own bespoke player. e.g. Toontrack's Superior Drummer and EZ-series for instance.
Kwackman
