mid range monitors vs untreated space
Post by zingerzingz »
:headbang: Howdy!
I thought I'd share the consequences of a control room in an untreated living room, I use the SE Munro Eggs 150 and measured using Sonarworks Ref 4 and XREF 20 Mic.
11.5 DB boost at 144Hz :crazy: also lots of wacky differences between left and right speaker where symmetry isn't possible, I've used the room EQ correction but understand that's not a sustainable solution in the long term.
https://imgur.com/RGAysLe
An interesting exercise, I'll be converting the shed into a studio, I look forward to those results.
Last edited by Hugh Robjohns on Wed May 12, 2021 4:55 pm, edited 5 times in total.
zingerzingz
Posts: 11 Joined: Sun Oct 24, 2010 12:00 am Location: UK
Re: high end monitors vs untreated space
Hi zingerzingz!
Yep, that's a fairly typical response for an untreated room, which is why most of us here either bite the bullet and install some DIY acoustic treatment, or accept the inevitable and buy some decent headphones instead ;)
Posts: 22540 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: mid range monitors vs untreated space
Actually, that's really not that bad for an untreated room. Apart from the room mode at 144Hz the rest is roughly within a +/-6dB range which is pretty good! I've seen much bigger dips and peaks than that, even in supposedly treated rooms! :silent:
Posts: 43616 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote:Actually, that's really not that bad for an untreated room. Apart from the room mode at 144Hz the rest is roughly within a +/-6dB range which is pretty good! I've seen much bigger dips and peaks than that, even in supposedly treated rooms! :silent:
Encouraging to hear this! I am in quite a large room so think that's contributed to that.
zingerzingz
Post by Airfix »
Martin Walker wrote: accept the inevitable and buy some decent headphones instead ;)
You can nearfield - triangulate - even in a kip - it can be done
Airfix
Posts: 1018 Joined: Mon May 07, 2012 12:00 am
