Should I Reach for EQ or the Fader to Tame High End in a Mix?
Post by dlsmusic »
Hello SOS Folks!
When finalizing a mix, I never know the best way to tame the high end in a mix. Should I roll off the highs on the hi-hat, cymbals tambourine, shaker or lower them in the mix? Or maybe both? Do you roll off some highs when mastering? Perhaps I'm adding too many percussion sounds with a lot of high end content? How do you handle this? Any suggestions, ideas are welcome!
dlsmusic
Posts: 11 Joined: Thu Oct 27, 2011 12:00 am Location: Salem, New Hampshire USA
Re: Should I Reach for EQ or the Fader to Tame High End in a Mix?
I suspect the remedy depends on why there's too much top end, and this is one reason why I still like to start with a pink noise mix:
https://www.soundonsound.com/techniques ... -reference
That way each of your sounds get incorporated into the mix at a suitable level in the first place. You can still do a pink noise mix, even at a late stage, so it's worth a try, if only to see whether you have a good basic balance in your mix.
I spend far more time rolling off stray bottom end from mic recordings that is simply unwanted rumble with no musical content, and I've very rarely had to roll-off highs from acoustic percussion - it only ends to be the electronic percussion that can have excessive amounts of stuff over 10kHz that many people won't hear that will benefit from being rolled off.
You could study the output of your track in real time with a spectrum analyser plug-in to see if anything 'sticks' out at a particular frequency range, but mostly it's down to adjusting fader levels to get everything into balance.
As for having too many percussion instruments, the secret is to make them fit into different parts of the groove for variety - there's no point having them all banging away at the same time and cancelling each other out ;)
Hope this helps!
Last edited by Martin Walker on Thu May 13, 2021 12:21 am, edited 2 times in total.
Posts: 22418 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by dlsmusic »
Great feedback and ideas Martin. I'll get on that pink noise mix strategy right away!
dlsmusic
EQ and faders work differently. If you lower the fader of a hi-hat then the frequency content is still there, albeit at lower energy levels.
If you roll off the highs on the EQ then much (not all, depending on the slope) of the frequency content above the cutoff frequency is removed.
There isn't a 'one size fits all' solution here; it depends on the material and the mix. If you have good ears then you'll find something that works for you which should work for most other folks but, as Martin says, generally speaking paying attention to the low end is critical to a good mix.
It's also one of the hardest to get right, especially without a treated environment. Good headphones can help a lot and a lot of very talented mix engineers use them but it's important to be very familiar with the headphones you're using in order to accurately manage the low end on them such that it works when played through domestic equipment in untreated spaces.
Auditioning your mix in mono is also a worthwhile exercise - a lot of mobile devices and small bluetooth speakers are mono.
The mixing with pink noise strategy is a good one and definitely worth employing :thumbup:
Posts: 9870 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by Zukan »
An audio example would help.
if you find that at certain points in the mix the top end sounds a bit prominent try a dynamic equaliser. That way the top end stays intact when you want it to shine through and attenuated when prominent. There is, of course, automation to consider as well.
Zukan
1-2-1 Tuition
Post by shufflebeat »
It's also worth considering looking at the initial transients of percussion hits rather than overall EQ. This analysis might send you back to the recording process and experimentation with mic position rather than endless auditioning of transient ontrollers.
shufflebeat
Posts: 9956 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Adding lots of eeky percussion is self-defeating. One well-placed hi-hat or shaker will push things along nicely - three or four shakers, tambourines, hats and others and you will have a mess.
As with anything in an arrangement, ask yourself why you're adding each and every part.
Posts: 21334 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by dlsmusic »
As always, lots of great feedback to chew on. I truly appreciate your insight. After a few more listens, I've come to the realization that I tend to add too many high end percussive parts to my arrangements. I'm definitely going to reduce the number
dlsmusic
dlsmusic wrote:As always, lots of great feedback to chew on. I truly appreciate your insight. After a few more listens, I've come to the realization that I tend to add too many high end percussive parts to my arrangements. I'm definitely going to reduce the number
Consider keeping the number (or not reducing them by many) but only using one at a time and just bringing them in and out at different points to add a bit of variety.
Posts: 29365 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by dlsmusic »
Thanks blinddrew! That's exactly what I did!
dlsmusic
Do you not mix as you go? Also, I try and not listen to individual elements in isolation, always listen in the context of the rest of the mix.
That way you can get the big picture, and any EQ, or other issues will stand out.
Posts: 21403 Joined: Sat Jul 12, 2003 12:00 am
Post by dlsmusic »
Arpangel wrote:Do you not mix as you go? Also, I try and not listen to individual elements in isolation, always listen in the context of the rest of the mix.
I do mix as I go but here's where I think I've been going wrong:
- Over use of HP filters across the mix making my mix thin
- This in turn gave the high frequencies too much prominence
- Forgetting to use proper reference tracks to check progress
dlsmusic
