Dynamics and EQ on the Hammond B3 / Leslie Setup
Post by trunkdog »
Would some kind soul offer advice on proper dynamics and EQ for the Hammond B3 / Leslie setup in both a recording and live setting? I can find a good deal on mic technique but nothing on dynamics and EQ.
When doing my research I thought I'd be inundated with advise given the iconic stature of the Hammond B3 / Leslie.
A search at the Keyboards & Synthesis forum turned up no mention of "Hammond"; can that be real?
I have difficulty, particularly in EQ'ing as the droning of the rotor works against my natural instincts.
Thanks in advance for any and all suggestions or experiences.
trunkdog
Posts: 92 Joined: Sat Dec 29, 2012 12:00 am Location: Deep in the Heart of Dixie
Thx - td
Re: Dynamics and EQ on the Hammond B3 / Leslie Setup
It shouldn't need EQ -- the drawbars are the EQ, really -- and I've never needed much in the way of dynamics processing either -- that's what the right foot is for on the expression pedal.
But if your player is not that great, then I'd look at a gentle leveller -- an optical compressor maybe with slowish attack and release times, and a moderate ratio of maybe 3:1 or less.
Post by The Red Bladder »
A droning of the Leslie should not be easily audible. Perhaps you are recording it too quietly? Hammonds like to be noisy!
The Red Bladder
Posts: 3904 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
The Red Bladder wrote:Perhaps you are recording it too quietly?
Or applying too much compression?
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by AlecSp »
The Red Bladder wrote:A droning of the Leslie should not be easily audible. Perhaps you are recording it too quietly? Hammonds like to be noisy!
I've yet to hear a quiet one!
AlecSp
Posts: 827 Joined: Tue Nov 16, 2004 12:00 am Location: Herts, UK
Post by Nazard »
Apart from the first few seconds of 'warm up', and turn off, the practice Johannus organ I play, with Leslie type speakers, makes no discernible 'Leslie' noise.
Nazard
Posts: 796 Joined: Sat May 15, 2010 12:00 am
Post by Dave B »
Hugh Robjohns wrote:It shouldn't need EQ -- the drawbars are the EQ, really
I've never done the real thing, but I do find that a gentle low cut can tame the bottom end a bit when mixing with a band. My modern Hammond (sk2) can push out a fair bit of bass end, so I permanently have the low end shelved rather than boom over the bass.
Dave B
Posts: 5935 Joined: Thu Apr 03, 2003 12:00 am Location: Maidenhead
