Large diaphragm mic for vocals.
How many times have we seen posts like this? and I’m here, asking the same question, simply because I still don’t have a large diaphragm condenser in my draw.
Yesterday was very frustrating, some of you know my music, it’s all over the place regarding "technical quality" it’s not really an issue, but creatively, I’m not getting the results I need, mostly, from the mic’s I have.
Yesterday I tried a Beyer M201, it wasn’t bad, it had a very intimate, breathy, sound, that picked up all my mouth noises, which is what I’m after, but it’s not very sensitive, and I needed massive amounts of gain to get a good sound about a foot away from the mic, it’s a dynamic, that’s to be expected, and my voice, isn’t drums or a trumpet, it’s very quiet, and the gain level started to make background noise a bit unacceptable.
I tried an SM58/57, awful, terrible, bad sound for my voice, and gain problems too.
I’m starting to think an LDC might be a better choice all round, if I was to find the right one, my voice is very quiet, breathy, and I like to be close to the mic, I know it’s difficult making recommendations, but any suggestions as to the right ball-park would be helpful, I need it to be good quality when needed, most of my stuff is low-fi, but I need the flexibility to be clean when I need it.
Posts: 22006 Joined: Sat Jul 12, 2003 12:00 am
Re: Large diaphragm mic for vocals.
So, standard reply no.1 - what's the budget?
Posts: 19211 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by Kwackman »
Arpangel wrote:Yesterday I tried a Beyer M201, it wasn’t bad, it had a very intimate, breathy, sound, that picked up all my mouth noises, which is what I’m after, but it’s not very sensitive, and I needed massive amounts of gain to get a good sound about a foot away from the mic, it’s a dynamic, that’s to be expected, and my voice, isn’t drums or a trumpet, it’s very quiet, and the gain level started to make background noise a bit unacceptable
Move the 201 closer, but off axis a bit to avoid plosives?
Also, if you don't have one, try a good quality wind shield with the 201.
They don't list one, but maybe Rycote could provide one?
Kwackman
Posts: 3691 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by shufflebeat »
I've been eyeing up a Beyer m88 for some time now but haven't really been able to justify it to myself. The "research" I've done would suggest it's worth considering.
Or, if you like the sound of the m201, just put a Fethead or Martiaudio inline preamp on it.
I've used the basic foam-dom that came with the m201 for vocals and the loss of quality has not been the main limiting factor.
shufflebeat
Posts: 10115 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Post by Kwackman »
shufflebeat wrote:I've used the basic foam-dom that came with the m201 for vocals and the loss of quality has not been the main limiting factor.
Would it be yellow by any chance?
I got mine 2nd hand many years ago, it came with a large yellow windshield.
My previous employer had several M201s, and they also had these yellow ones.
Is it a M201 "thing"?
(Apologies to Arp for the meander from topic)
Kwackman
Haven't you got an MKH40? I'd use that. Plenty of output level, so gain wont be an issue. And if it was good enough for Enya.... ;-)
Posts: 43724 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Bob Bickerton »
The answer is - it depends!
Is it just for your voice? In which case find a mic that suits your voice the best. Do you play as you sing? Multi-pattern, including figure of eight could be good. Budget (as has been said).
M201 can work well, I’d tend to eat it a little more than you suggest and use its bespoke pop sock. MKH40 - why not? I’ve had good results with MKH8040 and 8050s.
First vocal mic out of locker for me at the moment (could be different tomorrow) - UMT 70S - but it all ‘depends’.....
Bob Bickerton
Posts: 5644 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Mike Stranks »
Budget is the crucial factor of course... along with the match between your voice and any mics characteristics.
If you like the sound of the 201 but the gain issue is the stumbling-block then get an in-line preamp like a Fethead or Cloudlifter.
I don't have a lot of experience of decent LDcs, but I do like the Rode NT1 - a classy mic that punches way above its weight.
I have two, one inoperative and both have cute little foamdoms in funereal black.
Not all of us can carry off such an ostentatious fashion statement like you, Kwack.
shufflebeat
Mike Stranks wrote: I don't have a lot of experience of decent LDcs, but I do like the Rode NT1 - a classy mic that punches way above its weight.
Are you referring to the original nt1 Mike? I hear it's a very different animal to the nt1a.
I have an nt2 which, when it sound good it sounds great and is multi-pattern, harder than the m201 but sometimes that's the goal.
shufflebeat
The current iteration of the NT1, which is different to the earlier NT1, and which itself was different from the original NT1. It has been a much-used descriptor by Røde.
Post by Tim Gillett »
Arpangel wrote: Yesterday I tried a Beyer M201, it wasn’t bad, it had a very intimate, breathy, sound, that picked up all my mouth noises ...my voice is very quiet, breathy, and I like to be close to the mic...
A quiet voice can seem breathy, with prominent mouth noises, sometimes overly sibilant simply because the meat in the voice is weak in comparison. If so this is not a mic issue but voice. Singing harmony regularly in a band for some years I learned to strengthen my voice so that it was more full bodied ... relaxed, louder in the vowel sounds but without strain, and things like mouth noises, breath noises seemed to recede by comparison even though they remained at the same level.
Sure the mic needs to be good but it can be a temptation to blame the mic or some other piece of gear for what may also be a voice production issue. I say that having not heard your voice Tony, just speaking generally.
Another thing is that when you perform live at various venues as I have, you often have to sing with whatever mic, system and operator is provided, and to do the best you can with it. I realized that the one thing I could control and hopefully develop was my own singing voice especially as I always carried it with me.
I watch a lot of YT live performances by vocalists and often there are so many other factors involved in the final vocal sound we hear that the exact type of vocal mic (make and model) so long as it's a reasonable one, which it usually is, seems only a small factor.
Tim Gillett
Posts: 2708 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
Post by Kwackman »
A quiet voice can seem breathy, have prominent mouth noises, sometimes overly sibilant simply because the meat in the voice is weak in comparison. If so this is not a mic issue but voice.
You quoted Tony, but missed an important bit out- he's not complaining about his voice quality...
Kwackman
Kwackman, Hugh says Tony already has, apparently, an MKH40 and asks why he doesnt try that. I second that.
Tim Gillett
Wonks wrote:It has been a much-used descriptor by Røde.
Great for not avoiding confusion.
shufflebeat
Post by Guest »
Arpangel wrote:...I know it’s difficult making recommendations, but any suggestions as to the right ball-park would be helpful, I need it to be good quality when needed, most of my stuff is low-fi, but I need the flexibility to be clean when I need it.
You might want to try an Audio Technica 4080 active ribbon mic.
https://www.soundonsound.com/reviews/au ... 080-at4081
Guest
Post by manwilde »
I´d just like to say that the quest for the right vocal mic is real fun and really worth it. I´ve been doing quite a bit of testing myself lately, and had an epiphany just a couple of weeks ago when I tried my Golden Age active ribbon mic: with my voice, in my room, and for most of the music that I make, it´s just right. No eq, just a tad of compression and voilà!,
So, as it´s been said here many times, the best choice is not necessarilly the most expensive, or a LDC.
By the way, other mics that I tried were EV RE-20 & 635a, Roswell Mini K-47, Sennheiser e-835, Oktava Mk012 (omni, cardioid, hyper), and some others. All good mics FWIW, but there you go.
manwilde
Posts: 294 Joined: Mon May 07, 2018 3:57 pm
Post by Airfix »
Ribbons are sweet - they have a 'neutrally' slow response - that sharp attack - you would not notice with a ribbon - sweet mics. They are not like LDCs - which are open and honest - I have an old se2200 which is is fantastic
Airfix
Posts: 1018 Joined: Mon May 07, 2012 12:00 am
Post by manwilde »
Yes. To me, it "just sounds like a record", and that´s a marvellous feeling! :D
manwilde
The current NT1 is a very different beast to it's earlier incarnation and very markedly different to the NT1a. Why Rode willingly engendered the understandable confusion is beyond me... maybe that's why it's a bit of a 'sleeper'... I'd have one back in my mic box in a heart-beat if I was in the market for an LDC.
This is the NT1 to which I refer:
http://en.rode.com/microphones/nt1
Mind you, if I had the need and the dosh, I'd after one of these:
http://en.rode.com/microphones/ntr
Because it’s only been sold as a bundle, albeit a very worthwhile bundle, it does move the package out of most people’s ‘my first mic’ price bracket. And as a second or third mic, you may not want all the bundled extras, which again makes it less attractive for a lot of people.
No idea why it’s not sold on its own.
I few months back I posted here about the MKH40, just didn’t work for me, I don’t like singing into small mic's, or mic's that seem to be fragile and pop at the drop of a hat, I did use a shied with the 40 by the way, and it still popped. The 201 sounds much better on my voice and pops less than the 40, but I do find I hold back, and get all hesitant with small mic's I think a ribbon may be bad too, close-up, not good for the ribbon I guess.
Budget? Not sure, trouble with this situation is that it’s difficult to try mic's out, and there are so many! If you make a mistake with a cheap one it’s not that bad but if you’re spending thousands that’s bad, not that I want to.
The cheap option would be to stick with the 201 and get around the gain problem, I’m using it through a channel on my A&H MixWizard, I haven’t tried it with my main preamp which I think will be a lot better, it has a lot more gain, I’ll try that today, it’s been hiding away and I found it last night, see how that goes.
The expensive option I’m thinking, may be an AKG 414, I like that mic, on tracks that have used it, it seems to have a bright sound, not sure.
Enya? MKH40? I would never have thought that, I’d like to know how she used it.
My vocals are half spoken, I wouldn’t call it singing as such, the nearest I get to that is a cross between a drunken Laurie Anderson Tom Waits, on a bad day,
I am content with my voice, it’s not anything really, it does the job, so I’m not after looking to improve it.
Post by Guest »
My bottom line:
just stick with the 201 and get a booster. It’s my prefered alternative to the more frequently suggested SM57/SM7 for that kind of situation...
Guest
sound bites wrote:My bottom line:
Seems to be, yes, I’ll try it today with another preamp, the A&H is a great line mixer, but as usual, on a lot of mixers, the mic amps aren’t anything to write home about, a bit noisy, with quite bad gain bunching, they only give me a usable range when turned up full, with a 201.
If you have hang ups about singing into a small mic, stick a big mic up as well and sing into that.
Posts: 29730 Joined: Sun Jul 05, 2015 12:00 am Location: York
