New PC Build for recording
Hi All
I have got to the stage where I need to build a new PC. I built my current one and the one before that but (scared to think) how old my current one is - Definitely over 7 years anyway. Long story short I have not kept across PC builds since but will be comfortable building one.
I am at day 1 of research on this so don't know anything about best motherboards, processors, cases etc - the works. My current PC although old is still going strong but I am at a position where everything is caving in. I am using Pro Tools 8 because I have an MBOX2. As a result I am on Windows 7. To upgrade Windows, I will need to upgrade Pro Tools and then the MBOX is dead so need to sort out an equivalent there,
So then I get to the PC which is why I am here. That is showing small signs of dementia too so let's start from the ground up!
So my question to you fine people is about building a new PC. Can you share some recommendations on what products are good and work well together? I will only be using this PC for music recording. No gaming at all. So it needs to be tailored for recording. Quiet is important but mainly processing power and something that will last me another 7 years!
Not sure how long processors live for but my current one is an i7 and the case in an Antec which is pretty cool. The hard drives are old of course so probably best to replace them and just copy files over. So lets say I replace everything. If you can throw a few ideas at me, it can become a starting point for research and I would be very grateful!
Re: New PC Build for recording
I built a system recently and I found the technology has moved on from seven years ago.
- DDR4
- M.2 NVMe drives. Spinning hard drives now seem very slow.
- More power connectors for more current to the CPU and graphics card. ATX is supposedly a standard but my old ATX power supply wouldn't work in my new machine.
- USB 3.0 3.1 3.2 This wasn't relevant to me.
- X570 chipsets have a fan on the motherboard. I avoided that.
I went with a Ryzen 3900x, B550 motherboard, be quiet! case and power supply and a Noctua D-15 cooler which is about as big as an air cooler can get. It wouldn't fit in every case.
I have found out for myself what base clock/boost clock means. I haven't found there are many scenarios in my usage where single threaded performance would be relevant. Encoding an mp3 is a single threaded process -- other than that I see all the threads being used all the time.
A Ryzen 3900x is quoted as a 3.8GHz base clock and a 4.6GHz boost clock. I've never seen 4.6. This can only happen when only one core is being used. When all cores are being used the boost is less. It sits at 4.2 and goes down slightly under (extreme) load. For music production the relevant figure is the all core boost which I don't see quoted in specs often.
Full disclosure : I use Linux. YMMV.
- DDR4
You will get a lot of ideas, but I have always said its best to understand yourself what you need not just have someone else give their own opinions, take them as advice. I will quote Scan prices just to keep others happy !!!!!
Buy the cheapest is never wise nor the best, somewhere in the middle is always a good place to start. So lets say the Ryzen 3800x CPU at £280 next one up 3900 is a big jump in price. By a cooler that does not get in the way of the memory, I have some top end CPU coolers that are terrible designs and limits me on the Ram (memory) I can use.
Graphics Card. Now we have a problem cos there hard to source new right now for decent prices. I would go to your local Trademein or CEX cos they will give you a 2 yr warranty so piece of mind. I bought my Vega64 about 18 months ago for £240 its now over £100 more and on eBay sell for over £400, graphics cards have shot up in price even good old second hand ones. If your not gaming, on board HDMI might do, but I never recommend it, but its an option. The ASRock x570 Phantom Gaming is actually only £144 looks interesting. You can always add a graphics card later when they are a more sensible price. I would normally never advice ASRock but considering it has onboard VEGA Graphics and thunderbolt, it will save you a small fortune up front. I would not suggest a cheaper motherboard cos the X570 is a great chipset and the boards are all well made with quality features.
memory. Absolute minimum of 16Gb. I would recommend this for starters should you need more its easy to add more later. If you are using built in graphics it will use 2Gb of it so leaving you with 14Gb if you only had 8Gb having 6Gb left is just not enough for music.
Storage M2 Boot and what ever you need there after. I have started to buy Skyhawk Hard drives cos they have a longer than standard warranty and built to be hammered as there designed for Surveillance kit and happy to run 24x7.
Case power supply etc buy good ones. I use a Seasonic 850, cos I am running a system that demands power. You might get away with something smaller but try and keep to 750W minimum also buy semi modular you only then use cables you need.
- uselessoldman
Regular - Posts: 247 Joined: Sun May 03, 2020 7:39 pm
uselessoldman wrote:The ASRock x570 Phantom Gaming is actually only £144 looks interesting. You can always add a graphics card later when they are a more sensible price. I would normally never advice ASRock but considering it has onboard VEGA Graphics and thunderbolt, it will save you a small fortune up front.
It doesn't have on-board graphics. It has graphics outputs if the CPU supports graphics.
It has a M.2 key for Wi-Fi -- not relevant for an audio machine, and it has a fan on the motherboard. Reports are that these fans are quiet enough, but will that be the case in a year? I think there are a few X570s without fans, but most do have them.
Fans on chipsets is nothing new been around for a long time hardly going to matter when you consider the size of other fans on the CPU, Power Supply, Cases and some graphics cards. My case is certainly not quiet about the same as a decent power amp and I use a Factual Design R2 XL, Noctua Case Fans, Noctua CPU Fans and was one of the best cases you can get for sound insulation. Problem is when your running a decent CPU and Graphics you need all those case fans and the Noctua case fans are not cheap. My cases I think have 6 installed and another two on the cooler over £200.
Your right Merlyn on board graphics would appear to be off the cards for now with available supply of any CPUs going to manufacturers not OEM builders. And yes one of the M2 can be used as you said for WiFI but there also dual M2 for NMVe SSD drives. I have WiFI access to my computers through the router and locally shared folders.
That said the attraction of Thunderbolt is worth considering.
All that said, that is why I am waiting for Thunderbolt on all motherboards and waiting for DDR5 . I would not tell anyone to wait, I would though suggest taking it into consideration as this will be a big update/upgrade to all current systems, new motherboard new memory.
- uselessoldman
You're right about this being a bad time to buy a graphics card -- some of the prices are ludicrous. There is a global shortage of graphics cards and some people are taking advantage of that.
On the subject of quiet -- the noisiest part of my system is the old graphics card that I took out my old machine. Its one small fan is noisier than two be quiet! pure wings and two 140mm Noctuas.
I noticed before the graphics card shortage there were cards available that shut the fans down when the load was low like a MSI RX580. I'd go for something quiet like that once the prices settle down.
You could do a lot worse for ideas than going to the SCAN website and looking at the components they are using in their own 3XS machines.
Posts: 43624 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote:You could do a lot worse for ideas than going to the SCAN website and looking at the components they are using in their own 3XS machines.
Definitely. They've also got some helpful guides of where to focus your money and efforts for different use cases, under the "Pro Audio PCs Introduction" section here:
https://www.scan.co.uk/3xs/custom/daw-digital-audio-workstation-pcs
Luke W wrote:You could do a lot worse for ideas than going to the SCAN website and looking at the components they are using in their own 3XS machines.
I just did that and i have a question:
I read somwhere here that it is best to use the same RAM clock speed than the CPU use; so 3200 for a Ryzen 5900X for exemple. And here they are using 3600Mhz RAM .
What do you think of it?
I want to build a new DAW with a Ryzen 7 5800x
i know i will be using an X570 motherboard (wich one? too many choice, and a lot of gaming oriented MB ...)
32Gb of RAM, but 3200? 3600? i'm lost.
and M2 SSD hard drives for Windows and sound libraries
Any recommendation for the Motherboard and RAM clock speed?
-nemo- wrote:I read somwhere here that it is best to use the same RAM clock speed than the CPU use; so 3200 for a Ryzen 5900X for exemple. And here they are using 3600Mhz RAM .
With Ryzens there's another clock for what AMD call the 'Infinity Fabric'. Ryzens use a chiplet design and Infinity Fabric is how the chiplets talk to each other. The fastest the Infinity Fabric can go and stay in a 1:1 relationship with the memory clock is 1800Mhz. It's DDR -- double data rate so with 3600MHz RAM the memory clock is 1800MHz and the memory reads and writes on both edges of the clock signal. 3600MHz RAM then gets called 'the sweet spot'.
I built a Ryzen system recently and I used 3600MHz CL16 RAM.
I used a MSI B550A Pro motherboard which has been fine and doesn't have a fan. Unless there's something about the X570 that you particularly want?
I built a PC last year, but I have to say with parts shortages becoming more common it might very well cost more to build your own PC than buy one from Scan. In fact, even at the best of times you don’t save much.
- resistorman
Frequent Poster - Posts: 2976 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
I built a Ryzen based PC, 3900, with 64GB RAM, last year.
For RAM, use Ryzen optimised for better timings:
https://www.scan.co.uk/products/32gb-2x ... -amd-ryzen
The MB was an Asus PRIME X570-PRO,
https://www.scan.co.uk/products/asus-pr ... usb32-gen2
The cooler, a Noctua NH-D15 SE-AM4 (but you need a wide case),
https://www.scan.co.uk/products/noctua- ... h-a15-fans
NVME, x2, Samsung 970 Evo Plus, 1TB (the X570 chipset runs PCIE4, so is quick),
https://www.scan.co.uk/products/1tb-sam ... te-600k-55
And yes, I always look at what Scan are using, also Puget systems in the USA, as I do a lot of photography and video work.
@Trevor Johnson The RAM you linked to is CL18. CL16 would be better. You do know the SSD you linked to is PCIe3?
@-nemo- Looking at the link Trevor posted an obvious difference between a B550 chipset and an X570 is that there are more PCIe4 lanes. So the X570 has two PCIe4 M.2 slots. On the B550 motherboard I got there is one PCIe4 and one PCIe3 M.2 slot. And do you want RGB? I didn't.
I've got a PCIe3 M.2 NVMe SSD (bit of a mouthful) in at the moment and it's fast. PCIe4 SSDs like a Western Digital Black claim sequential read speeds of 7000MB/s or twice as fast as what I've got in this machine. PCIe4 is so fast the M.2 drives have a heatsink. With PCIe4 I think it might boot up before I've pressed the power button.
merlyn wrote: I used a MSI B550A Pro motherboard which has been fine and doesn't have a fan. Unless there's something about the X570 that you particularly want?
PCIE 4.0! For a 2To SSD with my soundbank so they can load as quickly as possible!
The Asrock X570 Taichu has 3 x M2 PCIE 4.0 ports!
One for the system, one for my soundbank and one for the others soundbank when i will be rich enough ^^
Yeah, newest PCIe4 drives seems insanely fast!
And no RGB needed for me neither! my 12yo are far enough
For 32Gb of RAM, Is 4x8 better than 2x16?
Thanks for all your answer guys!
uselessoldman wrote:Fans on chipsets is nothing new been around for a long time hardly going to matter when you consider the size of other fans on the CPU, Power Supply, Cases and some graphics cards. .
It can matter quite a bit if your little chipset fan emits a high-pitched whine as opposed to the spectrum of noise generated by the much larger fans on the CPU, PSU, case and some GPUs - no?
Username checks out.
- n o i s e f l e ur
Regular - Posts: 424 Joined: Sat Aug 04, 2018 6:20 am
I hope at 57 any high pitched noise will be well over my hearing threshold, but yes noisefleur you are right someone much younger with significantly better hearing might be driven a little mad by any high pitches whine. Not to be confused by the whine of your partner when they find out you bought another expensive toy without their permission.
Neno that is an interesting question and it depends on the systems architect. For example older chips used single channel memory so it was advised to use 2 chips one per channel, now with dual channel memory that is no longer relevant. So for example lets take 16GB is onex16 twox8 or fourx4 sticks better? The system doesn't care it just sees 16Gb but if you have 4x4 there is no room for more so with one 16Gb there are still 3 sockets free for future expansion. So my advice would be twox16Gb leaving you 2 free should you ever want to upgrade later.
- uselessoldman
Many thanks, Merlyn: "@Trevor Johnson The RAM you linked to is CL18. CL16 would be better. You do know the SSD you linked to is PCIe3?"
The RAM I linked to was the recommendation from Pete Kaine, from Scan, who had tested many RAM sticks when evaluating the then new Ryzen 3900 and 3950. That was back in late 2019.
Yes, my MB is PCIE4, but I couldn't find any PCIE4 NVME at a reasonable price. So I went for the Samsung, which had a 20% discount. Bear in mind, this was 18 months ago.
MB 'micro fans'. No problems: I have an Asus X299 Sabertooth, 10 years old now, working fine, and my hearing still goes just above 16KHz....My Asus X570 MB, the same....The best place, by far, to choose your fan parameters, is in BIOS.
What do you think of the Gigabyte AORUS Ultra?
Some people told me that Gigabyte ar not as reliable as MSI or asus
I was looking at the MSI MEG X570Unify too
Both have 3 PCIe 4.0 for SSDs
Why do you think they use the Asrock x570 Taichi on scan.co.uk more than the 2 I listed below?
I already have:
Crucial Ballistix 3600Mhz CAS16
Be Quiet Dark Rock 4
Noctua and Be Quiets case fans
Power supply
I'm going to get 5800X or 5900x if a good opportunity come around.
I just need to choose the motherboard but it's a pain, there are quite similar and i dont know if one of them suit my needs better than the others. The Gigabyte is cheaper right now
I already have:
Power supply
The Gigabyte AORUS Ultra is a very good board, it's one that Puget systems use for their X570 builds. Gigabyte are a very good company, I've used them previously.
I think the Asrock may have been one of the earlier X570s, perhaps that's why it's featured.
-nemo- wrote:I'm going to get 5800X or 5900x if a good opportunity come around
Consider a 3900X, it is a very fine CPU and around the same cost as a 5800X, but a lot less expensive than a 5900X, with the same core count as the 3900X. The money you save could buy you a very nice SSD or more RAM.
Have you sourced a GPU yet?
I was in the same position as you a couple of months ago and went for an upgrade as well. The components I went for are on this list:
https://pcpartpicker.com/user/maartenl9 ... iew=gyvvjX
Regards,
Maarten
Regards,
Maarten
- maartenl945
Poster - Posts: 43 Joined: Mon Dec 28, 2020 11:54 pm
Check out my YouTube channel about home recording called Lanewood Studios.
Since the title of the thread was recording and not composing or mixing, then I would say any system that has 8Gb and 2 cores 4 threads would be enough. Thus far I have fed 16 individual tracks into my Behringer x32 from my Focusrite Liquid 56 and ADA8200 via xlr and out via USB to my Surface Pro (running Studio One) and it has been flawless at 24/44kHz. I did go over the 16 with guitars and keyboards but it made no difference, this was from one computer to another one daw to another going through the x32
The Surface Pro is only recording/capturing the tracks, no effects etc... all those are done either at source or on the mixer. I should also add I am using a SP4 that has the i5 dual core and not the SP6 that is a full quad core CPU !!!!! I paid £240 and it came with the docking station, pen, keyboard and upgraded to the 256Gb Samsung 970 EVO SDD which I have further upgraded to 1Tb. I also added a 512Gb MicroSD card and when testing that it appears to also work.
Now when it comes to editing, composing that is something completely different since it depends on the software\vsts\Kontakt number of tracks etc you are using.
Of the 16 source tracks I used to test, 4x Superior Drummer, 1x EZ Bass, 6x Kontrol\Kontakt 3x Ample Sound 2x Vocals all run minimum 3 effects per individual channel and nothing is optimised that takes just shy of 16Gb and running 8 cores with ease when optimised it only uses 7Gb. Even when I double up the tracks to 32 using the full 16 outputs (two into one) the source computer only hits 22Gb and 12Gb optimised and the CPU is still well under 50%. The system is a FX8350 with 24Gb Ram, 1Tb NVMe with a ton load of storage. Firewire into the Forcusrite at 44Khz since that is the max the ADA8200 will go to when switched on and running with the Liquid 56 with all 16 XLR outputs going to the X32 over 2x 8 XLR snakes. Using the SD16 & SD8 makes no difference similarly when I plug in and add my guitars & 2x midi controller synths etc no difference.
When new this was a top of the range desktop consumer system (home computer) and not cheap, today I would expect to pay a small fortune, probably close to £2000 with all the various upgrades I have made since I bought it. But today I would get double the cores and 50% more system memory (Ram) for the same price. Unless I paid stupid money for a GPU, I use a VEGA64 that cost me £240 new it was £600 same as it sells for today on eBay - crazy times.
But then I would not buy a new computer at the moment, prices are crazy and there are a few nice features coming soon I am waiting for
- uselessoldman
