More Windows bloatware
Re: More Windows bloatware
Maybe it's just me but I can only seem to update everything (apart from feature updates) or nothing, and I don't like deferring security updates. Feature updates automatically become part of the next monthly update anyway so there's no escaping them.
You'd expect Windows Pro to be more work flow focused instead of pandering to the clickbait and social media generation.
- Dynamic Mike
Longtime Poster - Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
I know I had to dig fairly deeply to set things up as I wanted. As far as I can see, the setting I used is in the Local Group Policy Editor under Local Computer Policy->Computer Configuration->Administrative Templates->Windows Components->Windows Update->Configure Automatic Updates which is enabled and set to 2.
Dynamic Mike wrote:You'd expect Windows Pro to be more work flow focused instead of pandering to the clickbait and social media generation.
The last version of Windows Pro that wasn’t just a superset of the Home version was Windows 2000.
Since then the Home and Pro versions share the same code base with Home having relatively few features disabled.
I have no such issues in my studio -- two PC Audio Labs Rok Boxes running Windows 7 Pro. One is never connected to the Internet and the other connected only briefly if needed to install/authorize new software. They run fast and glitch-free, never suggest an update, use no virus software and have never have. And so far I have found only one program that wouldn't install in Win 7 (Melodyne 5 since the installer refuses to run when it detects Win 7). I have installed dozens of programs claiming to require Win 8 or Win 10, and all work fine.
Win 8 was a disaster and Win 10 has caused many friends and associates a lot of anguish even if it does work OK most of the time. I've run digital audio in my studio since Windows 3.1 (audio for video production at first using Software Audio Workshop) and Win 7 has been by far the most stable, day in and day out. So as "they" say, if it ain't broke, don't fix it!
I realize and understand companies cannot continue to support their programs in Win 7 (I spent decades in software development myself) but also know that almost any program written in a Win 8 or 10 environment will run in Win 7. Since I have a fully functional virtual studio that can handle over a hundred 24-bit audio tracks if needed, and have dozens of synth and sampler emulations and hundreds of audio processors, I'll run these systems as long as I can. I certainly won't ever "upgrade" them to Win 10 or beyond, and will replace them only when I can no longer keep them running!
- Dennis J Wilkins
Poster - Posts: 41 Joined: Fri Aug 05, 2011 12:00 am Location: Colorado USA
Dennis - Studio 12 Below - Colorado USA
For anyone fed up with Windows 10 it's possible to try Linux set up for multi-media here :
http://www.bandshed.net/avlinux/
I would create a bootable USB stick with AVLinux on it and try AVLinux without installing it first to see what you think. Someone who uses Reaper with mostly Reaper plug-ins would find the transition mostly painless I would think. Reaper has also recently added LV2 (the Linux plug-in format) support so there are a lot of Linux plug-ins now available for Reaper.
AVLinux comes with a ton of plug-ins pre-installed. There's also WINE and lin-vst for running Windows plug-ins, which works a lot of the time.
It is different from Windows and it's highly recommended to read the manual before you try it :
http://bandshed.net/pdf/AVL-MXE-User-Manual.pdf
It's possible to get an idea of what AVLinux is like just from the manual.
James Perrett wrote:I know I had to dig fairly deeply to set things up as I wanted.
Thanks for that. I'll give it a go.
- Dynamic Mike
One side effect of the news/weather thing is that I noticed that w10 knows my location. I’m guessing from the ip address or WiFi router name? Anyway there doesn’t seem to be the option to turn off location tracking unless I create an MS account, which I don’t want to do, I only need a local account. Am I missing something? Are they really saying I can only control my privacy options by having an account, thereby giving MS more information about me?
Life is wealth. (John Ruskin)
adrian_k wrote:Am I missing something? Are they really saying I can only control my privacy options by having an account, thereby giving MS more information about me?
We had a power outage last week. It took out 5 or 6 adjoining postcodes & lasted around 6 hours. My wife phoned the SP Energy advice line on her mobile (obviously no power, no wifi), pressed one for an automated helpline and the response knew our address down to the house number! Given we both have location services disabled on our phones & we've never called them before, I still can't figure out how they knew.
The fact that MS (& others like Google) need to know who you are in order to not collect your data just infuriates me. I pay a subscription for a tracker app on my car, I have no problem with that because I had a choice & I opted in.
- Dynamic Mike
adrian_k wrote:One side effect of the news/weather thing is that I noticed that w10 knows my location. I’m guessing from the ip address or WiFi router name?
I can help you there. It's not specific to Microsoft. Everybody who knows the real external IP address of your router knows your rough location.
Try it for yourself: https://whatismyipaddress.com/
VPNs can help by hiding your real address, although they slow down your connection a bit and cost money. You also run the risk of being blocked by some services if your 'apparent' IP address is a known VPN endpoint.
Dynamic Mike wrote:Given we both have location services disabled on our phones & we've never called them before, I still can't figure out how they knew.
Again, not a big tech company thing. Your phone is a location beacon in and of itself. As to exactly how the electric company knew I can't say, but there are any number of reasonable, if speculative, explanations.
Folks worry about big tech, internet tracking, cookies and whatnot but if you have a mobile of any description then even without any data or wifi enabled you're broadcasting your location to the world at large.
Further, if your phone has ever been used to call this-or-that service then they know your number and there are databases that track mobile phone numbers based on the registered address for that number. There are also databases that track the geolocation of your IP address, so if you use wi-fi or data services on your phone for any reason at all then unless you use a VPN service you can be assured that every single website or other remote IP address your phone communicates with knows where you are.
It shouldn't happen, but it does. Mobile phones are wonderful personal tracking devices that almost all civilians carry around willingly and that the secret services of years gone by couldn't have wished for in their wildest and most optimistic dreams.
I don't use a VPN (I don't feel the need to) but if you don't want pretty much everyone to know where you are and what you're accessing it's the only real defence short of binning the mobile and terminating your ISP subscription but it still won't hide your location from the phone providers.
Posts: 9978 Joined: Wed Sep 01, 2004 12:00 am
There's a solution for those worried about the inevitability of what we've bought into for the sake of convenience and revolutionising our lives at all levels:
Throw away/permanently switch-off your phones, tablets and computers and employ a couple of people who will run around with your messages in cleft sticks.
Seriously though guys... Yup! 'They' know who we are, what we're up to and where we live... and they have, to varying degrees, for very many years.
So what's the solution? Fretting and grizzling is easy... how are you going to fix it?
One could argue that society has sacrificed whatever privacy it had for the truly transforming effect that the digital revolution since the 1960s has had on all our lives. There's no going back... and in reality very very few people would want to.
- Mike Stranks
Yep, the key thing is doing a bit of research on the company you're signing up with, check their privacy policies and make your own decisions about what level of trade-off you're happy with.
For my desktop PC, based on the ISP server, it is very rough and can be 100 miles out. Seems to vary at least on a daily basis.
thats half the reason I turned off the weather app - whose weather were they giving me ?
Dynamic Mike wrote:My wife phoned the SP Energy advice line on her mobile (obviously no power, no wifi), pressed one for an automated helpline and the response knew our address down to the house number! Given we both have location services disabled on our phones & we've never called them before, I still can't figure out how they knew.
Almost certainly because the phone number was registered with them as a contact number.
Mike Stranks wrote:One could argue that society has sacrificed whatever privacy it had for the truly transforming effect that the digital revolution since the 1960s has had on all our lives. There's no going back... and in reality very very few people would want to.
That's easy to say if you live in a democracy.
From what I've seen in reality cop shows, if you've turned your phone off in the UK, you're probably hiding a body.
- Dynamic Mike
Hugh Robjohns wrote:Dynamic Mike wrote:My wife phoned the SP Energy advice line on her mobile (obviously no power, no wifi), pressed one for an automated helpline and the response knew our address down to the house number! Given we both have location services disabled on our phones & we've never called them before, I still can't figure out how they knew.
SP Energy just maintain the grid, the account is with E-On and they have my number, not my wife's.
- Dynamic Mike
Dynamic Mike wrote:Mike Stranks wrote:One could argue that society has sacrificed whatever privacy it had for the truly transforming effect that the digital revolution since the 1960s has had on all our lives. There's no going back... and in reality very very few people would want to.
Well in that case, I must be hiding a towns-worth of bodies
- Folderol
Forum Aficionado -
Posts: 20880 Joined: Sat Nov 15, 2008 12:00 am
Folderol wrote:Dynamic Mike wrote:Mike Stranks wrote:One could argue that society has sacrificed whatever privacy it had for the truly transforming effect that the digital revolution since the 1960s has had on all our lives. There's no going back... and in reality very very few people would want to.
You have been doing an awful lot of 'gardening' recently...
- Rich Hanson
Frequent Poster - Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Folderol wrote:Dynamic Mike wrote:From what I've seen in reality cop shows, if you've turned your phone off in the UK, you're probably hiding a body.
That explains your recent re-landscaping of your back garden...
https://www.soundonsound.com/forum/view ... 88#p758188
I hope no-one who attended your recent SOS get together has been reported missing!
https://davylamb.bandcamp.com/
Seeing as you've raised the point...
Most people in 'democracies' have been willing to sacrifice (or are unconcerned about sacrificing) their 'privacy' for the sake of the digital revolution and what it's brought them.
Equally most people in democracies and the governments thereof have chosen to ignore the human rights abuses of the totalitarian regime in China because of all the stuff the Chinese sell us. The situation of the Uighurs and what's being done to them is appalling. Christians who refuse to be part of the state-approved churches face a very, very difficult time. Then there's Hong Kong... Governments and left-leaning individuals murmur their disapproval, but who in this Forum has seriously considered not buying a piece of kit because it's made in China?
The world and globalisation is a complex and messy set-up. The harsh reality is that for all the 'huffin' and puffin'' about bloatware, updates, people knowing my IP address and where my phone is etc etc, nothing will change, because most people don't want it to change. Convenience usual wins-out over Conscience.
- Mike Stranks
Well, I for one will state why I am happy to buy from China.
1. The Uighurs. Before the clampdown by the Chinese authorities, Xinjiang was on the list of countries the UK Foreign Office considered too dangerous to visit. The ISiS affiliated terrorist group ETIP terrorised the area, their intent was to to establish a caliphate. There were cars driven into crowds of people, bombs on trains, unveiled women had their faces slashed in the streets. The authorities chose to deal with this by rounding up people and giving them two choices, assimilate and become productive members of society or get locked up. Now, quite authoritarian, I agree, but how did ‘The West’ deal with terrorism. We illegally invaded Iraq and in the process killed 250,000 innocent civilians, that’s 250,000 ordinary people like you and I, who according to Donald Rumsfeld, were just ‘Collateral damage’ surely one of the most perverse justifications for the slaughter of 250,000+ innocents.
Now, how many Uighur have the Chinese killed.
Peter Snowden is now in exile in Russia, for what crime? For telling the world about the Shooting fish in a barrel murders of innocent Afghanis, at one wedding celebration, 46 celebrants murdered because a US helicopter patrol didn’t want to return to base without being able to claim a kill.
It is claimed that Chinese have used enforced sterilisation on Uighur women, hmmm, then how come the Uighur population has doubled in the last decade. And the woman that made the claim has been described as ‘An attention seeking nutter’ by her sister.
Who made the claims about the ‘treatment of the Uighars’ well that happens to be a group of activists hoping to get political asylum in the West encouraged by some American bloke flogging a book. But, whatever, fact is now the Xinjiang region is now safe and thriving, the area’s population have risen above their circumstances and out of poverty.
As for the alleged imprisonment, well maybe the Chinese have been copying the West again, imprisonment without trial - Abu Grabe? Guantanamo Bay? Extra-ordinary rendition, water boarding, sexual humiliation, beatings(Babu Masah?war crimes (the accusations made against Australian SAS in the alleged murder of Afghani boys) the list goes on and on, napalm, the Mei Lai Massacre etc etc
Hong Kong. During the riots in Hong Kong, the more militant protestors used cross-bows and petrol bombs against the police. It was found the more militant factions were extremely well funded. An American man was recognised as he got onto a plane leaving Hong Kong, he was recognised as one of the individuals seen whipping up anti-government trouble during protests in Venezuela, where money was handed out to protesters to go and cause trouble. This individual has connections with a US ‘pro-democracy’ group, funded in part by………the CIA. Sometime after, it was noticed there was increased activity regarding parcels coming from the USA, these parcels were intercepted by Hong Kong authorities and found to contain guns.
Consider this. During the protests in Hong Kong, where as I said cross-bows and petrol bombs were used, how many protestors died? Now compare that with protestors that died storming the Capitol during Biden’s inauguration, six if I remember rightly.
Riddle me this. The USA is the beacon of democracy. But the USA has 4 times the number of people in jail when compared to China. How many people in the USA have died in police custody, last year I believe the figure to be in the 1000’s I compared the figures for China and they are a fraction of the US figures. During the protests in the USA an Australian journalist lost an eye after being hit by police, an old chap ended up in a coma after being knocked to the ground by police and the crack of his head hitting the pavement was so loud it was like the crack of cannon fire.
Is China a flawless and impeccable country beyond compare, no way, but I think that when we in the West demonise China, well if only we could bottle and sell hypocrisy, if there were a market for it, we would be rich beyond compare.
Some time ago I listened to a discussion between a uk minister and a leading Chinese official. The uk minister called out China in regard to human rights and the Chinese official replied “Your industrial revolution developed over 100 years, we have done the same in a few decades, we are a work in progress, yes we have much to do, but, have you ever tried to feed 1,4 billion people?”
Back to the Uighars. Sometime ago
I was listening to an interview on the BBC World Service, with a member of a Uighar dance troupe that were touring China to spread Uighar culture through the whole nation. The lady was asked “Isn’t that a bit awkward for you, considering the situation in Xinjiang?” The dancer replied
“Not at all, in fact we were enthusiastically welcomed everywhere we’re performed, in fact we look forward to touring again. However, ironically, we do have some trepidation about when return to Xinjiang for our end of tour show. We fear the militant terrorist faction might attack us, but nonetheless we shall not let them stop us as we are proud of our culture and will dance where ever we can”
It occurs to me that China is set to eclipse the USA, and let’s face it, anyone who is top of the heap is reluctant to be de-throned, the USA cannot bomb the Chinese into submission, but as we all know, the pen is mightier than the sword, so a relentless demonisation is unleashed in the media. I went to China to see for myself and found a country nothing like our media describes. And ask myself, since the end of WW2, how many wars have the Chinese started and how many have the West been in. How many George Floyds have there been in China. I think before we criticise China, we need swill our own stables out first. Typed on my Huawei that does not have Google sticking its nose into my business every 5 minutes,
Wow. That is a lot of whataboutism and selective reporting to fit into one post.
None of which addresses Mike's point that we all have moral choices to make all the time and that convenience generally trumps conscience.
There are millions of unfortunate people 'in transit' across the globe. They come from all kinds of ethnic groups, religions and cultural backgrounds - they will all have a different story. The one thing that links them is that they are all escaping dictatorships with the hope of reaching a democracy. The queues into the USA, Canada, UK etc. are long. The ones into North Korea and China and Russia are short. Why is that?
Still, keep up the good work 'One World'. Your efforts will not have gone unnoticed in Zhongnanhai; I'm serious!
- Drongoloid
Poster - Posts: 95 Joined: Fri Jul 08, 2005 12:00 am Location: P for Elterwater
blinddrew wrote:...and that convenience generally trumps conscience.
Inertia rather than convenience is probably more accurate. Most people just don't think about it, like they don't read the T&C when they click "accept".
It's not important yet and when it is important it will be really obvious but it will happen at an individual level and no-one outside the immediate vicinity will know or care.
The Good Lady Wife is less discerning than I am about to whom she assigns rights and privileges in this area. She is constantly inundated with "offers" to relieve her of her hard-earned for spurious reasons. That's enough for me to feel justified in my reluctance.
I'm not a natural tin-foil hat wearer but I have witnessed the abuse of power being facilitated by the abuse of data so it's not an abstract concept for me, just good housekeeping.
- shufflebeat
Jedi Poster - Posts: 10110 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Indeed, it's often said that security and convenience are opposite ends of the same spectrum.
