Behringer C-2 malfunction
Post by Horeli »
Hello!
I recently bought a pair of Behringer C-2 sdc mics to record percussion instruments, but one of them seems to have an issue. When it's plugged to my sound card, it constantly generates low-pitched static noise which renders it completely unusable, while the second one works perfectly fine.
I use cheap t-bone xlr cables from thomann, so my first guess was that one of the cables was damaged, and I replaced it with a new one: same result.
My father then gave me one of his own cables, which he was probably already using back in the 90's and feels pretty sturdy. It seems to have solved the problem to an extent, since the static noise has disappear during recording, but I still get a pop/cracking sound (not sure how it's called) when I (un)plug the cable in the sound card (phantom power is turned off).
So, to summarize, I have 2 microphones and 4 cables. Mic 1 works fine with each cable, but mic 2 only works with one specific cable. Why is that?
My sound card is a UR22mkII.
Sorry in advance if the answer to that question is obvious to you, I'm a total newbie when it comes to recording!
Fixed image link following Wonks' post - JP
Last edited by James Perrett on Sun Dec 15, 2019 11:04 pm, edited 1 time in total.
Horeli
Posts: 3 Joined: Sun Dec 15, 2019 6:32 pm
Re: Behringer C-2 malfunction
This kind of seemingly illogical problem is often due to Chinese XLR connectors which don't quite comply with the dimensions of the Cannon spec, and so don't fit accurately. As a result, the plug moves in the socket and so you get unwanted noise, crackles, splats and so on.
We had a similar problem in a recent Studio SOS where an sE4400 mic produced random crackles and splats. Turned out the cheap XLR cables were the problem... Switched to cables with genuine Neutrik connectors and there were no more problems.
Sometimes, of course, the problem is the XLR socket in the mic or other device, rather than the cable... So some experimentation may be required to find a combination of XLR types that work reliably.
Post by Horeli »
Thanks a lot for your answer!
I'll follow your advice and buy proper xlr cables which will hopefully solve that problem. If it's a mic socket problem -which is very likely according to what you said-, I'll make good use of the warranty.
Horeli
FYI, your image failed to display because you were linking to the web page itself and not the image. If the link doesn't end with .jpg or .png (or other common photo file type extensions), then you won't get a picture.
Post by Tim Gillett »
You didn't say whether the mic is new or used. It's worth checking the actual XLR pins for tarnishing/corrosion. They should be clean, looking presumably like the pins on the good mic.
Tim Gillett
Post by diekpd »
Hey, I had the same issue with these mics, the noise was just awful, the audio was unusable. I interchanged their capsules and that fixed the issue for me, now their working perfectly. I know it's hard to get more expensive equipment, but I won't trust my money and audio to Behringer anymore, I had some of their products and always there's something wrong, it can be any detail. I'd just wait to get more money and buy a quality product from another brand. But that's just my opinion.
diekpd
Posts: 1 Joined: Sun Jun 20, 2021 7:35 pm
Post by Horeli »
Hi there, I forgot about this thread because I eventually bought better gear, but I also solved my issue with the aforementioned mic: I opened it and found an unsoldered component inside, which I soldered back and it solved the static noise issue. It's no big deal since it's a £29 set, but that says a lot about Behringer's quality. Reliability > price!
Have a nice day
Horeli
It's not just Behringer, I had a Tascam DP-02 which had a faulty transport button (can't remember which one), I opened it up and a SMC diode was missing from the board ajacent to the dodgy switch, I soldered on a replacement and it worked fine from then on.
