Using Oeksound Soothe on a mastered track and dithering
I mixed a track and had it mastered and while it doesn't sound that great I noticed that if slapped Soothe on the master it does smoothe it out a bit and remove a bit of the harshness. If I were to render this new track would I have to re-apply any kind of dithering or can I just create a new WAV?
Re: Using Oeksound Soothe on a mastered track and dithering
You only need to apply dithering if/when you reduce the word length.
Posts: 42812 Joined: Fri Jul 25, 2003 12:00 am
Hi Legit!
Perhaps I'm a bit cynical about these 'clever' plug-ins, but in your situation I'd consider this the perfect chance to look at how Soothe altered your mastered track, and then think through how I could achieve the same results during the mix phase.
That way there's a good chance that your next mix might not need Soothe, and you'd be further on your way to mix perfection.
But that's probably just me
Posts: 22121 Joined: Wed Jan 13, 2010 8:44 am
Martin Walker wrote:Hi Legit!
I agree with this! If you get a benefit from putting Soothe over a whole mix, you’d get a whole lot more benefit from fixing the problems at source.
The 'Soothed' track was superior, really removed a level of harshness and sounded nicer and smoother to my ears. There's actually a preset called 'Before You Bounce' I just slapped that on.
What's weird though is that the frequency display shows resonant frequencies reduced down by -6db at varying times across the spectrum low to high. You'd then expect the Soothe track to lose a few final db but it maybe lost 0.1db on the master??
RichardT wrote: ↑Mon Jun 28, 2021 10:08 pmMartin Walker wrote:Hi Legit!
The issue was that a) it had been mastered professionally and b) it's a track I've been endlessly poring over and was sick of mixing.
