replacement speaker for gorilla gb70 bass amp
Post by heavenorlasvegas »
the original speaker in my gorilla amp is going bad. what should i be looking for in a replacement speaker? I have no idea what to look for as far as impedance and wattage go. Please help! :oops:
heavenorlasvegas
Posts: 175 Joined: Mon Feb 22, 2021 2:41 pm
Re: replacement speaker for gorilla gb70 bass amp
At the risk of stating the obvious, are you sure it's the speaker and not the amp?
Posts: 20889 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
yep, thats what the tech told me.
it seems as though the difference between guitar and bass speaker for use in amp is vague. "bass speaker can handle lower frequencies" "dont use bass guitar on a guitar speaker!" etc...
i'm not finding alot of technical data that seperates the two. at least when i search online anyhow..
heavenorlasvegas
Post by resistorman »
There’s some talk here about Gorilla amps:
https://www.talkbass.com/threads/rebuil ... 0.1281945/
resistorman
Posts: 2988 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
It is a cheap 'bass' amp, though with an open back, it really isn't designed for bass.
You can spend more replacing the speaker than the amps worth. You could spend a similar amount getting a better sounding used bass amp.
I believe it's a 12" speaker (you can measure and check) and will probably be 8 ohms (it's a solid state amp so will be either 4 or 8, but 8 will be a safer choice).
The amp is 70W peak, so about a normal 35W rating.
Because of the open back and low power, you'd want something efficient and with a high power rating to provide mechanical robustness.
For a Celestion speaker, I'd go for this
https://www.lean-business.co.uk/eshop/c ... p-330.html
For Eminence
https://www.lean-business.co.uk/eshop/e ... p-864.html
There are slightly cheaper speakers but they have much lower efficiencies and you could end up with a very quiet amp.
12" isn't a popular bass speaker size (compared to 10" or 15"), so there's not a huge choice.
Do not use a guitar speaker. The manufacturers designate speakers for guitar or bass use for various reasons, but the ability to accommodate large speaker travel excursions from bass notes is one of the requisites for bass speakers.
If you really like the amp that much, how about looking for a used 100W 12" or 15" closed or ported bass cab and converting the Gorilla to just a head? Or would that be beyond what you are comfortable with?
Posts: 19209 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Wonks wrote: Thu Jul 15, 2021 11:48 am It is a cheap 'bass' amp, though with an open back, it really isn't designed for bass.
For Eminence
thanks for your reply and useful info. If i upload a soundclip of the offending speaker would you be able to give me your opinion on what you think is wrong with it?
edit: i'm not sure it's even possible to upload sound clips :thumbdown:
heavenorlasvegas
You can’t upload anything here. Always have to host pictures, videos and sound files elsewhere and link.
When a speaker is going bad, a typical thing that happens is the voice coil starts coming apart and expanding in the magnetic structures’ slot. If you take the speaker out and tap the cone gently, it should be a pure tone like a drum. Any overtones is bad. Also, applying equal pressure, gently move the cone in and out, there should be no sound. Rubbing noise is bad. Not likely this is the case with an open back cabinet, but if there’s a foam surround for the cone, sometimes they are rotted.
resistorman
