Gain Stage, Or Normalize ???
Hi
When exporting MIDI to audio, is it recommended to manually set the volume for a track using the instrument channel strip volume fader, such as gain stage? or simply choose to normalize?
- DigitalMusicProduction
Regular - Posts: 241 Joined: Thu Oct 22, 2020 7:00 pm
Re: Gain Stage, Or Normalize ???
Is this a complete composition? Is it being mastered or mixed with other tracks? Normalized audio tends to be very loud so it depends on the application. What are you doing with it?
I see very few reasons to normalise these days. If you need to do something with dynamics then do it and limit the output to set your target level.
No multiple sample libraries, instruments or mix, just solo piano.
I've got nothing technical to add but would only point out that, having just skim-read your signature block in passing I assumed you were involved with a prison rehabilitation programme, until I looked more closely and noticed the comma.
- shufflebeat
Longtime Poster - Posts: 9959 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
shufflebeat wrote: ↑Fri Jul 23, 2021 8:13 am I've got nothing technical to add but would only point out that, having just skim-read your signature block in passing I assumed you were involved with a prison rehabilitation programme, until I looked more closely and noticed the comma.
Well spotted!
Posts: 22430 Joined: Wed Jan 13, 2010 8:44 am
I understand it's possible to apply your own normalization setting as opposed to the default normalize when exporting, however i can't seem to find this anywhere in Logic.
DigitalMusicProduction wrote: ↑Sat Jul 24, 2021 2:15 am I understand it's possible to apply your own normalization setting as opposed to the default normalize when exporting, however i can't seem to find this anywhere in Logic.
When you select BOUNCE, it's in the mixdown window. On the left side are your file types (PCM/WAV; MP3; M4A; Burn to CD), start and end points selected, real/offline mixdown, and then Normalize.
Error
Last edited by DigitalMusicProduction on Sat Jul 24, 2021 3:33 pm, edited 1 time in total.
DigitalMusicProduction wrote: ↑Sat Jul 24, 2021 2:38 pm
Your referring to the default normalize where there is no option to customise the setting. I'm looking for the normalize where you can alter the setting.
Error
Noniiii?
