dBFS Audio Clipping ???
Post by DigitalMusicProduction »
Hi
Is it right to say a peak level of -6dBFS is only recommended so as to leave enough space for effects processing such as mastering, which would take up an extra 3dB of space. Therefore seeing as I'm not applying any FX processing as a Master, i assume it would be safe to raise the peak level to -3dBFS ?
Posts: 241 Joined: Thu Oct 22, 2020 7:00 pm
Music is a universal language that speaks to every person, a euphoria of moods that inspires, convicts and heals
Re: dBFS Audio Clipping ???
Post by DC-Choppah »
If you are talking about peak level BEFORE mastering, then I don't think it matters where you put them as long as they are safely away from the top.
So to keep it simple I just mix where the levels are safely in the green on the master fader with a few yellow peaks.
Best not even think about peak levels until you go to master the whole track.
When mastering a track, raising and lowering of the level is done often by hand, by ear. So you need to leave room in both directions to allow the music level to be adjusted. I don't think it is so much about effects. It is just about being able to shift the level up and down in different sections of the song. There is no reason to push the peaks in the mix up higher before mastering.
If you are talking about the level of the master, then this: https://www.soundonsound.com/techniques ... k-practice
-3dB true peaks (oversamples peaks) are recommended to make the music sound good if it will be converted to mp3.
DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am Location: MD, USA
If this question is connected to your question about normalising... don't normalize to set a pre-mastering level. Just leave plenty of headroom and let the mastering engineer sort it out.
Posts: 21410 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by RichardT »
DigitalMusicProduction wrote: Sat Jul 24, 2021 2:31 am Hi
If you're mastering it yourself, which is what I think you're saying, then aim for something more like a peak of -1 dBFS. If somebody else is mastering it, -3 or lower is fine.
RichardT
Posts: 5979 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Normalising is a blunt tool - 'maximising' is arguably a more benign approach.
When 'normalising', a stray single-sample peak will set the level of your entire audio file. A 'maximising' limiter, set appropriately, can shave off these peaks transparently. Many limiter plug-ins will take inter-sample peaks into consideration too.
But again, do not do any of this to a mix file prior to mastering.
To put this more in perspective what I've done is recorded a track and added some minor FX processing tools such as Imaging and Volocity, which technically would constitute as mastering. After this mastering stage I'm still able to peak at -6dB, therefore I'm assuming i could raise the volume level to -3dB or possibly -1dB, would this be safe without causing any issues, the project is for commercial release.
Read my post again. There is no 'after' the mastering stage - it is the final stage of the process.
Removing the remaining headroom from the mix file is part of 'Mastering' (as is final dynamics processing, EQ, stereo imaging...). Typically you would not do this via normalisation, but if you feel that's the way for you then go ahead.
Hopefully you've considered dithering (or not) in your process, since you do not want to either apply dithering twice, or apply it prior to other processing.
Post by Ben Asaro »
DigitalMusicProduction wrote: Sat Jul 24, 2021 3:22 pm To put this more in perspective what I've done is recorded a track and added some minor FX processing tools such as Imaging and Volocity, which technically would constitute as mastering. After this mastering stage I'm still able to peak at -6dB, therefore I'm assuming i could raise the volume level to -3dB or possibly -1dB, would this be safe without causing any issues, the project is for commercial release.
To being to understand this, take your finished mix and run it through the loudness penalty plugin. I think it's better to see in real time how much various streaming services will adjust the overall level of your mix. That's a great starting point when you're trying to come to grips with peak levels, LUFS, vs overall loudness of the mix in general.
Without knowing anything about the actual piece of music, it's virtually impossible for anyone to say 'look at these levels'; a lot depends on how much you have in what frequency bands, particularly the low frequency band.
And read what the Elf says very carefully, there's a lot more to his advice than you may be aware of.
Ben Asaro
Posts: 3442 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
The Elf wrote: Sat Jul 24, 2021 5:10 pm Read my post again. There is no 'after' the mastering stage - it is the final stage of the process.
You are indisputably correct, my words were wrongly stated, what i meant was, at the final stage of mastering should i be peaking as far as -1dB or less? What is recommended.
What is the destination consumable for your audio?
For streaming services the 'typical' requirement is -1dBTP/-14LUFS, but services differ slightly, so if you have a specific target in mind it might be a good idea to check and match their requirements.
For CD it doesn't really matter so much, but for me that equates to -1dBFS peak. If you want to give rippers the best chance then -3dBFS may be advisable.
So what medium are you 'mastering' for?
As mentioned the album is for commercial retail (online streaming) I've heard about the loudness war's therefore the standard LUFS volume has to be applied, not overly familiar with the concept at this point, so would need some direction as to how loud my final master should be?
If you're aiming for streaming then -1dBFS and -14LUFS are a reasonable set of targets. But you do have be flexible on the latter depending on the material and how it's being presented.
I.e. if you're just uploading single songs at a time that's a reasonable starting point. But if you're creating an album or collection of songs then it makes sense to consider the context of the wider piece; a simple piano ballad probably shouldn't sound as loud as a full-on rock song. There are no rules for this bit though, just preference and experience.
There are plenty of good threads and articles on here about loudness normalisation, it's worth taking a bit of time to properly read up on it.
Posts: 29645 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by RichardT »
For solo piano, you might find a lower LUFS value than -14 sounds better depending on the material, because pianos can have a large dynamic range, and they don’t sound good when compressed or limited - at least if you’re after a more classical sound.
Don’t go lower than -20 LUFS though. I tend to average out at around -16 LUFS.
RichardT
Sounds like it's time to get familiar with the metering your DAW offers and read up on metering generally. As Drew says, there are a number of articles and threads that cover all of this.
The Elf wrote: Mon Jul 26, 2021 11:11 am What is the destination consumable for your audio?
What medium are you 'mastering' for?
As mentioned the project is a solo piano album, (soundtracks) to be be delivered to an online music distribution site, in my case CD Baby. The intention for the album would be for CD, digital downloads and streaming. Online research states streaming would need to be at -14 LUFS, whilst CDs at -8 LUFS.
Assuming this information is accurate? there would need to be two different final master volume outputs, one for CD, digital downloads, and another for streaming, is this correct?
DigitalMusicProduction wrote: Tue Jul 27, 2021 1:57 pm Assuming this information is accurate? there would need to be two different final master volume outputs, one for CD, digital downloads, and another for streaming, is this correct?
Like much of the recording information on the Internet, this isn't necessarily accurate. It may apply in certain circumstances but probably not in your case.
Do you have a way to measure LUFS? If so, how loud is your music currently if you adjust the gain to give you a true peak of -1dBFS? I'm worried that you are chasing LUFS targets that are simply inappropriate for your music.
Posts: 16935 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Mike Stranks »
Post deleted... duplicated what someone else had already said... :)
Yes there is the LUFS meter in Logic, but some piano tracks only peak at -14 LUFS, but float much lower, I've tried raising the gain on the instrument channel strip volume to balance a float at -14 LUFS, but this causes clipping on the dBFS channel strip volume.
All the piano tracks on the album have been mastered to float between -18 and -10dBFS with peaks no higher then -3dBFS, however as mentioned when switching to the LUFS meter the
Tracks float much lower with some only peaking at -14 LUFS, so what to do in this case?
There are different measures of LUFS, momentary, short-term and integrated.
The measure that streaming services are looking at is the integrated measure, this is based on the entire piece of music.
The short-term measure can be useful to look at how your loudest sections compare track to track.
I've yet to find any real use in the momentary measure, personally I ignore it.
Can we assume that you are using the integrated LUFS value for the whole track, rather than the short term or instantaneous LUFS value?
Posts: 19196 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
If the tracks are quiet then don't force them to be louder than they want to be. When people talk about aiming for an integrated level of -14LUFS they are normally talking about contemporary styles of music where there are few dynamics and levels are tightly controlled at all stages of the process.
I get the impression that your music doesn't fit into that category so you can safely ignore most of what you've read on the internet.
Wonks wrote: Wed Jul 28, 2021 1:42 pm Can we assume that you are using the integrated LUFS value for the whole track, rather than the short term or instantaneous LUFS value?
That's an excellent question, as i could of been monitoring the wrong meter? Short term over integrated, new to the concept, will check.
Last edited by DigitalMusicProduction on Wed Jul 28, 2021 2:52 pm, edited 1 time in total.
Error :think:
No harm done.
Where are you once you use the integrated value?
After checking the LUFS loudness meter the integrated level for the piano tracks only rose to -28 LUFS, thats -14 less then the required noise level for streaming service's. However on the instrument channel strip volume the track floats between -18 and -10 dBFS, peaks no higher then -3dBFS, which seems just right for my piano music.
Both volume levels on the piano sample library and Logics instrument channel strip volume are at their maximum levels, so I'm unsure as to how to increase the integrated LUFS level to -14 as all gain levels are at their maximum.
All that said when refering back to the instrument channel strip volume all seems fine when floating between -18 and -10dBFS with peaks no higher then -3dBFS. I assume these volume levels are adequate for CD and digital downloads. The issue lies with the LUFS meter by not being able to raise the tracks to the required -14 LUFS due to all gain levels already being at there maximum.
It's been said tracks that are to loud or to quiet when uploading to streaming service's will either be turned up or down to meet the required -14 LUFS, therefore should i not just upload the album and let the streaming service alter the volume to meet their standard if necessary?
