Audiothingies Micromonsta 2
Re: Audiothingies Micromonsta 2
Post by Ben Asaro »
blinddrew wrote:You can also buy small, angled prisms for this purpose.
Functional and will align Charkra energies at the same time! :D
Ben Asaro
Posts: 3359 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Post by Guest »
Or you can spend hours in Blender swearing and scratching your head and then hours 3d printings something that is 95% there (3 mm out from a snug fit):
Guest
Bravo [ACCOUNT DELETED] - very smart indeed! :clap:8-):thumbup:
Posts: 22436 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Guest »
Thanks. Already started working on version 2, hours of work to do where a wedge of foam cut with a bread knife would do the job just as well.
Guest
[ACCOUNT DELETED] wrote:Thanks. Already started working on version 2, hours of work to do where a wedge of foam cut with a bread knife would do the job just as well.
Ooh! I'd happily pay you to rustle a couple of these up for me? PM me if this appeals.
Posts: 21340 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Guest »
I'll get version 2 sorted tomorrow, I want a tight fit at the back so if you pick up the Micromonsta the stand stays attached, also have the back end come down at 90 degrees to save space and also improve printing time and use less filament by making it a bit slimmer.
Once this is done I can print off a couple for you no problem, pm me with your address.
Guest
Post by Guest »
Version 3, sort of holds the Micromonsta in place:
Guest
Post by Ben Asaro »
Looking good! And a great use for the 3D printer. I only use mine to print terrain for Warhammer! :D
Ben Asaro
Post by Guest »
The printer needs a service though, those ridges never used to be there!
Since getting the bloody thing it has been a never ending series of upgrades and fiddling.
It's a bit like owning an old British car.
Guest
Post by Ben Asaro »
Yup, 3D printers are super fiddly!
Ben Asaro
[ACCOUNT DELETED] wrote: Wed Jun 30, 2021 1:19 pm The printer needs a service though, those ridges never used to be there!
And there I was admiring the textured finish for added grip :headbang:
Post by Guest »
:) If only.
I will add a link to the file on Thingiverse incase anyone wants to print one: https://www.thingiverse.com/thing:4898258
Guest
Just tried to delete this post, but told I'm not allowed?! :(:?
Did you wait too long before deleting? I just deleted a test post here straight after I wrote it.
Posts: 18997 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Wonks wrote: Thu Jul 08, 2021 7:15 pm Did you wait too long before deleting?
Nope - it was about 2 minutes from post to delete.
Post by Kwackman »
Hi Elf,
Just to add- I made a posting here, and closed my browser, then re-opened, located the post and successfully deleted it....
Kwackman
Posts: 3629 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Yeah, I think I sussed it - use the button above, not the tick box in the edit screen.
Agreed. The tick box in the edit window isn't working, but the cross button in the post itself does. I'll flag it up...
Posts: 43394 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Fri Jul 09, 2021 11:00 am Agreed. The tick box in the edit window isn't working, but the cross button in the post itself does. I'll flag it up...
Thanks. Feel free to clean up this thread, if it's felt necessary.
Post by Guest »
So I have messed around with my Micromoster 2 a bit now.
For the money I think it a bit of a steal.
As I said before the MPE implementation is very good, even in Combo mode everything works fine, and mono patches work fine, all very good.
The hardware seems very good, everything seems pretty high quality apart from the terrible screen.
Sounds good to me as well, I am not an Analog purist though, my favourite synths are all digital (apart from the PEK, that is quite nice).
If I was going to change anything though:
The main issue I have is I am always looking for page 2 of the parameters. Limiting everything to four parameters makes sense in a way as you have four knobs and it makes it simple, but you also have an "Alt button", so why not make use of it and have eight parameters where needed.
Having FM oscillators on osc 2 as well as osc 1 would be good.
Another envelope or two would also be welcome.
The Drive parameters only really make sense at their lowest settings, so evening these out would be good.
Overall though highly recommended, anyone that likes synths should get one.
Guest
I'm about to expand my MIDI Designer editor Layout, and I'm aware that there's a standalone and VST editor in progress, so editing may become much easier very soon.
Post by Guest »
Sounds good, I have Midi Designer here so would be interested in that.
I think they did a pretty good design for editing on the box though, considering the number of knobs available!
Guest
In case it's of use to anyone who reads this thread...
Now that the new version of MIDI Designer Pro is out in the wild I can also release an improved version of my MicroMonsta 2 Layout.
This version will accept sys-ex patch dumps from the MM2, allowing any patch to be analysed and edited.
A few things to note:
The patch name and category are for display purposes only - editing these will still have to be achieved on the MM2 itself.
Some of the controls on the Layout will not be 100% accurate to the numeric parameter value in the MM2. This is due to the MM2 and MDP not completely agreeing on the translation of MIDI values. On the whole this shouldn't be wildly inaccurate, but it is important to be aware.
Use at your own risk.
I'll host the Layout in my Dropbox for a while, but hopefully it will make its way to other respositories:
https://www.dropbox.com/s/gqqpux79p7d3w ... igner?dl=0
Post by BillB »
blinddrew wrote: Fri Jun 25, 2021 3:45 pm You can also buy small, angled prisms for this purpose.
Sorry to dig this up from last year, Drew - can you link to any available examples? I am not sure precisely what to search for.
BillB
Posts: 2428 Joined: Mon Apr 07, 2003 12:00 am Location: East Yorkshire
Post by Guest »
I just got an email saying the MM 2 is coming back into stock, just a heads up for anyone interested in getting one.
I'll be getting a second one!
Guest
