CD burning
CD burning
Very last century I know, but when burning a music CD in Music, the process hangs at the "...finishing" stage.
Has CD burning (I'm trying to do it from a playlist in Apple Music, although problems remain even when trying to burn in the finder) been hobbled? I know that the whole optical media thing has largely been abandoned with Apple.
Re: CD burning
Has this happened multiple times, with different brands of discs from different batches? Do you have any other CD burning software to check if it's the drive that is at fault? It could well be that CD burning was not tested in house by Apple in a very long time. You could report the bug to them, although googling that right now it doesn't seem like it's possible for anyone who is not a developer. If I have time I will check it with my own system.
- Tomás Mulcahy
Posts: 2906 Joined: Wed Apr 25, 2001 12:00 am
Re: CD burning
Thanks. I have borrowed my friend's CD/DVD/Bluray burner, and the same thing is happening, with a disc from a different batch and with even an ancient CD-RW. Which suggests to me that it's something awry with the Mac's CD burning abilities, but I am no expert.
It's actually quite hard to find software which can burn an audio CD, from what I've found. I used to have Toast 11 (I think), which worked fine but can't be used under Catalina. I'll keep on hunting around for other burning software.
Re: CD burning
Which Mac & which OS are you using?
Re: CD burning
- Tomás Mulcahy
Re: CD burning
I've used Burn for Mac successfully, and it's free.
https://burn-osx.sourceforge.io
- rockydennis
Regular - Posts: 142 Joined: Sat Nov 03, 2018 5:36 am
Re: CD burning
Tomás Mulcahy wrote: ↑Wed Jul 28, 2021 6:30 pm
Try the demo of this:
https://hofa-plugins.de/en/plugins/cd-b ... -MQAvD_BwE
Many thanks. I have an 2015 iMac with Catalina.
Re: CD burning
rockydennis wrote: ↑Wed Jul 28, 2021 7:02 pm I've used Burn for Mac successfully, and it's free.
Many thanks.
Re: CD burning
Hi Barward, if this is something you will need to do frequently you could probably pickup an old W7 laptop for next to nothing, does not have to be 'Deep Thought'.
I have an HP g6 i3 that burns CD and DVD very well. I use Nero but there are plenty of freebies about (VLC?) . You would of course need to export the file as 16 bit, 44.1kHz .wav.
- Tomás Mulcahy
Re: CD burning
Tomás Mulcahy wrote: ↑Thu Jul 29, 2021 11:18 am
Thanks for this, I did not know CD burning is another of Reaper's features. Is there anything they did not think of?
I burn my own music to CD from Reaper, you have to create regions, and markers, but once you get used to it, it’s fine.
Just go to Render, and select CD CU/BIN
Re: CD burning
ef37a wrote: ↑Thu Jul 29, 2021 8:56 am Hi Barward, if this is something you will need to do frequently you could probably pickup an old W7 laptop for next to nothing, does not have to be 'Deep Thought'.
Hmm, interesting. I have been thinking this very thing, for all the things that a Mac doesn't really seem to do any more.
Thanks for the idea!
Re: CD burning
You can burn CDs on Catalina and Big Sur as well.
- Guest
