Recommend budget "dial-a-tone multi fx" to cover a covers gig
Post by jellyjim »
Hello kind people of the SoS forums
Recommendations most welcome for a cheap/budget (~£200/£250) guitar multi-fx to cover the tones necessary for a mostly 90s indie/rock covers gig. Cure (clean, reverb, chorus), Nirvana (distortion/fuzz), Pixies (gainy) etc.
Not much time or space to fiddle about with a pedal board, like I normally do. Would be great to have some kind of idiot proof box of the sounds I need to stomp between easily. Gig's likely to be cramped, chaotic (lots of guest singers), general madness.
Need to eliminate as many variables as possible!
jellyjim
Posts: 1753 Joined: Wed May 15, 2002 12:00 am Location: uk
Re: Recommend budget "dial-a-tone multi fx" to cover a covers gig
Post by andy cross »
A used Line 6 M9? Picked up a second hand M5 recently, and very happy with the noises it makes.
andy cross
Posts: 192 Joined: Tue Apr 22, 2003 12:00 am Location: Cambridge, England
Post by Andyh 56 »
Something like a Boss ME50 /70? Can either be programmed with pre-sets or can be used manually, with proper twisty knobs. no need for menu diving.
Andyh 56
Posts: 84 Joined: Tue Feb 06, 2007 12:00 am Location: uk
Post by Random Guitarist »
Will you tweak as you play, or do you see yourself as more moving through presets? (just saw the comment about cramped space)
If tweaking then maybe a used Line6 M13 would hits the spot?
The thing with the M13 is you have 12 scenes with up to four pedal emulations active, and each of those four can be a choice of three pre-selected fx. So you could probably set up a fairly good set of flexible pedal boards to cover both the songs you know you are doing and genre friendly pedal sets that you can call up for guests etc.
(Full disclosure I have one for sale at a good price if you did go down that route :D )
Random Guitarist
Posts: 1186 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
I'll offer up my usual suggestion of either Digitech RPxx (50 or 55 are the chip-shop priced end of the range - I prefer the 50) or Zoom MS-50G (which can be 'hacked' to add effects blocks from the entire MS-ish range).
Posts: 21317 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by rockydennis »
A Boss GT-1 is only £179.00 new, cheaper than the ME80 which is £229.00, and its sound engine is from the more expensive GT-100.
https://www.boss.info/us/products/gt-1/
rockydennis
Posts: 142 Joined: Sat Nov 03, 2018 5:36 am
It's hard to go wrong with a Boss GT or ME but I have a Headrush Gigboard, it's a fair bit over budget but the interface is a virtual pedalboard on a touch screen, the sounds are excellent and it's very flexible and programable.
Posts: 22608 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by al_diablo »
I vote for the Digitech RP series
I have the RP360 and it covers a lot of ground. FX, drive, amp and cab sim etc
You can set it in preset mode to switch between sounds or use it as 3 discrete FX on / off per preset
There’s the option of adding an extra control pedal to do both functions at once, I think
Quite a lot of convincing recreations of specific track tones in the presets
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
Post by Dynamic Mike »
I hate it when people post something slightly over budget but the Line 6 Pod Go would be ideal for what you're after. Best ergonomics in my opinion for ease of use and compact form. 4 snapshots for every preset which would be perfect for a covers band whilst keeping it simple on stage.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Post by tea for two »
jellyjim wrote: Fri Jul 30, 2021 1:09 pm Hello kind people of the SOS forums
90s Indie Rock you say Jelly
I been watching vids of this 70squid indie multi fx pedal
Valeton Dapper Indie been considering getting it
https://m.youtube.com/watch?v=7pP-8G0OdXE
tea for two
Post by Music Wolf »
TC Electronic Nova System. Compact, built like a tank, pretty easy to use.
£300 new, should be able to pick one up used for 50-60% of that?
Music Wolf
Posts: 2890 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Post by Dave.P »
I use a Boss GT-001 desktop unit, but the floor mounted version, GT 100 is second hand on the usual places for £250 - £300 region.
Cannot fault the sounds for general use one bit and the variety of tones from clean to dirty is very impressive.
The acoustic sim on this is also good if you need that kind of thing at some point.
Dave.P
Posts: 407 Joined: Thu Sep 14, 2017 5:53 pm Location: Scotland
Post by jellyjim »
Great suggestions!
The Boss GT-1 seems like a good candidate bordering on a no-brainer.
The Internet's awash with user patches so somebody's probably already nailed the tones I need, it's £167 at GAK, GAK is a 15 minute walk away, and ... I won't lose too much money if/when I flip it on eBay, as it's not really the type of fx I'd normally use!
Thanks team. You are exemplary.
jellyjim
I’ll echo Elf, MS70/50, well under budget too.
Cure? They were Yamaha fans I’m sure, signature sounds from "Symphonic" and other chorus programs.
Posts: 21327 Joined: Sat Jul 12, 2003 12:00 am
