DIY Airpiano
Re: DIY Airpiano
Post by Old Plucker »
Just noticed this thread.
So, here's one I made earlier, from 2007 I think.
https://unstablesound.net/skullamin.html
Arduino, ir sensors, leds & Max/MSP for the interaction & sonics
Old Plucker
Posts: 24 Joined: Mon Jan 20, 2003 12:00 am
Re: DIY Airpiano
BJG145 wrote:
Sam Spoons wrote:I'm pretty sure there'll be a DIY shop near you that will cut sheet materials and timber to size, I was going to suggest B&Q.
Right! Now, that's a great idea. (As for joiners workshops...never heard of them. I'll look them up. I have almost an allergy to this stuff. Arpangel, don't worry, it'll be fine...)
Don’t worry, I’m not worrying!
Posts: 21896 Joined: Sat Jul 12, 2003 12:00 am
Re: DIY Airpiano
Post by BJG145 »
The Arduino Mega clone arrived and works a treat. Still waiting on the extra sensors. I think I'll forget the MIDI shield and just go with MIDI over USB with a couple of buttons for presets, and an expression pedal input, like the original.
I've found a local craftsman who's going to build the case. I just ordered a couple of samples of 3mm and 5mm Red Tint 4401 Perspex to test with the sensors and make sure they still work OK.
https://www.perspexsheet.uk/red-tint-4401-perspex/
Do I need to worry about ventilation, I wonder...? I've specified a 2.5cm space to fit the electronics. Slots underneath maybe, or drill holes or something...? Not sure what the additional power requirements might be either, especially if I start adding LEDs. (40 of those square dots in the original to display height; bit of a gimmick, but I might work on it.)
Posts: 8079 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Re: DIY Airpiano
BJG145 wrote:Do I need to worry about ventilation, I wonder...? I've specified a 2.5cm space to fit the electronics. Slots underneath maybe, or drill holes or something...? Not sure what the additional power requirements might be either, especially if I start adding LEDs. (40 of those square dots in the original to display height; bit of a gimmick, but I might work on it.)
It all depends on how much current is being drawn by the electronics, which in turn will determine any temperature rises. Difficult to make a guesstimate methinks.
I should construct the circuit board and run it on a test rig to see how warm it gets, and that should give you a better idea.
As for the LEDs, most red ones will provide a suitable level of illumination with 5mA current, but that still means 200mA in total.
Posts: 22568 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: DIY Airpiano
Post by BJG145 »
Thanks Martin. I just did a bit of Googling on LEDs and Arduino, and it all seems to be about Neopixels now, so I just ordered an eight-way strip to test.
They seem to come in various shapes and sizes and you can daisy-chain them to the Arduino.
All the nice colours will be a bit wasted behind 5mm of red-tinted Perspex, but that seems to be just how they come, and as with the Arduino there are plenty of cheap compatibles.
I don't know the practicalities of handling current and power with Arduino. So far I've only powered individual sensors and LEDs from the board. But with eight of those strips, and eight of the Sharp sensors, I'm thinking I might need to build a separate power circuit...? In the pic of the original Airpiano above it looks like there's an input for a PSU next to the USB socket and this spec sheet mentions 9V power.
Re: DIY Airpiano
Post by BJG145 »
Extra sensors have turned up, along with the perspex samples. It seems to come in standard 3mm or 5mm sizes. Having tried both I think I'll go for the 5mm; it's nice and chunky and isn't going to bend any, so I've passed that request on to the joiner.
Both thicknesses seem to work similarly with the sensors, which is that as long as it's really close it doesn't seem to affect them much, but if you move it just a few mm away from the surface the readings go off. Reflections or something I guess, so I'll just have to make sure they're fitted closely against the lid.
After starting to look at the MIDI over USB library for the Mega it turns out that it doesn't support it natively, but it sounds like there's a workaround using this library so I'll give that a go. Or I could stick to using the MIDI shield, and it would be quite nice to have proper MIDI in/out, though the case won't be deep enough to support the stacked boards so I'd have to wire them together side by side. Should be simple enough, though I'm surprised it's not easier...I'd have thought there would be common adaptors or cables or something for this but I haven't found any yet.
The Neopixels strip has also turned up; these look fun, and fairly straightforward. There are connectors either end for ground and power. One end has "data in" and the other has "data out" and I think you can just wire them up in series then address individual LEDs in the chain using a standard Arduino library. Going to need some solder to connect it up though; it's been a while, and after spending half an hour rummaging around in sheds and drawers I gave up and added it to the eBay list. Besides, I like getting these little envelopes turn up every day or two with components. :D
I've found that the Arduino maxes out at 200mA so it won't be able to power everything. The IR sensors take up to 30mA each, and individual Neopixels can apparently guzzle up to 60mA each on full brightness, though you could get away with a lot less. I'm thinking, maybe 20mA per pixel, 160mA per strip, 1280mA for eight; plus 240mA for the eight sensors gives 1520...so a 5V DC supply rated at 2A ought to do it. I'll do some experimenting with a breadboard.
Re: DIY Airpiano
ULN2803 is your friend. 8x darling transistor that can directly connect to the arduino and has a output current of 500mA per channel, but a total power dissipation of 2.25W. That's not as bad as it looks as even with all devices on at the same time you can draw over 100mA each (they'll only drop a volt or so).
Cheap as err... chips
Here
P.S The outputs can also stand 50V when off.
Posts: 20863 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: DIY Airpiano
Post by BJG145 »
Thanks...I was wondering if I could just power the Sharp IRs and Neopixels in a simple direct way from some other circuit, hit them with 5V, and just use the Arduino to receive the analogue input from the IRs or send data to the Neopixels without needing transistors...? Not sure why the Arduino needs to be able to control the amount of voltage to these devices, if that's what the transistor is for...? (Neopixel brightness is apparently controlled like this. Each LED in a set has its own chip.)
Re: DIY Airpiano
Ah. I think I misunderstood how you were using these. I thought you were using the Arduino outputs to switch the sensors, but it seems you using its USB link as a power source. In which case, a trick I've seen used a number of times is to run a second USB line from the computer used only to provide 5V power.
Re: DIY Airpiano
Post by BJG145 »
First test with the Neopixels strip...
https://youtu.be/s5vbRdKg_os
I'll go with eight of these as height indicators. £3 a pop, easy to program, and as bright as you like - I'm a convert.
Re: DIY Airpiano
Post by BJG145 »
Just had an email to say that the case is finished and ready for collection. Look forward to checking this out...
Re: DIY Airpiano
Really looking forward to seeing this!
Posts: 43664 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: DIY Airpiano
So am I - your collection of controllers must be quite awe-inspiring by now BJG145! 8-)
Re: DIY Airpiano
Post by resistorman »
It would be fun to have something like this that output CV to control my Arbhar!
resistorman
Posts: 2981 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Re: DIY Airpiano
Post by BJG145 »
A while back I sent the IR sensors to a MIDI instrument designer of my acquaintance to tinker with, and he just sent me a link to a video with the latest progress. It's looking quite promising.
Here's a pic of the case I had made up by a local joiner, though it's not the most flattering angle.
Ultimately I'll arrange a proper photoshoot, hire Durham Cathedral or something.
That's Jo Hamilton, of course. There seem to be very few videos of anyone playing one of these, but here's a bit of There It Is.
https://www.youtube.com/watch?v=gG2hFVn ... JoHamilton
Re: DIY Airpiano
Nice to see this progressing :thumbup:
Re: DIY Airpiano
Indeed - controllers come and go, but the one's you're involved with tend to result in rather more expressive possibilities.
Re: DIY Airpiano
Post by BJG145 »
My DIY MIDI partner in crime has been working on pitchbend. I think he's now ready to kick this project out the door and send it back, so I'm hoping to have it ready for action within the next few weeks.
Re: DIY Airpiano
Not really relevant to the thread, but there's something about the design of that mouse that makes it look much older than it is. It's almost a throwback to the 50s or 60s when everything was designed to look like a spaceship! :)
Posts: 29686 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: DIY Airpiano
Post by BJG145 »
...ah, trackball mice. Hate 'em. :tongue:
Whenever I've been called out to a desk with one of those I've always had to nip back and fetch a proper one. Trackballs are only good for one thing.
https://en.wikipedia.org/wiki/Missile_Command
blinddrew wrote: Wed Jul 21, 2021 8:10 pmthere's something about the design of that mouse that makes it look much older than it is. It's almost a throwback to the 50s or 60s when everything was designed to look like a spaceship
(What do you make of Elon's rocket design? It's been described as "anthropological".)
Re: DIY Airpiano
It's a bit Flash/Flesh Gordon isn't it?
Re: DIY Airpiano
Post by ManFromGlass »
Now there’s a combo that will provide hours of fun in space!
Posts: 7852 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Re: DIY Airpiano
Post by BJG145 »
The finished board ready to be returned and fitted inside the case...
Re: DIY Airpiano
Looking good! :clap:
Re: DIY Airpiano
Post by BJG145 »
The guts of my Airpiano, ready to go in the morning post...
(Crosses fingers)
