three way speaker or two way mackie c200
Post by notsobadnotsogood »
i have doubts and don't have possibility to test to see about this
a three way speakers which i dont find reviews for
or
mackie c200 which unfortunately is two way......
i listen at low volume .....15 db
what would someone wich dosent want too good or too bad do
notsobadnotsogood
Posts: 1 Joined: Sun Aug 01, 2021 11:17 am
Re: three way speaker or two way mackie c200
Can you give us a make and model number for the 3 way speakers?
Posts: 16975 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
15dB isn't actually a volume, though you might mean that somewhere on your mixer or amplifier you have 15dB of gain (or is that -15dB of attenuation of the amp dial?).
But basically I assume you don't need a very loud speaker system.
What will you be playing through them, and what is your current set up? Is it recorded music or live music or speech etc? Presumably you already have a power amplifier (as the C200 is a passive speaker).
As you don't seem to be looking for a lot of volume, then are you looking for a good quality of sound? The C200s are towards the lower-cost end of the passive speaker market, so presumably you don't have a huge budget.
Posts: 19204 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by AlecSp »
Twitch...
AlecSp
Posts: 825 Joined: Tue Nov 16, 2004 12:00 am Location: Herts, UK
Your twitch is noted and shared...
Posts: 43667 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Mike Stranks »
Hugh Robjohns wrote: Mon Aug 02, 2021 9:37 am Your twitch is noted and shared...
An old fogie responds...
Eh? :?:
Mike Stranks
Post by Kwackman »
I think it’s similar to a suspected fox being in the henhouse..
Kwackman
Posts: 3685 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Mike Stranks
