External mic pre into babyface pro fs line/instrument input
Would there be deterioration of sound quality by connecting an external mic pre like gap pre73 to the babyface pro fs line/instrument input (analog in 3 and 4)? Im under the impression these are hiZ inputs???
- Guitarking
Regular - Posts: 299 Joined: Sat Jan 09, 2010 12:00 am
Re: External mic pre into babyface pro fs line/instrument input
Inputs 3/4 are indeed unbalanced and high impedance connections.
Ideally, it would be better to use the balanced line 1/2 inputs, but I don't expect you'll have any quality issues hooking up your Gap to inputs 3/4. Just remember that the input max level is +13dBu, and use TS-TS cables to make sure the cold side of the output transformer is grounded. (It may not be if you use TRS-TRS cables)
Posts: 43685 Joined: Fri Jul 25, 2003 12:00 am
Thank you Hugh! Good to hear as I wanted to use input 3 and 4 as two extra inputs for mics (of course with a external mic pre).
Speaking of external mic pres... how about using my Mackie vlz1202 pro as mic pre (of course not with the Neve character...)?
- Guitarking
Guitarking wrote: ↑Mon Aug 23, 2021 5:13 pm Thank you Hugh! Good to hear as I wanted to use input 3 and 4 as two extra inputs for mics (of course with a external mic pre).
Sure. Being unbalanced you may have to take steps top avoid ground loops if you're unlucky, but I suspect it will all work just fine.
Sure. I've always quite liked the Mackie VLZ preamps as a clean, quiet, competent design. I've found it best to take the preamp outputs from the insert point sends which avoids any noise/distortion and headroom limitations associated with the EQ and mix bus circuitry.
Hi Hugh,
Thank you!
I dont fully understand the insert point thing on the mackie. Where to put my cable to route into my babyface?
Thank you!
- Guitarking
In the insert socket for the relevant mic channel on the back panel of the mixer.
On the Mackie, the signal comes out on the T of the TRS socket. You don't need a return, so using a standard TS cable will work. Unbalanced, so there is a ground loop risk.
