Imitating the Final Frontier preset on Valhalla Supermassive ... using hardware
Post by Ben Asaro »
My favourite, and probably most-used, preset on the Valhalla Supermassive reverb is Final Frontier. And I've been thinking, I wonder how close I can get to it using hardware I have lying round the house?
When I hear that preset, I'm picking up a reverb with a lot of density, a stereo widener, modulation, and delay.
As today is a major holiday here in the US, my goal for this morning is to see if I can achieve a similar result to the Supermassive using hardware with my Lyra-8.
I'll post my results regardless of how close I get to the actual thing. :)
(There is also a medium-ish range goal of my next project that I'm starting to plan for as well at play here :D )
Ben Asaro
Posts: 3482 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: Imitating the Final Frontier preset on Valhalla Supermassive ... using hardware
Post by BillB »
Thanks Ben, sounds interesting. When you 'post results', would you also post and example of 'Final Frontier' for comparison, using something like a snare and/or bass drum? I hear/see lots of demos on Youtube where somebody uses a massive washy pad sound, then sticks it through reverb to make it massiver and washier ( :bouncy: ) but it is hard to tell which part of the sound is reverb. A short impulse sound makes that much easier.
BillB
Post by Ben Asaro »
I sure can! I actually use something short and attack-y when I am setting up reverbs for that exact reason: it's really hard to tell what's doing what when you have a dense patch going on and more often than not I'm not happy with the end result.
Here's Mk1 of my board, will see how this goes: https://photos.app.goo.gl/Lyd7VoGyzoemJzxU8
Signal chain: stereo widener > chorus > echo > reverb
I chose the RE-20 because a) it sounds amazing and b) it will allow up to 6 seconds of echo. If that doesn't work, I will replace it with a more clinical delay, but I think that the vibe-y-ness of the RE-20 will work here.
Ben Asaro
Post by Ben Asaro »
Well, that went quicker than I thought it would! :D
The results are very promising! In fact, I prefer the sound of the pedals over the Supermassive. I can understand why, but Supermassive highpasses the effected signal a LOT; the result is more of a pitch shifted reverb. Not a shimmer, but not not a shimmer. :)
My rendition is noticeably darker, probably due to the DECO/RE-20 combination, but I love it!
Here's the comparison clip: https://soundcloud.com/asfollowswriting ... permassive
The order is:
1. Lyra-8 dry
2. Lyra-8 > Supermassive
3. Lyra-8 > pedals
4. Drone creation using Lrya-8 > pedals
Ben Asaro
Post by Ben Asaro »
Spent another 20 minutes comparing and contrasting. My conclusion is that the Supermassive is a super deal. For a free plugin, it's incredibly versatile and powerful (and can do a lot more than just the mega-verbs). It took $1400 in pedals to get close to sound.
However, for my tastes, and the fact that I like to track with effects, the pedal board is more immediate and fun. Plus, I already own the pedals, so why not put them to good use?
Jumping through the clip I made between Supermassive and the pedals, they are quite close at first blush, and I feel like I leveled up in my critical listening and sound design skills. :D
Ben Asaro
Post by BillB »
That’s interesting, thanks, Ben. The Supermassive was smoother, the pedals seemed to introduce a lot of vibrato, presumably the chorus depth and rate was set fairly high.
If they are all stereo in-out, I would be tempted to reverse the pedal order and dial down the chorus to maybe see if you need it at all. I think I read, maybe on this forum, that Tomita ran reverb into delay - I should try it myself. It would be interesting to know what the Mimic does to the delay/reverb sound.
BillB
Post by Ben Asaro »
The DECO doesn’t have a blend, rate, or depth control, and technically isn’t even a chorus, it’s probably closer to tape flanging.
The MIMIQ takes a mono signal and splits it into a hard left/right stereo signal. Perhaps what you are hearing as tremolo is the phasing induced by the MIMIQ?
Either way, I love the sound, and I agree completely that Supermassive is smoother. But .. I prefer the sound of the pedals!
Edit: Oh yes, re listening, I definitely hear the tremolo you are talking about! I think that's a combination of the MIMIQ and DECO, to be honest. As my main concern is the actual final drone, I'm not very concerned about it, but I do wonder if I dial back the flanging on the DECO how it will affect the final sound ... I only included the pitched sound because you asked for something transient and I think it's neat to hear how quickly you can turn pitched notes into droning chaos with the L8!
Ben Asaro
Post by BillB »
Vibrato - Pitch modulation
Tremolo - Amplitude modulation
It’s pitch modulation I am hearing, so most likely is being generated by the Deco. Wobble control?
According to the photo, your Mimic can do stereo in-out, so it could go last... I wonder, by the time your front-end Mimic-generated stereo signal has been through the chorus, delay and reverb, is there anything left of the effect that it provides? My experience of stereo effects (e.g. an obvious one like ping-pong delay) is that they disappear into the reverb mush as you turn up the reverb mix - the stereo effect disappears. Essentially because most cheaper reverbs sum the input to mono before processing to stereo reverb, even though they mix the dry signal to the outputs in stereo. So as the wet mix control increases, any stereo separation in the input signal is lost.
Maybe the Blackhole maintains stereo spread of an input signal? ‘True stereo’ processing?
Still think it is worth trying them in a different order, if only to see how the sound differs :headbang:
BillB
Post by Ben Asaro »
I see what you're saying. The MIMIQ doesn't like complex signals such as you're suggesting, it's primary raison d'etre is for splitting a guitar signal. I've found that it is less effective with mono synths, probably due to the complexity of certain waveforms, so it works much better higher up the chain.
Ben Asaro
Post by Ben Asaro »
BTW, thanks for your insights and opinions, it's appreciated! :D
Ben Asaro
Hmmmm? Damn! this one must have passed me by, looks good, I’ll be downloading it as soon as I’m home, I don’t have a decent delay plug either.
Post by Ben Asaro »
Supermassive is amazing, definitely worth far more than the asking price. :)
Thanks to BillB's input, I will be revisiting the sounds and making some adjustments (particularly the Wobble, which was much higher than I thought; I must have bumped it by accident when setting up).
Ben Asaro
BillB wrote: Mon Sep 06, 2021 11:38 pm Vibrato - Pitch modulation
This has never been helped, by guitar people saying "tremolo arm" as it should be called a vibrato arm.
Arpangel wrote: Wed Sep 08, 2021 8:14 am
Yeah, but having taught guitarists one three-syllable word it was always going to be a challenge to get them to learn another one. ;)
Posts: 29714 Joined: Sun Jul 05, 2015 12:00 am Location: York
blinddrew wrote: Wed Sep 08, 2021 10:11 am
Uh-Oh!
Unlike drummers, at least they can hear you.
:D:silent:
Post by Ben Asaro »
Update: One of the things I love about challenges like this is finding out where I end up. After a lot of tweaking since my last post I’ve ended up with something that, while nothing like the Supermassive, is amazing in its own right. Having the luxury of playing a sequence over the course of days and make very small adjustments to parameters led me down a deep rabbit hole of exploration.
Where I ended was here: Space Echo: gone. The sound is absolutely amazing, but it’s just too noisy for its own good in this context. RV-500: returned. I lowered the Wobble on the DECO and with the Mother-32 playing a bass patch, the tone is AMAZING with the DECO applying chorus.
Final signal flow is basically the same: RV-500 > MIMIQ > DECO > Blackhole.
The sound is spacious and deep with a lot of modulation, love it!
Ben Asaro
Post by BillB »
Sounds great, Ben, I’m happy that you have got something enjoyable out of it, even if it is not what you were originally going for. Just goes to prove that, as long as the experiment is well-conducted, there is no such thing as a ‘failed experiment’, there are just results that may not be what you expected or hoped for.
I finally got my Korg NTS-1, second-hand bargain. I am slightly underwhelmed with the factory reverbs. They are good, but not great. But I just downloaded the HammondEggs ‘Cathedral’ etc reverbs and they sound great on the mini-speaker (“This one goes from very long to infinite”). Will hopefully rig up in the studio tonight/tomorrow and will report back via the ‘NTS-1 as hardware FX’ thread.
BillB
Post by Ben Asaro »
Looking forward to hearing it!
Here's the final version of my effects chain in context. Rough mix/unfinished music caveats apply, https://soundcloud.com/asfollowswriting ... art1-rough
Ben Asaro
Lovin' it Ben! 8-)
And for those who (like me) are not familiar with these effects, here are some photos of them in all their glory:
Posts: 22574 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by BillB »
Nice one, Ben, I enjoyed that. Very atmospheric and moody.
Was the RV-500 on a reverb setting?
BillB
Post by Ben Asaro »
BillB wrote: Sat Sep 18, 2021 11:33 pm Nice one, Ben, I enjoyed that. Very atmospheric and moody.
I have reverbs within reverbs lol. Here's the setup:
The RV-500 is in Dual Mode. The A algorithm is a room reverb and dotted 8th delay. The B algorithm is a dual reverb of room and plate as well as a quarter note delay.
From there it goes into the MIMIQ and gets doubled.
After the MIMIQ is the DECO for tape saturation and chorus.
Finally is the Blackhole.
Ben Asaro
