Anyone finding Reaper 6 a bit sluggish?
Post by Mixedup »
As above. Thought I'd try it out to see what I was missing. I'm on Mojave, on a MacBook Pro, a setup which has worked fine with previous versions. But the v6 is glitching a lot — graphically, with as much as a second pause to catch up with mouse movements making it almost unusable. Equally interested in experiences on Win or other Mac OS, hence posting here...
Mixedup
Posts: 4557 Joined: Wed Sep 03, 2003 12:00 am Location: Cambridgeshire, UK
Re: Anyone finding Reaper 6 a bit sluggish?
I've been running 6.29 on Win 10 without any obvious problems (and definitely no sluggishness) for a while, and am just downloading 6.36 now...
Posts: 43659 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I always update as and when any notifications come in, so am currently on 6.36 on Windows 7.
No slowdowns noticed at all, and I'm using Reaper on a daily basis.
Posts: 22566 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Lophophora »
Same as Martin Walker here.
Lophophora
Posts: 85 Joined: Thu Sep 15, 2016 2:28 pm Location: Singapore
Jean-Marc
SoundWise Mastering
Another 6.36 on Windows user here with no problems. Don't recall any glitching with the earlier versions of 6 either.
Posts: 29668 Joined: Sun Jul 05, 2015 12:00 am Location: York
I upgraded to 6.36 a few days ago (from 6.29) a few days ago and haven't noticed any issues. However, I've noticed in the past that it can get very slow if you are using a few convolution reverbs at high sample rates with large multitrack sessions of 24 tracks or more.
Posts: 16968 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by BWC »
James Perrett wrote: Tue Sep 21, 2021 12:43 am However, I've noticed in the past that it can get very slow if you are using a few convolution reverbs at high sample rates with large multitrack sessions of 24 tracks or more.
...compared to doing the same with other DAWs using the same machine?
BWC
BWC
Post by Zukan »
AA plugs Matt or general sluggishness?
Zukan
1-2-1 Tuition
Zukan wrote: Tue Sep 21, 2021 8:32 am AA plugs Matt or general sluggishness?
Yes, check your plugs.
I’m on the latest version, always update, I’m running it on Mac High Sierra, and Win 10, no problems.
Posts: 21868 Joined: Sat Jul 12, 2003 12:00 am
Post by Mixedup »
Thanks guys and gals. Latest version of Reaper. No AA or convo plugins. Only four audio tracks in the session. Could be plug-in related, though I've installed nothing new and the session was created and working fine in the latest v5. If/when I figure it out I'll report back but obvs don't want to name/shame plug-ins here if they're not at fault!
Mixedup
BWC wrote: Tue Sep 21, 2021 1:08 am
I expect other DAWs would be as bad or worse. It was surprising how much difference doubling the sampling rate made.
Post by BWC »
James Perrett wrote: Tue Sep 21, 2021 4:29 pm
OK, I'd be disappointed to hear of Reaper under-performing with such things, relative to the others, as I'm generally so impressed with Reaper's capabilities.
James Perrett wrote: Tue Sep 21, 2021 12:43 am It was surprising how much difference doubling the sampling rate made.
Makes sense, that's a lot of extra work for the old central calculator.
BWC
BWC
