Has anyone any experience with using a 1.5 meter usb 3.0 male-female extension for relocating the audio interface farther away from the computer?
I use the interface for both inputs and outputs (hybrid audio mixing).
I just need to place the interface closer to the rack gear, for direct patching into compressors before hitting the mixing console. Problem is, my computer and rack are on opposite sides of myself, hence the need for a 1.5m usb extender.
Any insight on these digital cables would be a great help.
Extra long usb for audio interface?
- wearashirt
Regular -
Posts: 130 Joined: Wed Jun 09, 2021 4:18 am
Re: Extra long usb for audio interface?
In most cases, the maximum cable length for a reliable USB connection is 5 metres, so as long as your extension plus the original cable don't add up to more than this you should be fine.
Posts: 22575 Joined: Wed Jan 13, 2010 8:44 am
My NI KA6 has a suggested maximum cable length of 3mtr and is indeed supplied with a good quality cable of that length. I did however have need to run at the maximum 5mtr as per Mr W. I bought two different cables and found one was solid and the other 'flaky'.
Instead of an extension with its slight but unavoidable 'kink' in the transmission, I suggest a single cable of correct length and of the best quality you can find.
There are 'active' USB extensions. I have not tried them and know of no one that has for an AI which are fussy things, e.g. most do not like hubs.
Lindy always used to be a source of good quality cables - they have a shop on Ebay or you can order direct. I've used 5m USB2 cables for quite a while now for DVD writers, USB sticks, keyboards and mice with no problems but haven't used ones that long for an audio interface yet.
Martin Walker wrote: ↑Tue Sep 21, 2021 5:10 pm In most cases, the maximum cable length for a reliable USB connection is 5 metres, so as long as your extension plus the original cable don't add up to more than this you should be fine.
^ this. If you need to go further there are optical USB cables available, eg by Corning, but they don't come cheap.
I've used 5m cables regularly for a variety of purposes with no issues. Given the low cost, to be doubly safe I'd recommend using a longer USB cable rather than combining a shorter one with an extension though.
1.5m should be no problem at all.
Posts: 9977 Joined: Wed Sep 01, 2004 12:00 am
My AXE I/O interface is currently connected with one of these: https://www.amazon.com/AmazonBasics-USB ... 00NH13DV2/ 3m and working great. I would also agree that a single cable of the required length is a better idea than an extension.
BWC
Mixedup wrote: ↑Tue Sep 21, 2021 9:01 pmMartin Walker wrote: ↑Tue Sep 21, 2021 5:10 pm In most cases, the maximum cable length for a reliable USB connection is 5 metres, so as long as your extension plus the original cable don't add up to more than this you should be fine.
https://www.amazon.co.uk/Network-Adapte ... B074CDL78M
Claimed ^ to be USB 3 over CAT5e but seems a bit cheap to me? There are innumerable such products for USB 2.0.
ef37a wrote: ↑Wed Sep 22, 2021 11:10 amhttps://www.amazon.co.uk/Network-Adapte ... B074CDL78M
This isn't USB over CAT5e, just a network interface that connects to the host using USB. It's effectively a dongle that turns a USB port into an RJ45 Ethernet interface.
Eddy Deegan wrote: ↑Wed Sep 22, 2021 11:38 amef37a wrote: ↑Wed Sep 22, 2021 11:10 amhttps://www.amazon.co.uk/Network-Adapte ... B074CDL78M
Ah so! I was trawling through page after page and pounced when I saw "USB3.0"
"Always read the small print"
Thanks everyone. Advice I've taken from your answers is:
1. Use one single USB cable instead of an extension - excellent suggestion.
2. I've also bumped up the length to 3.0m, just shy of the 5-m length everyone seems to agree on. Hopefully this is a way of not buying twice later on. (Like, when I finally spring to get that 32 input console!)
Turns out I can only make do with USB 2.0 of such a USB-A to Printer-USB cable that we use for most of our interfacaes. USB 3.0 of the same type of interconnect apparently is a different shape.
- wearashirt
Regular -
wearashirt wrote: ↑Fri Sep 24, 2021 1:49 pm Thanks everyone. Advice I've taken from your answers is:
Yes, USB 3.0 is a bit of a 'zoo'. The 'A' plug on a USB 2.0 cable will work on a Blue USB 3.0 A port but will not fit a 'C' port. The 'B' end will not fit a 2.0 B port. Then there is a rarer 'thin' USB3.0 plug. I have one on an external drive. PITA.
I had a phone with a C port (till I dropped it in the bath!) and was impressed with its ruggedness and the fact that you cannot pug it in the wrong way. The sooner ALL kit is USB C the better!
