Has anyone out there used a Mix Pre with GarageBand on iPad ?
I am not having any luck getting anything to happen. I think ordinarily when you connect an audio interface, it is detected and you are asked if you want to switch on monitoring. iPad is a newish model with USB-c any advice would be good. I wonder if it is to do with the input and output settings ?
Mix Pre & Garageband
Re: Mix Pre & Garageband
Depending on the model of mix pre you have - you might need to change the USB setting on the unit.
Details here:
https://youtu.be/QBMBF0jD4pg
Details here:
