New synth challenge -- the performance drone recording!
Post by Ben Asaro »
Well, I guess this will end up being my last synth challenge of the year as it's almost October and I'm finishing up my previous challenge (scoring a silent film) and I have no idea how long it will take to pull the next one off!
This is going be a bit rambly because I'm just starting to think seriously about how I'm going to do this and am already coming up with various obstacles and mental knots to untangle. :)
The goal of my next challenge is to record in real time a performance using just the Lyra-8 and Subharmonicon. And maybe a kick drum or some other minimal percussion? Not sure.
I have my effects chain already done (discussed in another thread) and a BOSS RC-5 looper. My goal is to have the output of the looper going straight into my interface and press record. What it gets is what it gets, so I'm expecting this to take days or weeks to get a performance I can live with. As I am off the last two weeks of November, that's my target to work on it in earnest.
The first challenge I was met with was: how long will this be? And will I have any control over how long it will take to get it 'right', or at least 'good'? My guess is that this piece will end up being quite long, probably between 20-30 minutes total. That doesn't worry me, my pieces tend to be very long anyway.
But how to approach this with the looper had me stumped for a few hours today. My original idea was to record 30 minutes of blank space and then overdub layers. However that would lead to the piece being hours long! I kept trimming and trimming and I think I've settled on a length of 1 minute for the track. If I start with a 1-minute long blank, I can then get the first drone layer up, overdub, and then 'perform' each subsequent layer as I improvise, record, and layer again and again.
The idea is, in theory, when I have a dense enough bed of layers, I can improvise a 'lead' layer of the Subharmonicon over the rest. I'm pretty happy with this approach and it looks pretty sound. I'm sure that during the coming weeks this will be modified and tweaked to match the real world constraints of doing this all live -- to say nothing of becoming proficient in improvising with this setup in the first instance!
Overall, I'm excited to start documenting the project here and am looking forward to recording something as a 100% live performance.
Ben Asaro
Posts: 3391 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: New synth challenge -- the performance drone recording!
Post by Bob Bickerton »
Probably of no use, but I've finally figured out a way off creating rather nice drones on my harp (the sort with strings) using a Gamechanger Plus Pedal https://www.gamechangeraudio.com/pluspedal/.
You can layer up several loops on top of each other very quickly (if that's what you want) and you can run it in 'wet' mode, which might suit your application. It has it's own effects loop (for the looped sound) into which I patch an Eventide Blackhole pedal to provide some movement to the drone.
This has seriously revolutionised what I can achieve with the harp live and I have heaps of control over how quickly the recorded loop fades in and fades out.
Just a thought.
Bob Bickerton
Posts: 5588 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Ben Asaro »
Yes, it’s an a beautiful pedal, I’ve looked into it before. Can it store more than one loop at a time?
Ben Asaro
My experience has been that dedicated loopers aren’t good for me, regarding creating drones, I find delays much more flexible, and things very slowly fade out, allowing new layers to be added, hence more variation over long periods of time, Frippertronics style.
Also, you may find that adding a "lead" over the top, will end up superfluous and just not needed.
I think a large number of oscillators, through processing, gives enormous scope for variation.
Posts: 21573 Joined: Sat Jul 12, 2003 12:00 am
...and I use a combination of long delays *and* loops. The Enso looper has a looping mode that also lets it fade off like a delay, so you get the best of both worlds.
Posts: 21369 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
The Elf wrote: Fri Oct 01, 2021 8:27 am ...and I use a combination of long delays *and* loops. The Enso looper has a looping mode that also lets it fade off like a delay, so you get the best of both worlds.
I’ve been looking for something like that for a long time, I’ll check it out.
Uh-Oh, just found out it’s software.
Arpangel wrote: Fri Oct 01, 2021 8:52 am
Yup - no hardware equivalent I'm aware of. Closest I can get is with my Line 6 Helix that will loop and delay at the same time.
The Helix will delay-fade over minutes and (thanks to me hassling Line 6!) now stays in time with the tap tempo light!
Ben Asaro wrote: Fri Oct 01, 2021 2:10 am Yes, it’s an a beautiful pedal, I’ve looked into it before. Can it store more than one loop at a time?
Yes, in group mode you can layer up lots of loops. But maybe think of it as a sampler rather than a looper. It samples a short section of audio when you press down the pedal and, I assume, cross fades the sample which it then loops. Slightly different approach, not so good for the attack on short notes, but manages tails and sustained notes really well.
Last edited by Bob Bickerton on Fri Oct 01, 2021 10:51 am, edited 1 time in total.
Bob Bickerton
The Elf wrote: Fri Oct 01, 2021 9:33 am
Recently bought a Electro Harmonix 720 Stereo Looper (https://www.ehx.com/products/720/) which does exactly that. You can programme up to 60 seconds of fade out - best looper pedal I’ve come across yet!
Bob Bickerton
Post by Ben Asaro »
Arpangel wrote: Fri Oct 01, 2021 8:00 am My experience has been that dedicated loopers aren’t good for me, regarding creating drones, I find delays much more flexible, and things very slowly fade out, allowing new layers to be added, hence more variation over long periods of time, Frippertronics style.
Neat! This will be much less of an ambient/Frippertronics/musique concrete thing and closer to pure drone music, though not as dry as most drone albums.
Ben Asaro
Post by Ben Asaro »
Bob Bickerton wrote: Fri Oct 01, 2021 10:16 am
The BOSS RC-5 has programmable fade in and fade out as well.
Ben Asaro
Post by Ben Asaro »
Bob Bickerton wrote: Fri Oct 01, 2021 10:10 am
Thanks for the extra info, Bob! Yes, it looks like a granular sampler, very cool, and I do actually want one, but I’m not sure how relevant it would be to this particular project. Still, you never know, GAS has a weird way of causing new things to show up! :D
Ben Asaro
Ooh! Well, I never knew fade was an option on other loopers. Just goes to show ya!
I have my fade set for several minutes on my Helix. 60 seconds wouldn't cut it for me. I need time to think while I'm scratching around in my Mellotron for the next sound!
The Elf wrote: Fri Oct 01, 2021 5:35 pm Ooh! Well, I never knew fade was an option on other loopers. Just goes to show ya!
Ah, I think I’d already be drinking beer in the pub by the time your looper faded :D
Bob Bickerton
Post by IAA »
Ben your approach I find very inspirational. I’ve followed your personal musical “challenges “ with interest. I’m working hard(ish) on my first release but it’s hard work and I need to balance it with something more improvisational. Your ideas got me thinking that I might work on a similar idea, but just use live loops in logic (never used them before) and my hardware synths to create one piece of “live” music and record that. Maybe even film it and premier it on YouTube......even if no one watches it’s the preparation and execution that would fire me up I’m sure. :D
IAA
Posts: 1571 Joined: Fri Dec 28, 2007 12:00 am Location: York
Post by Ben Asaro »
IAA wrote: Sat Oct 02, 2021 9:13 am
Wow, thanks for the kind words.
That sounds like a wonderful idea, I hope you get some inspiration out of the process! A modern sequencer, even if preloaded, can still be used as a tool for improvisation.
As time goes on I find myself being less and less interested in making music that’s the product of well-rehearsed layers and more of a document of a single point in time. In my case it tends to pieces that are minimalist and not overly complex due to the fact that I have very little facility with playing keys.
I’m looking forward to what you come up with!
Ben Asaro
Post by Ben Asaro »
Began sketching the basic structure:
Ben Asaro
Love that title!!! :clap:8-):shocked:
Posts: 22469 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Ben Asaro »
Some good news on all fronts!
1. The new album is in the can, mixed and awaiting mastering.
2. The accompanying film score is 50% complete and should be right on schedule for a late October completion date.
3. I was able to conduct my first minor experiment for the drone performance: syncing the SubH to the RC-5. I’m happy to announce that it went down a treat: simply connected a 3.5mm TRS cable between the two units and they synced up perfectly!
I am still holding off any real work until the film score is done, but this setup means that I won’t have to convert MIDI clock to analogue sync.
Ben Asaro
Post by Ben Asaro »
Preparation has officially begun for the next challenge!
I put together a small rack so I can manage signal flow and get some tonal control over the Lyra-8. The Lyra-8 will go through the PE-15 and then into the return of the Alpha Channel. The Subharmonicon will go straight into the SSL's input and use the channel strip's EQ.
I still haven't sorted out the panning issue yet, but I have a couple of ideas.
Ben Asaro
Post by Ben Asaro »
Version 1 of the score for the first movement is done. Hope to start testing this week!
Ben Asaro
Post by Ben Asaro »
Film score is officially done, starting pre production this week!
Ben Asaro
Post by Ben Asaro »
Finally having an hour to work on something new today, I took the recently-liberated SubH and connected it to the RC-5 and then straight into my interface.
In the spirit of this project, I pressed record in Logic before I had done *anything* on the SubH, and just started exploring, recording the entire process in real time. After four layers of loops I pressed stop.
It's hard to express the exhilaration doing something like this creates; this is as raw as it gets to the actual creation of sound, no editing, no filtering. I must say, I LOVE WORKING THIS WAY. Being creative on demand can be so challenging to achieve, and only by stepping back and analyzing what you did will you know if it will be a keeper.
My first jam is just that -- just a jam testing out the proof of concept and a test to see if I could do it: if I could layer multiple improvised layers in real time without it sounding like a load of crap. :D
I also realized that using just the SubH and the looper, you have so much as your disposal (except polyphony), I don't even know if I would use both sides! I guess as I keep practicing I will feel less overwhelmed with each successive jam session.
https://drive.google.com/file/d/1gDZhIs ... sp=sharing
Ben Asaro
Post by Ben Asaro »
Four jams in and I feel as if I'm starting to get the hang of the SubH as an improvisational instrument, as well as figuring out how to use the looper. I introduced the SSL into the signal chain last night and also realized that I needed to rearrange/reconfigure my effects to work with this setup, it was still very much set up for the Berlin School rig. The reorg worked great, I now have the signal chain going Sub H > SSL > DECO > RV-500 > Blackhole > RC-5.
I had the levels entirely too hot for the rig last night and I got instant crunch/feedback, but I kept the jam going because that's the point! :D
Today I course corrected the levels so that any feedback will be deliberately introduced. :D:headbang:
I must say, the RC-5 is a pristine unit, it records in 32bit and the sound is very transparent.
I still haven't figured out if there's a way to get the RC-5 to end less abruptly, but I'm not worrying about that now. I think I have one, possibly two, more jams and then I can introduce the Lyra-8 into the setup. That will automatically things both more interesting and more complex.
For anyone interested in hearing the nascent sounds, https://drive.google.com/file/d/16oxyTD ... sp=sharing
Ben Asaro
Some extremely encouraging results there Ben; it sounds great to me.
I have a looper which I acquired relatively recently but have not used yet. In light of this successful experiment of yours I'll be having a go with looping the Moog stack as soon as I get a free couple of hours to set it up on the living room table (being without a working studio is arduous, but not long to go now!)
Lovely stuff, thanks for sharing! :clap:
Posts: 9907 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
