Just got the Korg Prophecy out of storage ...
Re: Just got the Korg Prophecy out of storage ...
Post by jaminem »
Nostalgia created by this thread, Couple of Whiskeys, eBay, Credit Card.
I now own a Prophecy again.
I blame you for this, contributors to this thread...
Also..
Excited, yeah the plugin was a bit cheaper and wont break, but it doesn't have the log controller....
jaminem
Posts: 1535 Joined: Mon Mar 19, 2001 12:00 am
Post by pilot-wave »
Replaced my OSCar with a Prophecy in the late 90s in a bid to obtain greater fine control over programming articulacy and dynamics, which it certainly gave, though its overall, relatively 'grey', tone in comparison to its richer, more colourful, sounding predecessor was a bit of a disappointment.
But... I think it still shines within a mix having a real edge in carving out those more graphic elements, whatever the style of music... I was particularly fond of its use in some of those more 'out there' 90s industrial Drum & Bass tracks.
Recently dug it out of storage to fill in the temporary role of modular synth controller after my alpha Juno 2 died. What's striking, all over again, is the depth of programming sophistication and modulation control over that engine. In those terms, aside from the tricky UI, it's quite reminiscent of a much later Dave Smith Evolver keys or even Pro 2/3.
pilot-wave
Posts: 131 Joined: Tue Sep 06, 2005 12:00 am Location: Gloucestershire: UK
The Red Bladder wrote: Fri Oct 08, 2021 6:22 pm Prophecy, Z1, Triton, Karma, MS20, MS2000 all in constant use.
So no Roland then? ;-):beamup:
Posts: 4765 Joined: Mon Jul 21, 2003 11:00 pm Location: A studio deep in the fenlands of Cambridgeshire, UK
pilot-wave wrote: Fri Oct 15, 2021 5:44 pm What's striking, all over again, is the depth of programming sophistication and modulation control over that engine. In those terms, aside from the tricky UI, .
I came to the Prophecy owning a DX & analogue monosynth so I saw it as a subdued but modernly complex monosynth.
I found the UI easy but perhaps tedious. There were good shortcuts like presets for each module - eg the envelope genererator had all the usual parameters or for a "quick start" I could select from organ, piano,pluck,etc - preset envelopes.
pilot-wave wrote: Fri Oct 15, 2021 5:44 pm I was particularly fond of its use in some of those more 'out there' 90s industrial Drum & Bass tracks.
I think the Prodigys FAT OF THE LAND is a Prophecy album, there may be more definitive examples but you can certainly play "spot the preset" !
Posts: 4819 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
N i g e l wrote: Fri Oct 15, 2021 7:08 pm
... I think the Prodigys FAT OF THE LAND is a Prophecy album, there may be more definitive examples but you can certainly play "spot the preset" !
Ha - yes! Not being overly familiar with that album, I've always misremembered it as being an example of a Moog Prodigy fest due to the band's name and references to its use in their earlier days. Having just now listened to the first track the Prophecy is clearly flaunting itself.
Once it's out of its temporary modular MIDI controller duties, despite having a Pro 2 and MEK sitting here, I really must, after years of storage dormancy, re-investigate that Prophecy engine properly again.
pilot-wave
Post by resistorman »
Interestingly, this just showed up in my inbox:
Korg Prophecy Editor Now Available
https://coffeeshopped.com/2021/10/korg- ... -available
resistorman
Posts: 2979 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
