Unusual hardware synth recommendation...
Re: Unusual hardware synth recommendation...
Post by Djberwick »
I could at a pinch go up to £500 - for that it seems that the main contenders would be Make Noise O-Coast and the Behringer 2600?...
Djberwick
Posts: 56 Joined: Thu Oct 24, 2019 5:57 pm
Post by Ben Asaro »
I will not recommend Behringer for personal reasons: I think Uli and his company are mercenary and unethical.
The 0-coast is fantastic and you can create a 0-series ecosystem based off of it.
A used Mother-32 or perhaps Subharmonicon should be on your audition list, depending on how experimental you want to get.
In the head-to-head semi modular shootout, the contenders will be the M32, 0-Coast, and SubH, in my opinion. I can't speak to the Neutron.
I personally think that the SubH gives the most bang for the buck: 2-6 oscillators, dedicated audio outputs for each, MIDI and analogue sync, fantastic sound, and an architecture that invites exploration. You can use it as a simple 2-voice synth or something far more experimental.
Ben Asaro
Posts: 2804 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Post by Djberwick »
Just checked out the SubH and that's defo out of my budget unfortunately. However, I found this demo of the Mother-32:
https://www.youtube.com/watch?v=NF3lhhiknfY
Assuming this is just the synth doing this (excluding the reverb) I am absolutely blown-away. I haven't heard the O-Coast doing anything like this in the demos - maybe it can though.
Djberwick
Post by Ben Asaro »
They are very different synths with different aesthetics and architecture. My original goal when I got my M32 was to get three of them. I fell down the modular rabbit hole instead (I have approximately a 10-voice eurorack system) and ended up with a SubH at the tail end.
If I were to start all over again, I would probably stick with my original plan!
Ben Asaro
Djberwick wrote: Thu Oct 14, 2021 1:44 pm Just checked out the SubH and that's defo out of my budget unfortunately. However, I found this demo of the Mother-32:
I've not seen that one before - it's an excellent demo! It's not quite a self-generating patch though; it's a repeating 32-note sequence played with random timing changes.
The Mother-32 is a surprisingly capable synth but it's sometimes not the easiest box of tricks to use, in part due to the various combinations of button presses required to effectively use the sequencer.
It has a single oscillator but there are patch outputs for sawtooth and pulse from that oscillator that can be accessed simultaneously, plus you can sort-of get the filter to track pitch as well.
It's definitely a synth that rewards persistence and time spent learning how to use it, it can sound fantastic and it plays very well with other semi-modular and euro-rack kit also.
I love mine, and have it in a 3-tier rack with a SubHarmonicon and a DFAM alongside it.
The Sound On Sound review of the Mother-32 is here:
https://www.soundonsound.com/reviews/moog-mother-32
Posts: 9551 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by Ben Asaro »
Ha, Eddy took the words right out of my mouth!
I was going to say: if you want sounds that are uniquely your own, you're looking in the right direction. But it's at the cost of time and effort, and quite a bit of both (you can check out my synth challenges for more detailed look at the singing highs and crushing lows of this pursuit).
The only other thing I will add is that if you are looking for absolute rock solid tuning, stay far away from modular and semi modular!
Ben Asaro
Post by Djberwick »
No worries, I've spent a lot of time with the Wavestate and enjoy deep crafting sounds/sequences. Not worried about tuning either, adds to the charm!
Seems like you pay a premium for the "Moog" name, but they always come with quality.
Djberwick
Ben Asaro wrote: Thu Oct 14, 2021 1:35 pm I will not recommend Behringer for personal reasons: I think Uli and his company are mercenary and unethical.
Ben is right about the O Coast, it’s pick of the bunch for me, simply, because it doesn’t really have a sound, it can be very conventional, or very, very way out, the Behringer 2600 is a lovely synth, I thought about it, but it’s still an analogue mono synth, basically, with a very stereotypical sound, that’s hard to get away from, I’ve got the Arturia 2600, and it’s fantastic, it does all the things for me that the original 2600 doesn’t, but it’s nothing like the Behringer, it’s very hard to get away from "that sound" which is very good, but not if you don’t want it all the time!
Some of my favourite sounds ever I’ve made on the Arturia 2600, but I’d never be able to get them on the original, or the Berry.
If soft synths were an option, well, the world is your oyster, and if you’ve got an iOS device, Animoog, what more can I say, how much is that? $30?
Posts: 19417 Joined: Sat Jul 12, 2003 12:00 am
Post by Djberwick »
The soft synth approach would definitely be a lot lot cheaper but my DAW is already stacked up with VSTs for the orchestral instruments, plus really keen to get into the analogue area by merging the two.
Thanks for everyone's suggestions and demystifying this for me!
Djberwick
Post by Ben Asaro »
Fortunately, there are lots of us here who are using hybrid systems and sync'ing hardware synths, software synths, and DAWs!
Ben Asaro
Post by Djberwick »
My current thinking is that I'll get a Mother 32 first then at a later date get an 0-Coast. From what I've heard no doubt both are top notch but I think coming from my lack of experience the Moog might be better to start off with. I haven't really heard many demos online for the 0-Coast that I like, whereas there's plenty for the Mother...but sounds like it has a lot of scope (maybe more than the M32) to create a wider palette of sounds....
Djberwick
Post by Ben Asaro »
You literally cannot go wrong starting with a Mother-32, that was the synth that launched 10,000 modular addicts. :D
Just make sure that you are running the latest firmware on it, it greatly improves the performative aspects of the synth!
Ben Asaro
On a related note, the Mother-32 is capable of self-generating patches in the real sense. Here's one and this is the patch sheet for it:
Post by Djberwick »
Sold :thumbup:
Djberwick
Post by Ben Asaro »
Do let us know how you get on with it!
Ben Asaro
The main thing here is that you heard something you liked from the M32, and it had potential for you, that’s all that needs to be said.
YouTube can be a real let down with demos though, most are awful, I wouldn’t judge the O Coast by those, like any synth, you need to try it.
Hope you enjoy the 32, Moog never disappoint, I’ve a Grandmother and Matriarch, couldn’t be without them, I don’t think there’s been a time in my life when I haven’t had a Moog around somewhere.
Post by Djberwick »
I'm sure I will, cheers. There is just something about the Moog brand that is very desirable to me :)
Djberwick
Djberwick wrote: Fri Oct 15, 2021 4:38 pm There is just something about the Moog brand that is very desirable to me :)
It’s the sound.
:D:D:D
Post by Djberwick »
Mostly that :) On a superficial level it is the heritage/history as well!
Djberwick
Post by Ben Asaro »
Djberwick wrote: Fri Oct 15, 2021 4:44 pm Mostly that :) On a superficial level it is the heritage/history as well!
There is definitely a prestige factor added to the Moog brand. When I purchased my M32 (from B&H in Manhattan), the salesman was like, "oooo ... that's the Cadilac of synthesizers". :D
Ben Asaro
Ben Asaro wrote: Fri Oct 15, 2021 5:07 pm
I think the Moog’s I own were designed like a TVR.
Post by t-sun »
Arpangel wrote: Sat Oct 16, 2021 9:22 am
Total Voltage control Reliability
t-sun
Posts: 264 Joined: Mon Jan 18, 2021 6:31 am
t-sun wrote: Sat Oct 16, 2021 9:42 pm
More like Terrible Voltage Regulation :wave:
Posts: 19724 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
I've had issues with both of my "current" Moog’s, and my confidence has been knocked, build doesn’t seem as good as it used to be.
Also, not a good company to deal with, no replies from support, I’ve given up.
My Grandmother has been back for repair and they found nothing wrong with it, as soon as I got it back it went wrong again, and still has an annoying fault, filter stops working, overloaded, no reverb. My Matriarch just freaks out now and again, then comes back again.
I just accept all this, like my car, comes with the territory
