Arturia Keystep 37 issues.
Re: Arturia Keystep 37 issues.
Ben Asaro wrote: Wed Sep 29, 2021 9:18 pm:D
Ooooh! Ooooh!
:D:D:D
I can’t be too bad on Arturia, they did change my life, so.
When they came out, I bought the Moog Modular, and ARP 2600, and went on to record loads of stuff with them, I thought they were magical.
Posts: 21423 Joined: Sat Jul 12, 2003 12:00 am
Given up on this, the CV out is very unreliable, Arturia released an update, but it’s still not up to scratch.
I’m just going to get a Midi module for my rack and use any of my other keyboards, my Moogs don’t seem to have any of the issues I’m getting with the Keystep, they control everything fine, and I can use the sequencers and arps on-board the Moogs, so problem solved.
One of the main reasons I got the Keystep was for it’s CV outputs, so if you’re doing the same, just be careful to check it out first, to see if it actually works with your system.
Post by Ben Asaro »
I have mmMIDI from ALM, it will do two MIDI voices to CV at once, is inexpensive, and works great. Definitely recommended, unless you need more that two voices.
https://busycircuits.com/alm023/
Ben Asaro
Posts: 3351 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Ben Asaro wrote: Thu Oct 21, 2021 12:49 pm I have mmMIDI from ALM, it will do two MIDI voices to CV at once, is inexpensive, and works great. Definitely recommended, unless you need more that two voices.
Thanks Ben, looks like the perfect solution.
