Vocal synthesis -- automated workflows from .xml or text/midi
Post by claz »
Hello hello,
Does anyone have recommendations for vocal synthesis software that accepts a music xml file with notation and lyrics, and outputs the sung audio?
In case you don't know what I'm talking about, here's a website that works on that principle: https://www.sinsy.jp/
Realism isn't important, but I need an automated workflow for batch-rendering audio from notes/text files.
There's plenty of work-in-progress software on GitHub that does what I'm asking, but I haven't yet found anything more polished. Some of these accept .xml; some accept a combo of .mid/.txt (separate notes/text), which is more cumbersome, but still fine.
Ideally, I'd be able to access the software through a command line interface -- i.e., via code, rather than through a graphical interface.
I've used AlterEgo (VST link: https://www.plogue.com/products/alter-ego.html), with good results, but it's a bit painful to enter text. It's not designed for automation, but you can kind of hack it by creating presets with the text you want -- but even then, you need a way to render without going into the GUI.
I'm curious about Vocaloid, but there's no free trial or online manual -- an it's only useful to me if I can supply a whole music/text file for an automated workflow.
Anyway, just wondering if anyone else has already solved this problem!
Cheers,
claz
Posts: 114 Joined: Mon Sep 10, 2018 3:35 am
Re: Vocal synthesis -- automated workflows from .xml or text/midi
Post by Tomás Mulcahy »
Vocaloid.
Tomás Mulcahy
Posts: 3002 Joined: Wed Apr 25, 2001 12:00 am Location: Cork, Ireland.
Post by claz »
Vocaloid accepts .xml? It does not seem so from their docs.
claz
