SOS Technical Glossary
Re: SOS Technical Glossary
Post by FrankF »
Forum Admin wrote:
Hugh Robjohns wrote:Damn good idea! Done!
And here's the direct link to the term for those of us who are lazy but nosy too... ;-)
https://www.soundonsound.com/glossary/dfa:-)
I hear Behringer are bringing out a DFA clone in the next few weeks.
It will have both MIDI and USB sockets, and will be available in a whole range of "attractive" colours.
According to my source, it's expected to start shipping from the beginning of April - I've pre-ordered mine already!
FrankF
Posts: 590 Joined: Fri Sep 13, 2002 12:00 am Location: La Vendée, France
Hugh Robjohns wrote:Pre-ringing, Minimum phase, Baxandall, Quasi parametric, LKFS, LU, bit depth, LDC/SDC, Band stop (reject) filter, Turnover frequency, SRC sample rate converter
All added...
Jitter, S+S Sample and synthesis, Scrubbing Tape, Frippertronics, Pre delay, Echo, Chamber, SRC, NYC (New York compression), Binaural, Shotgun, Crest factor, Noise floor,
Still on the to-do list after a long lie down in a darkened room... :crazy:
Posts: 43650 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Ave Moderator! Mixerturi te salutant!
Posts: 29663 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Luke W »
Love the fact that DFA has made its way in there, that was a great suggestion. :clap:
Luke W
Posts: 1697 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
New terms added to the Glossary:
Acoustic Envelope
Jitter
Interface Jitter
NYC (New York compression) / Parallel Compression
Shotgun Mic/Rifle Mic/Interference tube mic
Binaural
Dummy Head
Crest Factor
Noise Floor
Chamber Reverb
Post by Kwackman »
Hugh Robjohns wrote:New terms added to the Glossary:
..Dummy Head
At last, I've got my very own personal entry! :tongue:
Kwackman
Posts: 3678 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
:bouncy::think:
Ian wouldn't let me make an entry for Frickin' Eejit! :lol::shh::silent:
Post by Zukan »
Envelope follower
Zukan
1-2-1 Tuition
Zukan wrote:Envelope follower
Isn't that a trainee Post-person?
Posts: 4765 Joined: Mon Jul 21, 2003 11:00 pm Location: A studio deep in the fenlands of Cambridgeshire, UK
Post by wireman »
Been a while since I looked for new suggestions:
  • Public Address System (PA)
  • Audio Feedback / ringing
  • Feedback Suppressor/Controller
  • Alignment (tape)
  • Front of House (as pertains to division of tasks for sound engineering).
  • Live Sound Mixing
  • missing/phantom fundamental
wireman
Posts: 804 Joined: Fri Dec 17, 2004 12:00 am
Post by forumuser840717 »
Suggestion - explanation of the 3:1 "Rule"?
Mainly because it creates more confusion than it solves and probably 95+% of the time it's irrelevant to the circumstances in which it's being raised!
forumuser840717
Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
:D Thanks. I'll add it to the list.
Post by wireman »
Perhaps my suggestions a few posts up were not worthy?...
wireman
Sorry, yes, I'll add them to the list too!
Rompler. Saw it in the mag this month and I'm really not sure what it is.
But I might have one in the garage. :D
blinddrew wrote: Tue Jul 26, 2022 10:04 pm Rompler. Saw it in the mag this month and I'm really not sure what it is.
Didn't you ever wear a rompler suit when you were young? :D
Replace 'sam' in sampler with 'ROM', and you get a ROMpler. A synth that basically plays back samples stored in ROM, though often allowing you to mix different samples in layers and to change the filters and envelopes plus add effects etc. A pure ROMpler has no other means of sound creation onboard (e.g. no oscillators). The Roland JV1080 would be a classic example of a ROMpler.
Posts: 19204 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Yep. Wonks summed it up nicely but it's a term close to my heart so I'll add my supplementary definition.
"A device that uses samples instead of oscillators but cannot sample and within which the waveforms are stored in ROM as opposed to RAM or equivalent".
One advantage of a rompler is that you don't have the hassle of keymapping and such. It 'just works' due to the effort put in by the engineers who created the product. They are generally better at sampling than users are.
Of course the downside is you can't play samples you created.
There is a grey area between sampler and rompler which is a synth that has no sampling hardware but which has memory into which user-samples can be loaded (the Yamaha SY85 being an old example and the Kurzweil K2700 being a new one) but that feature comes with various caveats, overheads and limitations and technically that's not completely romplerific* by definition.
* I may have coined a new term there. I'll own it :-)
Posts: 9954 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Thanks chaps, I'll add those definitions ASAP.
Thank you all. :thumbup:
Sorry... took me a while, but I've added it to the Glossary
Post by RichardT »
Sone thoughts on potential entries:
Granular synthesis
Grain
EQ (some people may not know this means equaliser)
Automation
Fade in / out
Masking (psychoacoustic)
Pre-master
Clip gain
Normalise (as in adjust level of audio)
De-click
Quantisation noise
Array (microphone)
Source-destination edit
Three point edit
Four point edit
Rectifier
Comping
Null
Streaming
Destructive (editing)
Edit list
Mixdown
Floating point
Disk image
Distributor (as in cd-baby etc)
Royalty (streaming)
RichardT
Posts: 6007 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Tiz a never-ending challenge!
All good ideas. Thanks Richard. I'll try and work through them.
There goes Hugh's weekend! :D
A couple of weekends at least. He’ll have to look all those terms up first so he knows what they mean. ;)
Bonfire - collective noun for banjos and/or bagpipes.
Posts: 13291 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
