Logic re-freezing tracks when opening old projects
Post by Dr Huge Longjohns »
Logic Pro X has started behaving oddly. Whenever I open a project ancient or recent, it freezes tracks without me asking it to. (Freezing in the sense of track freeze to save CPU etc not crashing). Literally go to open file and as it opens it tells me it's freezing some tracks, presumably the ones in the project that were frozen before? No idea why it would suddenly start doing this, it's a right pita. Any ideas how to solve?
Last edited by Dr Huge Longjohns on Fri Feb 07, 2020 12:18 pm, edited 1 time in total.
Dr Huge Longjohns
Posts: 3953 Joined: Thu Apr 10, 2003 12:00 am Location: Gallifrey
Re: Logic re-freezing tracks when opening old projects
Post by MOF »
Unfreeze the tracks that you originally froze and re-save the song.
MOF
OK, but I can't go through every project I've ever done. I wonder what the issue is? These are projects I haven't opened for like 4 years, some of them?
Dr Huge Longjohns
Post by MOF »
You only have to do it once, as and when you open each song. When you needed to freeze songs (I presume you have a fast enough computer now and don't need to) that was what happened each time you clicked 'play', it would run through the song (without audio as it rendered those tracks) and then played the song.
MOF
Same computer same setup. Just suddenly started this strange behaviour for no apparent reason. Most odd.
Dr Huge Longjohns
Post by muzines »
I'm not sure offhand, but frozen tracks will need refreezing if there are no freeze tracks in the project (ie, the frozen audio files are missing), or possibly something's changed (eg, the frozen tracks were done with the engine set to 32-bit, and now the engine is set to 64-bit mode, so Logic says "Ok, those freeze files are invalid now, let's re-freeze".). Or maybe the plugin version has changed since the file was initially frozen. There are likely a few reasons to invalidate existing reeze files.
There will be *some* reason that's causing this behaviour, as otherwise, I've opened projects from long ago with freeze files are the projects play as they should without re-freezing anything.
muzines
Ah, I guess plugin changes/updates might be an issue with old files, yes or even Logic updates I suppose. Good thinking!
Dr Huge Longjohns
Dr Huge Longjohns wrote:Ah, I guess plugin changes/updates might be an issue with old files, yes or even Logic updates I suppose. Good thinking!
Of course it could be that it froze because it noticed the size of your longjohns ...
<coat/>
Posts: 9978 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by thematix »
Hi friends,
I’m having the same issue, though with new tracks. Audio tracks (not midi) that have been freezed don’t remain such upon reopening my project file. Upon 1st hitting play the project goes directly into re-freezing the tracks regardless if it’s one or a few. Seriously a time consumption burn.
Big Sur, with LPX 10.7.1
Any help is tremendously appreciated! This is killing me :)
Thankyou!
thematix
Posts: 2 Joined: Fri Nov 26, 2021 1:22 pm
Post by thematix »
Hi friends,
Hard drive space appeared to be my factor.
When the main drive began to fill up and the OS detected it and independently deleted work files it deems of least priority. Thus deleting the “LPX freeze files” upon startup/reopening a LPX project file to clear work space.
thematix
