Low profile XLR cables
Post by Humf »
Can anyone point me in the right direction? Various terminations needed if possible but even just a reliable source with male-female plugs would be great. I’ve seen one or two on Pink Noise but they’re a bit pricey for my needs!
Hugh - I’m sure I’ve seen you photograph some in some audio recorder reviews?
Sent from my iPhone using Tapatalk
Humf
Posts: 181 Joined: Wed Oct 22, 2003 12:00 am
Re: Low profile XLR cables
I'm not sure what you mean by low-profile XLRs. All of mine are Neutriks of various vintages. I think the current XX series are probably the smallest.
Posts: 43692 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Humf, do you perhaps mean right angled XLRs? These https://www.bax-shop.co.uk/xlr-plugs/de ... kFEALw_wcB are about the lowest profile I have found. Neutrik of course do R/A but they are a bit bigger.
Posts: 19145 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by Humf »
Sorry I should’ve been clearer. For my video work, I would just like some short length and lighter weight XLRs to hand. I’ve not yet had any need for compact or right-angled connectors. More the weight of the cable itself. I only have 10/15/20m available and could just do with some nice short ones with the thinner cable.
Here’s the example from Pink Noise.
https://www.pinknoise-systems.co.uk/low ... ables.html
Humf
Post by Nazard »
I moved to the XX range after reading the Neutrik information on their site. And they are very nice to solder, etc..
I would stick to Neutrik as they tolerances are tight, reducing the potential strain on equipment connectors, especially when removing XLRs.
Nazard
Post by Humf »
Sorry this is the link
https://www.pinknoise-systems.co.uk/amb ... ssory.html
Humf
https://www.enrgtech.co.uk/product/twis ... 451-010100
With the above you could make up some short, light weight cables. You need to sleeve it to make it thick enough to get reliable cable clamping.
Humf wrote: Sun Nov 21, 2021 5:09 pm Sorry I should’ve been clearer. For my video work, I would just like some short length and lighter weight XLRs to hand.
Ah. Lightweight rather than low-profile...
I have a bunch I acquired from Rycote years ago for use with their InVision studio shockmounts, but they don't appear to offer them anymore. Others I've made up myself using whatever thin flexible mic cable I could find. It's mostly Mogami 2697 I think -- but any thin flexible two core plus screen cable would do. The Mogami cable is intended for lavalier mics.
If you're not into DIY cable making, contact one of the small independent cable making companies who could easily knock some up for you. John Godsland at Orchid Electronics might be a good bet if you're in the UK. I'd hope they could produce them for well under £60 each which seems to be the standard price for commercial ready-made cables of this type.
Obviously, a thin and lightweight cable isn't robust. I generally only use them as a link between a microphone on a shock mount and a heavy-duty cable to run back to the recorder. The idea is to prevent any cable-carried vibrations from reaching the mic and effectively short-circuiting the shock-mount. They also prevent the weight of a normal cable from deforming the shock-mount. Mine are all around 0.5m in length, mostly with standard XLRs on both ends (although a few have right-angled female XLRs)
Post by Humf »
Thanks Dave. I think Somner do something similar. If I don’t find any ready made, then I’ll have to have a go. Only ever done repairs before.
Humf
Post by Nazard »
Apologies if I have missed the point of your post.
You need small diameter, and short XLR cables, to reduce wind noise, (via the cables), when making videos?
P.S. I am sure that the latency on SoS has increased since the last, major, update. E.g. I didn't see Hugh's reply, until now. And I frequently refresh the webpage.
Nazard
Post by Humf »
I have a bunch I acquired from Rycote years ago for use with their InVision studio shockmounts, but they don't appear to make them anymore. Others I've made up myself using whatever thin flexible mic cable I could find. It's mostly Mogami 2697) I think -- lavalier mic cable.
Thanks Hugh. Yes I’d seen the Mogami cable mentioned too.
I’ll have a look at Orchard.
One of my uses would be almost like patch cable within a rack that houses both my X32 rack and video switcher. Also for use with various mics and routing from my zoom F6 which is on a spider arm off the tripod. Solo shooting is tough and I’m trying to find ways to reduce bulk and where possible, keep the rack with some bits of cabling permanently patched for speedy setup.
Humf
Post by Humf »
Trevor Johnson wrote:Apologies if I have missed the point of your post.
I’m rarely outdoors but otherwise, yes. Reducing bulk and keeping short is my aim.
Humf
Post by Humf »
Just for clarity, I don’t ever use the x32 and F6 at the same time Image
Just chatted with Pink Noise (who are always amazing...) and they do make custom cables, so fingers crossed I’ll get some made up. Ideal solution as I live locally to them.
Humf
Post by Humf »
It’s arrived.. and it’s a thing of beauty. Thank you Pink Noise.
Humf
:clap::thumbup:
Posts: 22577 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
