sE Microphone repair anyone?
Post by Mick C »
Hi All,
I have an sE Electronics Z5600a MKII valve mic that's recently started giving an audible hum/buzz around 93Hz. Does anyone know of a suitable repair shop, ideally near Manchester, that might be able to diagnose and repair?
I've tried it on different audio interfaces in different buildings, and as I say, its only recently started and I've had it for about 8 years. New valve from Watford valves too. So I'm convinced it's either the mic, the transformer, or the bespoke transformer to mic cable - these being the only things I'm not able to test.
Thanks!
Mick
Mick C
Posts: 157 Joined: Tue Oct 26, 2010 12:00 am Location: Manchester, UK.
Re: sE Microphone repair anyone?
That hum frequency sounds suspiciously mains related so I'd suspect a power supply failure first and foremost. Sorry I can't recommend anywhere specific, but hopefully someone here can.
Posts: 43633 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I have used Gee Electronics in Warrington a couple of times in the past for mixer and amp repairs and had good service. I imagine they'll be able to help.
Posts: 22849 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Mick C »
Sam Spoons wrote: Thu Dec 02, 2021 9:22 pm I have used Gee Electronics in Warrington a couple of times in the past for mixer and amp repairs and had good service. I imagine they'll be able to help.
The guys at PMT Manchester actually recommended Gee, but when I phoned Gee they said unfortunately they only do PA stuff nowadays and couldn't help.
Mick C
Mick
Shame, that said microphones are pretty specialised, have you contacted sE directly? They seem a reputable brand so I'd expect them to have recommended repairers and a mic is not to large to post economically.
Post by Mick C »
Its definitely a shame, I thought I was onto a winner with GEE!
I've just contacted sE - hoping the repair cost isn't too scary..
thanks for your help
Mick C
Mick
Post by shufflebeat »
Roland at the Amp Clinic would be worth speaking to with anything valve related:
https://m.facebook.com/story.php?story_ ... %2As%2As-R
But I suspect going back to the manufacturers would be simplest, quickest and probably cheapest.
shufflebeat
Posts: 10066 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Post by Mick C »
Hi Guys
SE have three repair centres in the UK: Southend, Sheffield and Glasgow.
I’ll be giving them a call.
Thanks
Mick
Mick C
