Do I need a second ground connection?
Post by solaris »
Hi there, I am building my studio and someone told me that the connection to earth forthe audio equipment should be different from the lights, A/C etc. I could add a second ground connetion in the garden. Is it necessary for a professional studio?
Also how do we measure the quality of the ground? What should I aim for?
Thank you very much in advance.
solaris
Posts: 101 Joined: Mon Oct 27, 2003 12:00 am Location: Greece
Re: Do I need a second ground connection?
No. While each of these should have their own route back to the distribution unit, never have two separate earth sources in the same area. As I was once told, "There is no such thing as Earth potential".
Posts: 20899 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by solaris »
That is great. Thank you for the information.
Are all grounds created equal or should I somehow measure the one I've got?
Thanks again.
solaris
Employ a qualified electrician. This is not something to 'experiment with. There are rules and regulations...
Posts: 43727 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by solaris »
Hugh Robjohns wrote: Tue Dec 07, 2021 9:42 pm Employ a qualified electrician
Thank you very much for your answer. I have employed a qualified electrician but he is not specialized in recording studios. So the connection to the ground will be safe and according to the rules etc., but I don't know if I need something better for the studio and what would that be. Like I could tell him that the ground "resistance" should be so and so.
Thank you for your help.
solaris
solaris wrote: Wed Dec 08, 2021 11:33 amI have employed a qualified electrician but he is not specialized in recording studios. So the connection to the ground will be safe and according to the rules etc., but I don't know if I need something better for the studio and what would that be
I'm afraid I don't know what the rules are in Greece. In the UK, the standard IEEE rules are generally entirely appropriate for a recording studio -- although as Folderol says above, it is important to keep the mains supply for studio equipment separate from the utility supplies for lighting, HVAC, and so on. All mains safety grounds should meet at the incoming mains feeder's earthing point.
Obviously, you need the studio mains safety ground to be as low-impedance as possible, which means using the thickest ground cable back to the distribution box that's practical for the installation.
Installing a separate 'Technical Earth' -- which is what I think you're referring to -- requires very specialised design and installation as there are significant safety issues to be dealt with, and in most cases it won't actually bring about any worthwhile advantages anyway.
Post by solaris »
That is amazing. I found the IEEE rules, so I have a general idea of the resistance values. Thank you both for your help.
solaris
Hugh Robjohns wrote: Wed Dec 08, 2021 11:48 am
In the UK, the standard IEEE rules are generally entirely appropriate for a recording studio.
NOT the IEEE in the UK. :headbang:
The IEEE is an American organisation.
In the UK, BS7671, (currently the 18th edition of the IET wiring regulations) is the appropriate document to refer to. The IET was formerly the IEE (whose name could have caused confusion with the IEEE as they are very similar organisations in their respective countries), but the IEE merged with the IIE to become the IET back in March 2006.
I’m sure the IEEE guidelines contain a lot of useful information that runs in parallel with the IET regs, but they should not be used as the basis for UK installations.
Posts: 19213 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Apologies: typo on my part! :oops: And I should have caught it as the IET Wiring Regs are on the shelf beside me!
Post by Paton.90 »
I think if you are careful with the wiring, and how you connect your equipment, there wouldn't be reason to be worried about earth issues.
BUT, if you have the money and the time to design something (with a qualified electrician like Hugh said), read and google about "star ground", although it's complex i've heard it gives very good results. Maybe people here know more about it or have a different opinion.
Paton.90
Posts: 17 Joined: Sat Jul 11, 2020 9:55 pm
Post by Mike Stranks »
Paton.90 wrote: Sun Dec 19, 2021 7:56 am I think if you are careful with the wiring, and how you connect your equipment, there wouldn't be reason to be worried about earth issues.
Sorry to be blunt, but NO!
With a new-build you have to be absolutely sure there's a proper and good earth. Without it the risk of killing yourself or others or burning the place down is very substantially increased.
ALWAYS be sure about good, solid earth connections in any sort of building - new or otherwise.
Post by Paton.90 »
Mike Stranks wrote: Sun Dec 19, 2021 8:32 am
I assumed he already had a proper earth connection and was thinking of adding an extra one for his new studio, i imagined like a new room in his house or something like that. Maybe i misunderstood :oops:
Paton.90
