Hi! Just asking whether I should NOT use Audacity to convert final WAV masters into mp3's for distribution.
What do you guys think?
use audacity to convert wav to mp3
- wearashirt
Regular -
Posts: 127 Joined: Wed Jun 09, 2021 4:18 am
Re: use audacity to convert wav to mp3
According to the manual Audacity uses the Lame library to encode mp3 so it should be as good as anything. Just make sure that you use a reasonably high bit rate - I'd suggest 256kb/s if you use variable bit rate and 320kb/s for a fixed bit rate.
Posts: 16381 Joined: Mon Sep 10, 2001 12:00 am
James Perrett wrote: ↑Sat Dec 25, 2021 3:09 pm According to the manual Audacity uses the Lame library to encode mp3 so it should be as good as anything. Just make sure that you use a reasonably high bit rate - I'd suggest 256kb/s if you use variable bit rate and 320kb/s for a fixed bit rate.
It does indeed. This was a minor problem at one time as debian wouldn't include LAME due to the mp3 patent status, so you had to fetch it separately.
As a result I got into the habit of calling LAME directly from the command line.
- Folderol
Forum Aficionado -
Posts: 20316 Joined: Sat Nov 15, 2008 12:00 am
Reaper users have to download Lame separately too, it's a free/open source download but AIUI they can't include it with Reaper for licensing reasons.
Forum Aficionado - Posts: 22226 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Sam Spoons wrote: ↑Sun Dec 26, 2021 2:30 pm Reaper users have to download Lame separately too, it's a free/open source download but AIUI they can't include it with Reaper for licensing reasons.
Not sure that's the case anymore Sam. When i changed computer last year and was reloading all my software I didn't need to load Lame separately.
Posts: 28843 Joined: Sun Jul 05, 2015 12:00 am
According to Wikipedia all the mp3 related patents had expired by 2017 in the US (and by 2012 in Europe) so the licensing issues have probably gone away now.
blinddrew wrote: ↑Sun Dec 26, 2021 2:35 pmSam Spoons wrote: ↑Sun Dec 26, 2021 2:30 pm Reaper users have to download Lame separately too, it's a free/open source download but AIUI they can't include it with Reaper for licensing reasons.
Maybe, I'm shortly going to install Reaper V6 so will find out then
If you want a very versatile converter you can download the 30 day demo of Samplitude Pro X 6 from MAGIX. It is very simple to use, Once your .wave is loaded you just click 'Export' and select MP3 (there are several other options)
A new box appears and it is very easy to select the quality level you want.
Very quick and easy for batch ripping CD tracks as well.
I've used Audacity a lot for this purpose. No problems at all. I agree with James' bit rate recommendations, but that would be true for any such tool and not just Audacity.
- ConcertinaChap
Jedi Poster -
Posts: 14720 Joined: Wed Jul 20, 2005 12:00 am
Mr Punch's Studio
If a tune's worth playing it's worth playing lots!
Thanks all for your important comments!! Now I feel bad for the one buyer who got her file as 128 kbps...
- wearashirt
Regular -
wearashirt wrote: ↑Mon Dec 27, 2021 4:10 am Thanks all for your important comments!! Now I feel bad for the one buyer who got her file as 128 kbps...
95% of people neither know, nor care...
