Recording noise level review
Post by nunobass »
Hi,
I hope everyone is doing well in this Forum!
I'm new here so Hello!
I'm writing to have an opinion about my recording noise level.
I'm using a phil jones bass buddy pre-amp with DI and a alpha-omega darkglass.
I took a screenshot of my spectrum analyzer of the noisy signal attached.
I thank you in advance for your feedback about my noise signal!
nunobass
Posts: 1 Joined: Thu Jan 13, 2022 3:21 pm
Re: Recording noise level review
You have a noise floor from a bass DI sitting below -100dBFS. I'd say that was extremely good, so why are you concerned about it?
Posts: 43616 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by nunobass »
The reason for asking was just to have a technical option.
I'm thinking on starting to offer as a session bass player and I want to be sure I'm can delivering a close to studio audio quality wav :)
Thanks for you feedback :thumbup:
nunobass
Assuming your bass signal is peaking up to somewhere between -10dBFS and -20dBFS I don't see a problem. If the bass is only peaking -80dBFS there is a problem... :D
RTAs can give misleading results what you need to know is the 'resting' noise floor in dBFS relative to your average playing level.
Posts: 19067 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by MOF »
Do your bass guitar recordings sound noisy when played at reasonable levels?
MOF
Posts: 2569 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
Post by MarkOne »
If I was looking for a session bass and I had to choose between something that sounded like Billy Sheehan on fire but with a bit of recording noise, or Joe from the band down the pub tracked at Air Studios on the quietest signal chain known to man, I know what I'd be choosing.
Just saying. :wave:
MarkOne
Posts: 3045 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
Some numbers: I plugged my rubbish Hondo bass into my MOTU M 4 and set gain for -20dBFS peaking to -10ish. I then stopped playing and oriented the bass for least noise pickup. Reading was a 'blippy' -66dBFS.
Chopped off the noodling part and just exported the noise to Right Mark Anny and the mid band level was -126dB but with a whopping 50Hz peak at -90dB, there was another lesser peak at 150Hz.
Certainly a better quality bass should be less noisy but I doubt even the best rig will get below -75dBFS and keep away from big transformers!
