Cassette to cassette overdubbing — how did we do it?
In the late seventies/early 80s we would record our bands using two cassette decks. We’d plug two mics into one and point them at the instruments to create a stereo backing track.
Then we’d get a second cassette deck and record vocals and the backing track together onto the second cassette.
But for the life of me I can’t remember how we did it. Obviously it’s easy with a little mixer to blend the backing track and live vocals into the second cassette but I don’t believe we had access to such sophisticated equipment!! All we had was basic hifi separates. So how did we do it? Any other oldies got any ideas?
(We didn’t do it by using speakers by the way, in case that was a thought.)
- Dr Huge Longjohns
Posts: 3953 Joined: Thu Apr 10, 2003 12:00 am
Re: Cassette to cassette overdubbing — how did we do it?
I don't think you'd have stayed in stereo...
One scenario would be to take the backing track and route that to one track of a second machine and at the same time record vocals onto the other track.
You'd then have backing L, vocals R or vice-versa.
You could then take those tracks and 'mix' them back to another machine using a combination of 2 to 1 adapters and balance controls.
It would work, but I wouldn't vouch for the quality!
The arrival of the Portastudio in 1979 - I remember it well! - really was a game-changer. The rest is history!
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Mike is right, and if you’d had an amp with a mono button, you could then record a mono mix of the two tracks onto one cassette deck, on both channels.
I wasn’t averse to just snipping cables, and literally just twisting wires into the same signal.
I must be one of the only guys from my generation that never had a cassette multitracker. I went through a few open reel recorders, though. One of which had built-in 'sound on sound' that I could never understand!
We definitely had the backing track still in stereo, I was transferring an example into Logic yesterday!
I’m wondering if some cassette decks let you record the mic ins and line ins at the same time? That would certainly solve it?
The vocals are clearly done with two mics too so it’s all stereo and remarkably good quality actually.
- Dr Huge Longjohns
Lots of the cassette decks of that era had basic input mixing functions for combining mics with line sources. I remember a desktop Sony model that had faders on the top which we used in exactly the way you describe.
Posts: 41714 Joined: Fri Jul 25, 2003 12:00 am
I graduated from ordinary cassette as described above, with two mic inputs, to a Teac 108 which let you record right and left tracks completely independently! Two track multitracking! Changed my world. Then a four track Fostex x15, then a Tascam Porta 2! Then along came digital and the Akai dps 12. Happy days!
- Dr Huge Longjohns
Hugh Robjohns wrote: ↑Tue Jan 18, 2022 10:19 am Lots of the cassette decks of that era had basic input mixing functions for combining mics with line sources. I remember a desktop Sony model that had faders on the top which we used in exactly the way you describe.
I certainly don’t remember any mixing/blending functions like that but if it would let you record both sources at once we probably blended using the mic in rec level or something!
- Dr Huge Longjohns
As you had mics, are you sure you didn’t run them into a mixer first and then into a cassette deck? It would have made it a lot easier to do what you describe.
No definitely not. A Shure Unidyne B and another plastic no name dynamic was the extent of our recording rig. Just moved them around until it sounded ok on playback. Eq, compression etc were not even on our radar.
- Dr Huge Longjohns
Dr Huge Longjohns wrote: ↑Tue Jan 18, 2022 9:39 am We didn’t do it by using speakers by the way, in case that was a thought.
I first did it with speakers, cheap little boom boxes, sounded terrible. I also vaguely remember a bookshelf system where I could push in both the "Tape" and "Aux" buttons at the same time, and if I could make 'em both stay in... then I got my 488 Portastudio...
BWC
You weren't the only one to miss out the portastudio. I had friends with 4 tracks (including one with an old Ampex half inch reel to reel machine) but I upgraded from sound on sound on a reel to reel straight to 8 track. 4 tracks involved too many compromises and on every 4 track session that I did we spent too long trying to overcome the limitations imposed by the lack of tracks. Sound on sound dictated that you had to work in a certain way while 8 track gave you proper multitracking without the headaches of 4 track.
Posts: 15664 Joined: Mon Sep 10, 2001 12:00 am
8 tracks on a cassette is mad isn’t it! Were these just double speed like the posher four track ones?
- Dr Huge Longjohns
Dr Huge Longjohns wrote: ↑Tue Jan 18, 2022 2:12 pm 8 tracks on a cassette is mad isn’t it! Were these just double speed like the posher four track ones?
I had an 8-track cassette for about a week once, I think a Tascam if memory serves, but found the quality unacceptable in comparison to the (surprisingly good) Akai Professional 4-track I'd used previously.
My solution was to return the 8-track and extend myself a bit more to an 8-track HD recorder. Never looked back after that!
Posts: 9549 Joined: Wed Sep 01, 2004 12:00 am
Completely mad. Stupidly thin tracks made barely playable by the use of strong noise reduction and doubled tape speeds.
The Tascam 238 eight-track multitracker ran at 3-3/4 ips with dbx, and the Tascam 238S version used Dobley S noise reduction.
Me too, IIRC I went straight from a mono portable cassette recorder to a Revox A77. There may have been a couple of stereo cassette decks but definitely never a cassette multitracker.
Forum Aficionado - Posts: 21523 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
My 488 ran at double speed and had dbx that I left switched off. Used with good quality cassettes, I thought it sounded as good as anything else I had access to at the time.
BWC
I had a pioneer dual cassette deck that let you blend a mic input when you were copying from one deck to the other. It was just a consumer tower system from Dixons, nothing high-end. I'm pretty sure the backing track stayed stereo but any overdubs would have been mono.
- Dynamic Mike
Longtime Poster - Posts: 5290 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
I started with a Tascam 244 Portastudio but my next upgrade was to a Sansui 6 track cassette and 12 channel mixer (they also made a combined 6 track portastudio). After that I moved to 8 track R2R.
- Music Wolf
Posts: 2842 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://www.starbelly.me/
I didn’t get a Portastudio till the late eighties, there used to be a studio near us, that we used to record in, they had a half inch four track Ferrograph, and I always had trouble filling up those four tracks.
Before all that I had open reel machines, tape bouncing, cassettes, using records as samples, I’m in the middle of going through these old tapes, I can recommend it, it’s very interesting, listening back.
That’s exactly what I’m doing, hence my bewilderment!
- Dr Huge Longjohns
