Project Guinjo
Re: Project Guinjo
Post by RichardT »
As I’m sure you’re aware, Drew, guinjo is Spanish for jujube, which is a Chinese red date. My partner Wendy uses them when she makes Chinese soups.
RichardT
Posts: 5979 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Re: Project Guinjo
Wonks wrote: Wed Dec 29, 2021 5:32 pm Just keep thinking about the bridge height. If you put a simple L-bracket on the edge of the rim, then the bridge will probably need to be at least 1cm higher than this to get a reasonable break angle. Add that to the height of the rim above the skin, and it's getting pretty tall.
Getting the string anchor point down as low as possible to the drum head removes the need for extra height just for break angle. You could do this with a more complicated bracket, but drilling holes would seem to be the simplest method and in keeping with the DIY ethos of the build.
That's a very good point, one I hadn't considered.
Given the scale length of 20.25" (about 514mm), the neck's 12th fret body join and a 10" tom, it would seem the wooden centre block would need to be constructed to project the 12th fret about 3.5" away from edge of the drum shell in order to get the bridge at the fairly standard banjo position of 1/3 the way across the head from the tail end. Just sayin' loike.
Yep, that's part of the plan, possibly under-illustrated in the first diagram.
Posts: 29645 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Project Guinjo
RichardT wrote: Wed Dec 29, 2021 6:54 pm As I’m sure you’re aware, Drew, guinjo is Spanish for jujube, which is a Chinese red date. My partner Wendy uses them when she makes Chinese soups.
I did not know this. I shall make sure the red theme is carried over into the build. :)
Re: Project Guinjo
Post by RichardT »
blinddrew wrote: Wed Dec 29, 2021 8:16 pm
No, I wasn’t really expecting that you would! I didn’t know either until I searched for guinjo on Google.
RichardT
Re: Project Guinjo
Cut down the drum, marked up the beginnings of the centre block, tidied up the neck a bit (including removing the end of the fretboard so that it will nestle up against the drum rim to avoid needing a stratospherically high bridge.
Work is being slowed a bit because I'm still struggling with a sprained thumb.
Re: Project Guinjo
Today has been all about the centre block, but I have made some significant progress with one of the most awkward bits of the job:
Re: Project Guinjo
Good work. I can’t see the nails at all! ;)
Posts: 19196 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Re: Project Guinjo
Post by RichardT »
That’s looking really good!
RichardT
Re: Project Guinjo
Looking great Drew :clap:
Posts: 22850 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: Project Guinjo
Looks rather strange, but in a nice way :thumbup:
Posts: 20824 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Project Guinjo
Wow - you really are enterprising and resourceful Drew! :clap:
Posts: 22551 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: Project Guinjo
I'd hold fire on the congratulations until it actually works! ;)
Still got the neck setting to do and that's where I'm going to have to step up the precision.
Also I'm planning on over-complicating the headstock... :headbang:
Re: Project Guinjo
blinddrew wrote: Mon Jan 03, 2022 10:25 pm I'm planning on over-complicating the headstock... :headbang:
Excellent :thumbup:
Posts: 13288 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Re: Project Guinjo
Post by ManFromGlass »
You might consider some padding on that metal rim as it might not be too comfortable to rest an arm over, unless you’re into that sort of thing……
Not judging at. . . . . .
:smirk:
Posts: 7839 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Re: Project Guinjo
I have thought about some kind of plate here.
But I haven't thought enough to figure out how to do it.
Re: Project Guinjo
ManFromGlass wrote: Tue Jan 04, 2022 3:41 am You might consider some padding on that metal rim as it might not be too comfortable to rest an arm over, unless you’re into that sort of thing……
:smirk:
Just view it as penance for building such a banjo-like instrument. He should probably add spikes to the rim. ;)
Re: Project Guinjo
Heavy metal banjo? Great idea!
Perhaps with a resonator that big it will be LOUD !
We can only hope . . . . . . .
Re: Project Guinjo
Doesn't look like much, but there's been a lot of fine tuning to get to this stage.
Neck glued:
Re: Project Guinjo
Here's something that might give you a bit of inspiration (or maybe not :D )
FWIW Duved is a superb guitarist in the Manouche style, He is achknowledged as having a very authentic sound, possibly the closest contemporary player in sound and style to Django himself. Definitely ot so sure about the banjo though :smirk:
Sorry it's FB but I couldn't find the vid on YT.
https://www.facebook.com/denis.chang/vi ... 487061565/
Re: Project Guinjo
Enjoyed that Sam, good find! :thumbup:
Re: Project Guinjo
I gave Duved and the fiddle player a lift from Manchester Airport to March Manouche Festival where he was playing a few years ago (I volunteered at the festival a few times). Slightly odd guy, Adrian the fiddler was lovely, Duved slept the whole journey... Great player though.
Re: Project Guinjo
First coat of colour (most of which will be sanded off) and starting on the unnecessarily complicated headstock:
Colour is more patchy than I was expecting so I might have to think about trying a solid colour. But that would require buying some paint and I'm trying to do this without spending money wherever possible.
Re: Project Guinjo
The words ‘glue spots’ spring to mind. You really needed to clean up better when gluing it all together.
Re: Project Guinjo
I must confess that I was expecting a bit of glue spotting but not nearly as much as this! I think it might be time to have a trawl through the paint pots and see if there's anything useable.
Re: Project Guinjo
Ok, the stain looked even worse this morning so we're definitely going solid colour. I just need to find some suitable paint.
This does actually give me the option to tidy up a bit of historic damage to the neck.
So currently it looks like this:
Overly complicated headstock coming together:
