Have I Been Conned?
Have I Been Conned?
Post by pa28 »
After many years of using a Classic Faderport it finally gave up the ghost. I am now the owner of the latest Faderport2 Studio One.
Having been assured it will work not just on Presonus;s own products but there are multiple DAWS including Cubase it will work on. NOT.
I am using Cubase 8.5 Pro on a Win 7 Pro 64bit machine quitee simply this will not work under any circumstances the device shows up everywhere ie in midi manager, device manger etc it receives all midi inputs IE all controls on device transmit and shows as midi activity. I have tried this with 3 other pc's using Cubase 5, Nuendo 4 Cubase 8.5 32 bit/64 bit and Nothing
Am writing this on a laptop that has never had a Presonus device attached so no software conflicts and still ZILCH. Raised a support ticket with Presonus a couple of days ago and as usual has been ignored so sadly will be returning as Amazon's returns policy allows as "Not performing as expected" really hacked off with this and now need to get another controller, any good recommendations for Cubase?
pa28
Posts: 167 Joined: Sun Oct 14, 2007 12:00 am Location: u.k. London
Capitalisation is the difference between helping your uncle jack off a horse  & helping your Uncle Jack off a horse.
Re: Have I Been Conned?
Can't help with Cubase, and I don't have one but I'd say a Behringer X-Touch One would be worth a try. https://www.thomann.de/gb/behringer_x_touch_one.htm
Posts: 22856 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Definitely X-Touch - it works well.
If you have an iPad and MIDI Designer you could also use my layout that emulates the Mackie MCU protocol and is very 'X-Touch-alike'... ;) At the least it would give you chance to try it out before you choose something physical.
Posts: 21413 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by pa28 »
The Behringer does look like it could be replacement, and as a non "Apple" person the ipad option is unfortunately not for me.
Cheers
pa28
Post by fatbenelton »
Sorry if I’m stating the obvious, but the Faderport2 is set up for Studio One out of the box and you need to ‘set it up’ for other DAW’s by holding various button combo’s on startup. Can’t remember the Cubase one but it’ll be in the documentation...Once set it stays that way until you want to change it.
fatbenelton
Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
Just had a look (P18 of the manual):
By default, the FaderPort is in Studio One operation mode. To switch to Cubase
/ Nuendo operation, press and hold the NEXT button while powering on your FaderPort, then press the Bypass button to enable Cubase / Nuendo (MCU) operation.
The FaderPort is a class-compliant device in both macOS® and Windows®. Simply connect your FaderPort to a free USB port on your computer. No further installation is necessary.
You then need to go into Cubase Studio set up and add a Mackie Control (which the fader port imitates)..there are some other settings but I’ll let you read the manual rather than copy it all here.
fatbenelton
Jonny
Post by pa28 »
Fully aware of the procedure to select correct DAW on power-up. And have tried all 3 MCU options on all computers that I have with both Cubases(5 & 8.5 Pro)and Nuendo, and still nothing. will give Presonus one more day to respond before the label is printed to return this doorstop back to Amazon.
Would really like to hear if anyone has got this working same as I need.
pa28
Post by gingertimmins »
Have you done the firmware update?
Your cubase versions are quite old. Could it be that the new fader port is only compatible with newer versions?
gingertimmins
Posts: 498 Joined: Wed Dec 05, 2007 12:00 am
I’ve just dusted mine off and installed/set up without a hitch - Cubase 11 though.
fatbenelton
Jonny
Post by pa28 »
gingertimmins wrote: Wed Jan 19, 2022 2:34 pm Have you done the firmware update?
According to Presonus the firmware update is not needed for my setup. however I did do it just make sure it wouldn't work :headbang:
pa28
Post by pa28 »
fatbenelton wrote: Wed Jan 19, 2022 2:37 pm I’ve just dusted mine off and installed/set up without a hitch - Cubase 11 though.
how does it show when adding a remote device. and is there a corresponding .DLL in say components in Steinberg?
pa28
I’m on Mac/have no idea. I just set it up in studio and it works.
fatbenelton
Jonny
Post by pa28 »
fatbenelton wrote: Wed Jan 19, 2022 3:00 pm I’m on Mac/have no idea. I just set it up in studio and it works.
OK but my problem was on Win 7 64bit as said...
pa28
Indeed you did but the set up in Cubase should be the same and equally simple. I’ll leave you to it.
fatbenelton
Jonny
Post by pa28 »
Quite right and so it should be, but it isn't, so now hopefully Hermes carriers will be taking this well made doorstop back to Amazon tommorow. Behringer look like they will be getting my wonga now.
pa28
Post by pk.roberts »
Looking at the Tech Specs on the Presonus website, it does show Windows 10, 64 bit as the minimum spec required.
pk.roberts
Posts: 115 Joined: Fri May 09, 2008 12:00 am
Ain't No Party Like an S Club Party
Post by pa28 »
pk.roberts wrote: Wed Jan 19, 2022 3:28 pm Looking at the Tech Specs on the Presonus website, it does show Windows 10, 64 bit as the minimum spec required.
Yep correct thats why I tried on Win 10 64 bit first to see if it was worth updating to Win 10 on my main music PC. But sadly complete failure all round.
So, on its way back tommorow and the "X Touch" will be ordered once refund in bank.
pa28
Post by pa28 »
Well the X-Touch arrived, and all up and running using the same Mackie Protocol that Presonus said would work with Cubase but doesn't, really pleased with the extra functionally of this piece of kit, a different way of working as I had got used to with the Classic Faderport for many years, but hey-ho moved on and back to work.. :bouncy:
pa28
Thanks for coming back to let us know. It's good when these things work out.
For lots of extra switch functions you might also look at Stream Deck - that's the most used remote device in my studio, used to run Cubase, invoke macros, switch mixer views, run backups, open folders, change the colour of my studio lights... almost anything you can come up with. It's quite a life-changing device!
Post by Chromeman »
The Elf wrote: Mon Jan 24, 2022 2:50 pm For lots of extra switch functions you might also look at Stream Deck
Which version do you have as a matter of interest? Amazon has a Mk1 and Mk2 version of the 15 key unit. 32 keys would be overkill for me I think.
Chromeman
Posts: 265 Joined: Mon Mar 31, 2014 12:00 am
I find the XL better for the studio, as it works in rows of 8, which is a bit of a studio 'norm'. I standardise my top row to page navigation and program launching, so the rest is available for functions. My main Cubase layout is shown below (the rainbow takes me into a screen full of colours for colouring my tracks/parts).
But I also have the smaller 5x3, which is fine for my living room laptop.
BTW I see no advantage to the SD Mk2 - it even comes with a now fixed angle stand, which kills one of the Mk1's best features!)
Post by Chromeman »
Thanks for that. Very helpful re the different versions. Have gone for the 32 key in the end - as you said, having 4 banks of 8 makes a lot of sense for DAW use. Cheers.
Chromeman
I have the Stream Dock mini and it's very useful but I hate the wedge shape, the front panel is just not at the right angle for easy operation. I nearly bought the Stream Dock mk2 but thankfully spotted fixed front panel angle which made it a nonstarter. I have an original Stream Dock on the way from Thomann as I type.
Sam Spoons wrote: Mon Jan 24, 2022 4:32 pm I have the Stream Dock mini and it's very useful but I hate the wedge shape, the front panel is just not at the right angle for easy operation. I nearly bought the Stream Dock mk2 but thankfully spotted fixed front panel angle which made it a nonstarter.
Here's my guess... The fixed stand is cheaper to provide.
If the angle was about 10º it would be fine but it's far too upright :madas:
