Akai 4000DB finally dies.
In the middle of a session yesterday, using the 4000 to distress some spoken word recordings, it was already getting pretty bad, but I liked it, it was "nicely bad"
Then, all of a sudden it made a loud screeching noise and one of the meters stopped working, it sounded completely muffled, you could just about hear the left channel only.
I did the usual, cleaned heads, tape path, de-mag, but it didn’t do anything.
I noticed that there was a lot of oxide on the table below the first tape guide, and whoever owned this machine in the past did a bizarre thing, they replaced the metal guide roller with a wooden one! :crazy:
It’s the rotating wheel in between the roller guides and it makes an awful squeaking sound.
Its not worth spending too much time on, I’ll take it apart to if I can see anything obvious, but that’s about it.
I might get another tape machine, something in better condition, maybe a Studer, or a proper studio job, if I can keep up the enthusiasm.
Tape is a pain, and I'd forgotten exactly how much of a pain it is, and tape is so expensive, I’m not sure I even want to continue with this just for one or two effects, they aren’t the same on the computer, it is a unique sound, but the returns for the effort involved aren’t worth it.
Re: Akai 4000DB finally dies.
Post by Dan LB »
Now that you have your Mac setup check out SketchCassette:
https://aberrantdsp.com/plugins/sketchcassette/
Dan LB
Posts: 1691 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
