I am getting a MOTU M4 to go with my new Mac studio, but I balk at the £37.00 Apple one?
Are there any cheaper but still viable options?
USB-C cables for new Mac Studio
- Gone To Lunch
Frequent Poster - Posts: 1165 Joined: Fri Jun 11, 2004 12:00 am Location: London
Re: USB-C cables for new Mac Studio
- Dave Rowles
Posts: 1589 Joined: Thu Feb 28, 2008 12:00 am
As it is only USB2 speed any old usb c cable would do I would think.
Edit: Two posts at same time, I always go for Anker as well. Good products and amazing support.
- Guest
As above, if it's USB then there's less of an issue. If you're connecting Thunderbolt devices then you'll need to make sure the cable is specified for Thunderbolt (they usually have the logo on), although the connectors are the same a USB cable won't do the trick there.
Got a nice silicon thickish one with a Microsoft Display Dock that are now cheap new and should give you display port and HDMI out plus something like 4 USB 3 ports and a 5V 3A USB-C charger https://www.ebay.co.uk/itm/184782136840
or my IKEA fabric coated ones that are only £5 have been fine https://www.ikea.com/gb/en/p/lillhult-u ... -50491543/
Luke W wrote: ↑Mon Apr 18, 2022 7:37 pm As above, if it's USB then there's less of an issue. If you're connecting Thunderbolt devices then you'll need to make sure the cable is specified for Thunderbolt (they usually have the logo on), although the connectors are the same a USB cable won't do the trick there.
I wondered about this; my MOTU M4 only has USB-C, but the Mac has both Thunderbolt and USB-C?
- Gone To Lunch
Gone To Lunch wrote: ↑Mon Apr 18, 2022 9:04 pmLuke W wrote: ↑Mon Apr 18, 2022 7:37 pm As above, if it's USB then there's less of an issue. If you're connecting Thunderbolt devices then you'll need to make sure the cable is specified for Thunderbolt (they usually have the logo on), although the connectors are the same a USB cable won't do the trick there.
Both the USB-C and Thunderbolt connections should work for a USB device, on my laptop both the USB-C 3.0 and Thunderbolt 4? connections work with any USB device I've thrown at them.
EDIT: I have just RTFM the MOTU M4 and it says:
If your computer has USB-C ports, use a USB-C to USB-C cable (rated for USB2), or a USB-C to USB-A adapter, (both sold separately).
So does this mean that the MOTU USB out is USB-A, and/or 'rated for USB2'?
- Gone To Lunch
DGL. wrote: ↑Mon Apr 18, 2022 9:18 pmGone To Lunch wrote: ↑Mon Apr 18, 2022 9:04 pmLuke W wrote: ↑Mon Apr 18, 2022 7:37 pm As above, if it's USB then there's less of an issue. If you're connecting Thunderbolt devices then you'll need to make sure the cable is specified for Thunderbolt (they usually have the logo on), although the connectors are the same a USB cable won't do the trick there.
Yes it's become a bit confusing now that the newer USB versions and Thunderbolt use the same connector. I find it helps to remember that USB-C is just the name of the connector itself, it doesn't dictate what's going through the cable.
But thats correct. Thunderbolt ports are compatible with USB devices, but Thunderbolt devices aren't compatible with USB ports, they need a Thunderbolt capable port. It just so happens that on most new compuers those two ports now look identical...
Luke W wrote: ↑Mon Apr 18, 2022 10:01 pmDGL. wrote: ↑Mon Apr 18, 2022 9:18 pmGone To Lunch wrote: ↑Mon Apr 18, 2022 9:04 pmLuke W wrote: ↑Mon Apr 18, 2022 7:37 pm As above, if it's USB then there's less of an issue. If you're connecting Thunderbolt devices then you'll need to make sure the cable is specified for Thunderbolt (they usually have the logo on), although the connectors are the same a USB cable won't do the trick there.
Luckily on mine the two Thunderbolt ports are on one side (with a regular USB socket) and the USB 3 USB-C port is on the other. The Thunderbolt connections are also for the charger to confuse things even more, though it does mean a genuine replacment charger is easy to get hold of as other manufacturers use the same Delta Electronics unit.
Gone To Lunch wrote: ↑Mon Apr 18, 2022 9:18 pm EDIT: I have just RTFM the MOTU M4 and it says:
Basically USB-C is backwards compatible. So you can use an A-C or a B-C cable and both will provide the right connection and power. C is capable of higher bandwidth, so C-C is best for high bandwidth applications. This won't be a problem for the M4
- Dave Rowles
