Expand Antelope Orion studio synergy core with a focus rite Scarlett 18i20 1st generation
Hello guys, I'd like to expand my antelope Orion studio synergy core with a focusrite Scarlett 18u20 1st generation. I've connected the 18i20 adat output to antelope Orion adat input. What should I do now? Thank you .
Re: Expand Antelope Orion studio synergy core with a focus rite Scarlett 18i20 1st generation
I think you need to connect the Focusrite up to your computer via USB and run the Focusrite Control program to set up standalone mode before it will work with the Orion. Once you've set it up, it should continue to work in that mode.
Posts: 16932 Joined: Mon Sep 10, 2001 12:00 am
I think you'll also need to decide which unit is going to be the master clock then set the other unit accordingly.
Posts: 29642 Joined: Sun Jul 05, 2015 12:00 am
Looks like the Scarlett still thinks it's the master there.
