EMT 948 turntable : the motor working but does not turn. Th
Post by CeruttiA »
Hello !
Has anyone had the problem. It started by the disc rotating irregularly with a slight scratching noise, the green light blinking irregularly. Now the motor is clearly engaged but the disc doesn’t move. Can someone tell me what i can do and what the problem could be ?
Thank you very much !!!
Alexander ( Paris)
CeruttiA
Posts: 109 Joined: Sun Nov 29, 2015 12:00 am
Paris, France
- passionate by sound, mosty ECM Jazz
Equipment: Rogers LS 5/8 BBC version/ Audio Research SP11/ EMT 948
Re: EMT 948 turntable : the motor working but does not turn. Th
Contact EMT. It's broken. :cry:
Posts: 43675 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
