How to record a heartbeat?
I'd like to record a heartbeat to then use in various ways (e.g. as a sample).
When I imagine "heartbeat", I have in my mind both the "thump thump" aspect as well as the more constant "whooshy" sounds that surround those.
Any suggestions on how to capture this (e.g. placement, equipment)? I don't have experience with contact mics (yet), but I am guessing that would be an element.
I'm open to suggestions for libraries that include heartbeats, but I'd prefer to capture my own, if possible!
Re: How to record a heartbeat?
A miniature lavalier mic (omni) taped tight to the chest.
Experiment with position (the side might be better than the sternum) and be careful dressing the mic cable to avoid rustles and bumps.
You'll need a very quiet room, a preamp with a lot of gain, and some hefty EQ to bring out the elements you want.
I doubt you'll get whooshing sounds -- that kind of thing needs ultrasonic scanners!
Posts: 43688 Joined: Fri Jul 25, 2003 12:00 am
A hydrophone and a core drill?
- forumuser840717
Regular - Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
As my daughters would say: eeeww!
Sure, provided it has a good LF extension and high enough sensitivity.
I would just use an electronic stethoscope - all the ones I know of can record audio. They can be pricey, so see if you can find someone who works in medicine who has one you can borrow.
(I'm more interested in this "whooshy" sound you mention - is this something you hear in your head, accompanying your heartbeat? If so, this might be a bruit, something you should have checked out.)
- rockydennis
Regular - Posts: 145 Joined: Sat Nov 03, 2018 5:36 am
I had a requirement for this exact same sound last month. A quick google search for ‘free heartbeat sample’ yielded many choices. Not as fun as making your own I agree but took like 5 mins and got the job done…
Even just thinking about it, makes me feel quesy
- cooneyblue
New here - Posts: 9 Joined: Tue May 24, 2022 5:21 pm
If you want a "whooshy" sound as well, try using a fetal doppler - they're not too expensive, and some have options to record - and you may know parents who own one.
- rockydennis
Slight necro thread here, but I tried using a contact mic this afternoon.
No dice.
Posts: 29713 Joined: Sun Jul 05, 2015 12:00 am
::: checks pulse :::
::: fishes out copy of World War Z for instructions on next phase :::
Zeppelin Labs Cortado MkIII. Positioned where I could feel the strongest pulse and held in place with masking tape. The only thing is picked up were my micro-movements whilst trying to sit as still as possible.
https://davylamb.bandcamp.com/
Well you try using your voice box when your lungs aren't functional.
Or necessary.
Or necessary.
It could just be a sensitivity issue, with the sound too quiet to produce a detectable output from the piezo. If you’ve ever used a Stethoscope, you’ll know that handling noise is much louder than the heartbeat and you have to press reasonably firmly as well. So there’s a knack to pressing it in place without making any noise. Masking tape may hold it in position but without applying any real downwards force
And with ultrasound sensors and the like, you always get a gel applied first to the skin for better sound transfer. I’d try using some of that (available on Amazon).
