Digital mixer, again.
Re: Digital mixer, again.
Arpangel wrote: Tue Jun 14, 2022 6:09 amThe only way this could be useful for me, is in setting up instrument and microphone "templates" for recording, with favourite effects chains as part of the scenes, for different instruments, that would reduce set-up time.
Exactly that. What a handy feature, and something no analogue desk provides!
Hugh Robjohns wrote: Tue Jun 14, 2022 8:08 am
It's the first thing I’ll set up when I get home, what I’m wondering now, I’m going through the manual :( is it possible to have effects "per channel" what I mean by that is does every channel have its own dedicated effects section, or is it one central effects unit that serves all channels? the latter would be a severe limitation.
PS
Looks like it’s got eight effects units, that’s not bad.
Post by Aled Hughes »
Arpangel wrote: Tue Jun 14, 2022 8:37 am
PS
I think the effects can be configures as either per-channel inserts, or as a global send effect.
Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Aled Hughes wrote: Tue Jun 14, 2022 8:46 am
PS
That’s correct, some can be used only as inserts, some sends.
Look! I’m making progress! and embracing new technology, aren’t I good!
:D:D:D
Post by Bob Bickerton »
:clap::clap::clap::clap::clap::clap::clap:
Thinking about scenes - sure if you're running Les Mis' you can assign 80 or 90 different scenes......
But in your case I would set up a few scenes as templates - easy recall for your favourite set-ups!
(not familiar with your desk so labels might be different - sometimes templates are different and called shows)
Bob Bickerton
Posts: 5634 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Bob Bickerton wrote: Tue Jun 14, 2022 9:40 am:clap::clap::clap::clap::clap::clap::clap:
They are scenes Bob, the thing is, I rather like those scribble strips, they’re handy, but if I haven’t got room for this desk, I don’t think the Compact and Producer have them?
Arpangel wrote: Tue Jun 14, 2022 9:45 am
The Compact has them, but not the Producer.
If you want smaller, maybe look at the Midas M32R as well. It’s essentially an upmarket X32 Compact, and works pretty much the same way.
Aled Hughes
Aled Hughes wrote: Tue Jun 14, 2022 9:47 am
I think size is going to be the only deciding factor in this, I’m already warming to this X32, the Compact, and Producer just don’t have enough inputs, Midas neither.
I don’t really want to have to faff around with input boxes, it’s a shame, as the Compact, and Midas 32r are the perfect size for me, if they had 32 inputs I’d buy one today.
Arpangel wrote: Tue Jun 14, 2022 9:57 am
The input boxes aren’t a faff really, especially if you’re going to keep them set up in the same place. It’s a single Cat5 cable to the desk, configure the desk once to see those inputs and off you go. Saves space, you can place the mixer where you want it, and have the stagebox out of the way to reduce cable clutter.
Aled Hughes
Post by S2 »
I have the Producer which I use for one of the bands I'm in. Slight overkill really, but I really like the scenes feature. We play in the same places a lot so it's nice to save the room setup for each venue and then recall it with the odd tweak the next time we play.
I use an A & H Zed 12fx for a smaller band and there is always a little thought involved when going from one to the other, especially if I haven't used one of them for a while.
But it's a great desk - even without the scribble strips and only 16 inputs. Far more portable for the live use we do than the Compact or the full size.
S2
Posts: 4488 Joined: Sat Jun 18, 2005 12:00 am Location: Dorset
Aled Hughes wrote: Tue Jun 14, 2022 10:14 am The input boxes aren’t a faff really, especially if you’re going to keep them set up in the same place. It’s a single Cat5 cable to the desk, configure the desk once to see those inputs and off you go. Saves space, you can place the mixer where you want it, and have the stagebox out of the way to reduce cable clutter.
Hmmm? what would I be looking at? to give an extra 16 inputs? I’m not familiar with Cat5 shenanigans, and would they appear as an extra layer on the X32?
Arpangel wrote: Tue Jun 14, 2022 10:45 am
https://www.bax-shop.co.uk/digital-snak ... gL-1_D_BwE
Gives 16 ins an 8 outs to a Behringer X32 or Midas M32 range. There is also a Midas equvalent that works with both ranges too.
They essentially take the place of the additional connections on the bigger X32- you can assign them ti be on channels 17-32 or however you like (obviously, having less faders, they are on a separate layer on the mixer itself)
It’s important to note that the desks are all the same internally, and can ‘see’ the same amount of inputs and outputs. It’s only the amount of onboard connections and faders that changes. They all have the same capabilities under the hood.
Aled Hughes
Don't want to upset you Mr A but did you consider one of these ?...
https://www.soundonsound.com/reviews/soundcraft-ui24r
Mike C seemed to think it was the dog's whatsits.
Posts: 19140 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
ef37a wrote: Tue Jun 14, 2022 11:07 am Don't want to upset you Mr A but did you consider one of these ?...
I have one. If it ticks your boxes it’s a great piece of kit. Not as many inputs as the X32 though, and it is (stupidly) fixed at 48kHz operation as an interface. Also, it’s more limited in terms of FX engines as they can’t be placed at inserts (you could work around it with routing, but it would be fiddly…)
Aled Hughes
Post by DGL. »
It gives you more sources to choose from, not any extra channels on a FS X32. Basically any channel can take it's input for a few different sources, these can be the onboard inputs, the card inputs or from the AES50 network.
In the routing section you choose where each channel gets it's input from and with the V4 firmware that can be from anywhere for any channel.
So I could have CH1 coming fromany of the onboard inputs, CH2 coming from an input on either AES50 A or B, and CH3 coming from the card (i.e. an input from the USB interface).
AES50 Supermac works in the same way as a regular snake except the transmission is digital, the pre-amps are in the stagebox, and the cable required is just shielded cat 5e (must be shielded with ethercons at ether end that are connected to the shield), in the world of AES50/Supermac this gives you 48 channels each way at 48Khz.
Naturally if you have one of the smaller X32's then a stagebox is needed to access all mixable channels (well you could use inputs from the card slot).
DGL.
Posts: 2320 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
Post by Dave Rowles »
I went for the Midas DL32 when getting more inputs for my X32 Rack. Purely because of the upgraded Pres, which do make a difference, and the flexibility. Works brilliantly as a stage box. Once I'd set the X32 to see it, it automatically uses the DL32 as the inputs first as long as the DL32 is on.
Dave Rowles
Posts: 1589 Joined: Thu Feb 28, 2008 12:00 am Location: Isle of Man
I use scenes for different recording and/or mixing scenarios, I have different ones for live mixing, studio band or acoustic recording etc.
You have sussed out the fx capabilities I think but yes, 8 stereo fx slots which can br use as inserts or send fx (with some limitations).
I love the LCD scribble strips, best thing since sliced garlic baguettes, they were the main reason I ought my X32 Compact rather than an A&H Qu16.
The S16 should work flawlessly and give you the extra physical inputs the Compact lacks compared to the full sized X32.
Posts: 22900 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
It’s here, in the basement, no time to even look at it yet.
Sam Spoons wrote: Thu Jun 16, 2022 11:46 am I use scenes for different recording and/or mixing scenarios, I have different ones for live mixing, studio band or acoustic recording etc.
It’s too big, it’s going to displace too much stuff, I could accommodate it, but it would upset my "cockpit" approach to playing, and become the centre of operations, my synths need to be in that place.
A Compact with an S16 would be OK, does the S16 show up in the X32 as another layer?
Post by Luke W »
Arpangel wrote: Thu Jun 23, 2022 7:47 am A Compact with an S16 would be OK, does the S16 show up in the X32 as another layer?
You assign it via the "Routing" menu, so you can pick which block of channels you'd like to see the inputs from the S16 on.
Luke W
Posts: 1698 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
You can assign input sources as a block of 8. So in your case it'd probably be inputs 1-8 and 9-16 desk pres, then inputs 17-24 and 25-32 S16 pres.
You can then assign any of the inputs to any channel. This is a little bit inflexible which is one of the major gripes against the desk, but I find, in reality, that I've rarely come across a situation where it would've been useful to have more flexibility.
Dave Rowles
OK so it doesn’t give me extra hardware inputs just more choice of inputs from the ones already on board?
Not sure what you mean here Tony? If you buy a Compact then the S16 will give you 16 more inputs and 8 more outputs but an X32 full console already has the max number of physical inputs the desk can process at any one time so there would be no benefit in having an S16 for your setup with a full sized X32.
Arpangel wrote: Sat Jun 25, 2022 12:10 pm OK so it doesn’t give me extra hardware inputs just more choice of inputs from the ones already on board?
The hardware inputs are on the S16.
I’ll try and break it down- think of it like this:
*All and any X32 is a 32 channel mixer. They all have exactly the same ‘brain’ and processing power, but but only the big ones have the physical connections for the 32 input.
*In order to have physical inputs for all channels on the smaller X32 (Compact etc) you need to connect it to a stagebox like the S16. That gives you 16 extra physical inputs and 8 outputs in addition to the connections already on the desk. For example, you can assign the desk inputs to channels 1-16 and the S16 inputs to 17-32.
*Obviously, the Compact has less faders than the big X32, so you need to use the fader layers to access the channels (there are buttons on the desk to switch labels, clearly labelled such as ‘1-8’, ‘9-16’ etc.
*So, essentially, an X32 Compact with an S16 offers the same power and connections as the big X32, just that half the connections are moved out of way onto the S16, and you need to press a button on the X32 a bit more often.
Aled Hughes
Nicely explained Aled :clap: Just to add, the full sized X32 only has 8 extra faders making 24 plus master in all (the Compact/Producer has 16 plus master). All X32s are, actually, 40 channel mixers, all of which can be assigned to analogue sources (I think, not entirely sure if you can assign analogue inputs to the USB stereo channels). The aux/USB channels have a more limited feature set than the main 32 channels and you can only send 32 over USB to the DAW simultaneously but it does have huge flexibility.
