Thanks for the very clear explanation Aled.
If I’m going to go in this direction, the combination is a Compact, and an S16, I still get the scribble strips (important) and all the inputs I need.
Not having matching numbers of faders to inputs, could be seen as limiting, in a live mixing/recording situation, but I guess these can all be automated to overcome that problem? if I’m correct, even though a layer may not be visible, it’s volume curves will still be active?
Digital mixer, again.
Re: Digital mixer, again.
Arpangel wrote: ↑Sun Jun 26, 2022 6:37 am Thanks for the very clear explanation Aled.
The X32 does not have automation. That would need to be handled by your DAW.
If you need automation of your live inputs before hitting the DAW for whatever reason, I guess you’ll need to be looking at some rare and expensive system, with a lot of setup and syncing work and associated headaches!
I was under the impression that you’d use the X32 as a big interface/patchbay/FX unit to get the signals into your DAW.
- Aled Hughes
Posts: 2120 Joined: Tue Oct 24, 2006 12:00 am
Even with the full size versions you still only ever have 16 inputs "in view" at a time, but once you've put some time into getting to grips with the way of working then switching between layers quickly becomes second nature.
The Compact (and Producer) can assign inputs to both fader banks so allowing 16 visible at a time, the FS X32 has 16 faders in it's LH/input fader bank so doesn't do this.
Forum Aficionado - Posts: 22636 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
The X32 system I need will cost me £2,000+
I’ve thought it through with your help and it’s not even almost there in my head.
It’s been great to play with, effects are very good, and it feels OK.
Space is my biggest enemy, it’s more important for me to address that than look at gear right now, as more space would enable me to have what I really need, and deep down really want, and that’s a large format analogue console, and £2,000 would go towards something really nice, so I’m not making any moves just yet.
Borrowing this X32 was one of the best things I’ve ever done.
Still think a Speck XtraMix 6 is exactly what you need…..
- fatbenelton
Frequent Poster - Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
It probably was, and I think you're right. A big, old-school analogue console is what you'd be happiest with.
You just need to find the space.
Posts: 43336 Joined: Fri Jul 25, 2003 12:00 am
This thread reminds me that I need is to quit rearranging my gear and get on with making music
- resistorman
Frequent Poster - Posts: 2954 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
resistorman wrote: ↑Mon Jun 27, 2022 2:48 am This thread reminds me that I need is to quit rearranging my gear and get on with making music
I have about six albums on my friends website and another 32 unpublished, I have well over 200 hours of music in various formats that could be sorted into albums.
It wouldn’t bother me if I never recorded another note, and I’ll never live to edit all of my back catalogue.
But like a lot if by people I can’t stop recording, and also like a lot of people my stuff will probably go unnoticed in the grand scheme of things, thrown in a skip.
Messing around with equipment and playing with gear doesn’t concern me, it passes the time, as I get older my musical output is decreasing and other things are more important, you realise what is actually important in life.
Designing my modular, rearranging my studio, and posting on this forum, are all in my opinion “musical acts”
Certainly “museful” acts.
- Guest
